Old 11-26-2020, 06:45 PM #1
jross20's Avatar
jross20 jross20 is offline
jross20's Avatar
Maxiumum F/R Shock Collasped Lengths
Wanted to collect some more information to add to my database for the community and myself.
I have a list of shocks for the front and rear, but there seems to be conflicting information over the maximum collapsed lengths. Basically at what point is the shock too long collapsed to where it would affect up travel or cause damage.
So far, some guys say around 14" is the max for the rear, does everyone concur? What is the max for the front?
My hope is to eventually make some kind of detailed information guide so we can better plan out suspension work.
Old 11-27-2020, 10:19 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
That's going to vary a lot depending on stock/extended bump stops, body lift, and tire size/wheel specifications. Some people like eimkeith have cut the front bump stops down to allow more up travel. He had to modify his front inner fender to allow the tire to go up that high.
Old 11-27-2020, 01:15 PM #3
jross20's Avatar
jross20's Avatar
I thought about it and I think I should have worded it like so:
Assume you remove all tires, with stock bumpstops, what's the maximum collapsed/compressed measurement before the shock starts to overcompress and "become the bumpstop".
Basically we need this foundational control information so we can better plan out mods. My thought is that we are just blindly extending bumpstops and it may be unnecessary or we might not be extending enough.
collapsed , front , information , max , shock
xreas replacement - shock vs shock/spring replacement amheck 4th Gen T4Rs 21 11-14-2017 08:21 PM
Shock help Cali 4runner Classic T4Rs 6 02-04-2017 01:19 PM
What shock or shock/coil combo would you choose? Levinz11 4th Gen T4Rs 9 04-07-2015 09:07 AM
Do LC shock bushing match stock lower shock bushings?? Jc12 3rd gen T4Rs 2 04-10-2012 07:54 PM
Shock Help 2004TR4-SR5 4th Gen T4Rs 4 02-16-2011 10:11 AM
