Old 11-26-2020, 02:38 AM #16
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Originally Posted by 4Runner4Leon View Post
Oops, my bad - the hole was not there, I drilled it with a hole saw. There is a flat area where the clutch pedal would go, and the sound insulation is perforated there, so it makes for a nice installation. But you do need to drill the hole .
Oh snap. How does one do that without screwing it up? Haha
Old 11-26-2020, 01:10 PM #17
4Runner4Leon's Avatar
4Runner4Leon 4Runner4Leon is offline
Real Name: Leon
4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all 4Runner4Leon is a name known to all
Real Name: Leon
Went in from the engine bay side to most of the chips out of the interior. Just drill slow and steady .
1997 4Runner Limited 4WD E-Locker ~200k | Falken Wildpeak A/T3W 265/75/16 | Pro Comp 69 16x8 | OME 2906 | B&M 70264
Addicted Offroad Front Bumper | Spiker Engineering High-Lift Hood Struts and Ultragauge Mount
4Runner4Leon is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 02:57 PM #18
jross20's Avatar
jross20's Avatar
Man that makes me nervous.. how did you get a drill on there? Doesn't seem like there's a left room, and do you recall what kind of bit that you used?
this is definitely one of those things I would prefer to pay someone to do just because I don't have much experience with drilling through metal
Old 11-26-2020, 04:29 PM #19
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
On my 98, I used an existing hole in the firewall plugged with a plastic plug. I used a grommet identical to the one @4Runner4Leon mentioned.
*11/4” Universal Firewall Boot
Amazon.com: Daystar, Universal Firewall Boot, Single, Accommodates 3/8" to 1" Diameter Wire Bundles, fits any vehicle that needs a wire loom, KU20040BK, Made in America , Black: Automotive
This video will show you which hole I'm talking about. Start watching the video below at play time 25:21.
Old 11-26-2020, 05:09 PM #20
Real Name: Leon
Real Name: Leon
I used my bimetal hole saw set with an 18V cordless drill - lets you drill slow with gobs of torque, ideal for hole saws. But for sure, if you're not comfortable, this is not the ideal place to learn. Drill some holes on a scrap piece first to get the hang of it.
Old 11-26-2020, 05:38 PM #21
jross20's Avatar
jross20's Avatar
Timmy to the rescue!!! Man this is much more my speed, haha. Il go ahead and order that grommet.
Will there be any downside from drilling a little hole through that plastic material? Instead of just having the little x cut?
Old 11-26-2020, 06:23 PM #22
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Thanks for the video, that looks like a great spot too. I have a 99' SR5 and that entire area is covered with firewall insulation (see pic), which leaves me with a couple of question
- do you know if there is still a grommet in the 99's?
- if there is, is there any harm in removing the insulation in that area for the grommet? (ie, is there something inherently different that makes the 99+ models run hotter in that area?)
- Will the temps in that area be significantly hotter? Sorry about being a newb but I don't know how hot it actually gets in there and my wire says it's rated to 150 C
Thanks!
Best options for routing wires through firewall-screenshot_99-jpg
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 11-26-2020, 08:06 PM #23
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
You could drill a hole. I just took the path of least resistance and cut an X with a utility blade.
Old 11-26-2020, 08:09 PM #24
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Thanks!
You should probably only remove as much insulation as you need too. I think it's to reduce heat transfer as well as provide some sound deadening. I don't know if the 99 has that same grommet hole. If it doesn't, just do what the other guys suggested and drill your own hole with a hole saw.
Old 11-26-2020, 10:18 PM #25
So I found that there is a grommet behind the insulation. I'm still considering drilling a hole because the grommet on my truck would pretty much come all the way out and touch the engine unless I cut it down some.
Honestly, I wish there was a way to bring the wires in directly behind the radio, which is where I want them ultimately.
99' SR5 HRU
Old 12-01-2020, 11:48 PM #26
So, I'm opening this up for one more minute before I start hacking away at this. I tore the whole dash apart to see if there was any way to bring a 22 pin weatherpack connector into the passenger side. I've decided to use the weatherpack for organization and because I feel it is simply more watertight than going the grommet route. I found a spot where it would fit but the problem is I'm not entirely sure where this spot would exit exactly into the engine bay.
This image is looking behind the passenger side airbag
Another option is the passenger footwell, but again, I don't really know where this would exit and it looks like it might not even be possible b/c it would be @ the wheel well
I've relocated the cruise and have a plan for my platforms, plus a worst-case scenario plan where I will run the harness back to the driver side and put the weatherpack next to the factory grommet
The small platform will hold two breakers, while the larger platform will hold the fuse blocks, grounding blocks, relays, etc.
99' SR5 HRU
Old 12-02-2020, 06:07 PM #27
jross20's Avatar
jross20's Avatar
Really wish someone sold those nice acrylic platforms to mount all of this stuff. I'm just using universal harnesses from that led site.
The boot is on the way, I'll try to get some pictures to help others out too even it gets here.
Old 12-02-2020, 09:31 PM #28
I agree, ripcord's platform was awesome and I even looked at the machine he used to cut it but soon realized it was several thousand dollars, lol. One thing I did notice though is that on his 2002 at least, the driver's side bay is not as crowded. I took a picture of his bay before the mod vs my bay and you can see there is significantly more room to clear the hood with a platform in that location. If I had more clearance I probably could work something to fit my setup in that space, but there is zero chance of that happening on my 99.
Here is his engine bay before the platform
vs my 99
99' SR5 HRU
Old 12-02-2020, 09:57 PM #29
jross20's Avatar
jross20's Avatar
vs my 99
Ah yeah i wish there was another option... I've tried to come up with some solutions...but there isn't anywhere to mount it that I can figure out ...haha
Perhaps under the dash ....?
Old 12-02-2020, 11:22 PM #30
cblock406's Avatar
cblock406 cblock406 is offline
Real Name: Christian
cblock406 is a jewel in the rough cblock406 is a jewel in the rough cblock406 is a jewel in the rough
cblock406's Avatar
It will fit, mine looks just like yours, but you seem intent on using the passenger side.
You could probably make another mount for your relays on top of the factory fuse box, or make a bracket to mount them in the fender out of site. Not sure what I’ll do when I get to that point.
https://www.toyota-4runner.org/3538657-post172.html
Build Thread: http://www.toyota-4runner.org/3rd-ge...ce-thread.html
@projects_always
cblock406 is offline   Reply With QuoteReply With Quote
boot , couple , daystar , noticed , wires
Need to get some wires through the firewall Signal 5th gen T4Rs 22 06-24-2022 02:58 PM
How did you guys run all your wires through the Firewall into the 4Runner? gkatmar Engines / Suspension / Wheels / Tires / Audio / Accessories 6 02-20-2022 09:58 PM
Wires through firewall eds72 4th Gen T4Rs 17 07-26-2016 12:39 PM
Cable routing through firewall mikey's2010SR5 5th gen T4Rs 10 07-31-2012 09:21 PM
Where to run aux wires through firewall? sant6236 3rd gen T4Rs 1 01-16-2008 05:59 PM
