Old 12-03-2020, 09:26 PM #1
bassglass bassglass is offline
bassglass is on a distinguished road
3rd gen after market seat install question
installed some nice after market in 2000 t4r, I see on the underside of the oem passengers side seat there is another lead from the seat belt wires / connector. I'm assuming these are the leads for a sensor mat. I'm guessing this isn't simply a normally open, single pole switch arrangement and I'll get away with twisting the two wire together... I'd basically like to wire it so that the srs always sees an occupant. I saw emulators on line Any help?
bassglass is offline   Reply With QuoteReply With Quote
Old 12-04-2020, 03:33 PM #2
Depending on year, that sensor is either not there ('96-'98), only used for the seatbelt warning light ('99-'00) or integrated into the SRS system ('01-'02).
Since you have a 2000, just leave it unplugged. Your passenger airbag will work normally. The SRS system only uses two forward sensors and controls the two airbags and two front seatbelt pre-tensioners. It does not use seatbelt information or occupancy information.
If you short the sensor wires (it is simply a switch-type sensor), you will have the flashing seatbelt warning light on the dash unless the seatbelt is plugged in.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-04-2020, 05:50 PM #3
Thanks so much Charlie! I certainly appreciate your help
Sent from my Pixel 3 using Tapatalk
3rd , market , seat , twisting , wire
After Market Radio Install (Lesson Learned) losinstinks Classic T4Rs 18 08-02-2016 12:51 AM
after market cd deck install aarona3184 4th Gen T4Rs 3 05-13-2012 07:40 PM
After market inverter install with a factory-ish look phillipah 4th Gen T4Rs 5 02-25-2010 11:25 AM
Bypass seat airbag and seat belt lights? Recaro install steve germany 4th Gen T4Rs 0 04-04-2009 09:18 AM
After Market Sub Install exclusivebeef Engines / Suspension / Wheels / Tires / Audio / Accessories 2 02-25-2008 12:15 AM
