Old 11-27-2020, 09:06 PM #1
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Relocating 4X4 switch on Limited TCASE Shifter
Anyone know if its possible to move the 4WD switch that is on the Limited XFER case lever? I would like to put a custom knob, but the switch is presenting an issue. Is it a momentary switch like the OD Switch on the Trans?
I would Ideally move it up to the left side of the dash where the blank plates are. I plan to add an E Locker, so it would be cool to have all my 4x4 control switches right there...
Thanks in advance for any insight!
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 11-27-2020, 09:39 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Both the OD and 4WD switches are detent switches or latching switches if you prefer. I have a limited multi mode with RR diff lock and actually like the 4wd switch where it is, no searching or scanning it's intuitively right there in my right hand conveniently placed so you can swiftly hit it or pull down to 4x4 as you slide into the ditch, I have to scan for the RRDIFFLOCK.
The PO of one of my 4runners can attest to not engaging 4wd while one tire is spinning after getting stuck after sliding into a ditch, pop goes the t-case, mind you his rear brakes where not set up properly to stop that one tire from spinning adding to the likelyhood of this senerio. I'm also unsure if the non multi mode tcase shifter would fit in the limited tcase shifter so you don't have a big hole in the shifter. Sounds like a lot of work to change a pretty good setup IMO.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 06:29 AM #3
HiluxSurf SSR-G's Avatar
HiluxSurf SSR-G HiluxSurf SSR-G is offline
HiluxSurf SSR-G will become famous soon enough HiluxSurf SSR-G will become famous soon enough
i think on the 2001-2002, the OD switch is momentary.
HiluxSurf SSR-G is offline   Reply With QuoteReply With Quote
Old 11-28-2020, 11:11 AM #4
shadow247's Avatar
shadow247's Avatar
The OD switch is definitely momentary on the Limited 2001 for sure. I had that apart the other day when I swapped on a new Auto Shifter.
Guess I will dig into it some more.
The 4Runner Show
Old 11-28-2020, 12:38 PM #5
pavelvoivoda's Avatar
pavelvoivoda pavelvoivoda is offline
pavelvoivoda will become famous soon enough
Originally Posted by shadow247 View Post
Anyone know if its possible...
You can do anything. Just exchange the wires on to a regular switch that is not momentary. Like the rr diff lock, or any other that stays in.
Here is an original 4x4 switch that locks in place when you push it, that you can use to turn on AWD, and then if you have a center diff, you can lock into 4x4 either by pulling the lever back, or pressing the momentary switch on the dash, depending what year your Runner is.
8472560040 Genuine Toyota SWITCH, CENTER DIFFERENTIAL LOCK 84725-60040 | eBay
Or what you can do is move all your 4x4 switches in one place with the 4x4 lever...
Relocating 4X4 switch on Limited TCASE Shifter-viber_image_2020-03-30_20-31-07-jpg
"Sadly, unlike the Bill of Rights, the UDHR has no 2nd amendment, rendering it useless. Remember that."
2person xUN diesel T4R equipped for long distance touring w/ light-duty off-roading.
1000kms range w/ subtank
pavelvoivoda is offline   Reply With QuoteReply With Quote
4x4 , add , limited , move , switch
WTB: 3rd gen manual tcase leather shifter boot (96-98) G_Raw For Sale: T4R Items 2 11-05-2020 11:55 AM
5 speed, J shift tcase shifter install flooredrunner 3rd gen T4Rs 6 05-26-2020 01:20 PM
Relocating LTD Transfer case Switch phillyd2 5th gen T4Rs 30 03-08-2020 06:03 PM
Transmission & tcase shifter gasket(s) kolelt 3rd gen T4Rs 0 06-30-2017 02:15 PM
Relocating 110V switch (2004 Limited V8) to center console matthewpstro 4th Gen T4Rs 0 02-21-2014 10:50 PM
