Old 11-30-2020, 03:50 PM #1
ArmArak's Avatar
ArmArak ArmArak is offline
ArmArak will become famous soon enough ArmArak will become famous soon enough
ArmArak's Avatar
Custom Spare Tire Swingout Build (Hitch Mount)
Hi guys,
I finally finished my spare tire swingout! My original plan was to build Bandit Runners awesome bumper design but my schoolwork and college apps caught up with me so I didn't have the time (or space) to start a project that big. I still plan on building the full bumper as soon as I get the chance (maybe this summer when I have more time), but in the meantime I needed a way to carry my spare tire. I decided on making a tow hitch mount swingout design as it wouldn't be too complicated and would be pretty easy to fabricate.
Here's the final results I think it worked out pretty well! Lmk what you think!
I run 255/85R16 Toyo Mud Tires for reference.
I started off with some measurements on the truck and designed a 3D model in SolidWorks. I placed a picture of the rear of the 4Runner behind the model to get an idea of how it would look installed. I think it worked out pretty much exactly to the plans.
After being happy with the CAD I started building it. I'm lucky enough to have access to a milling machine so some of these parts were made on a Bridgeport, but everything could easily be done with handtools as well. The hardest part was bending the square tubing for the tire carrier beam and gas can holder. These two parts could have been made from two pieces welded together; however I wanted to attempt making the bends. It took some time with a cuttoff wheel making cuts in the tubing and bending it into place with a press. Any gaps in the bends were filled in during welding. The 90 degree bend was very easy, but the other one was rather difficult and took a few tries going back and forth between the grinder and the press to get it right.
I don't own a welder so I had to take the parts to a buddies house to weld everything up. All the welds are super simple and only require short beads, nothing complicated. Structurally the entire build is very solid and weighs about 85 pounds.
The gas can holder is bolted onto that side beam. I bought the can and the holder on eBay for 30 bucks. The holder is pretty solid but I ditched their cover mechanism and stitched on a leather belt.
The canister is pretty crappy though, but eh what can you expect for 30 bucks
For those wondering the license plate cover is from a Landcruiser.
If I were to redo this build I would make a few changes.
First I would have the tire sit a bit closer to the trunk. This image shows the gap that I would like to be smaller.
Next I would make it a dual swingout. It was important that the tire be on the driver side because it allows more visibility looking back, but it was also important that the swingout would not open into traffic. This puts a lot of torque on the pivot point when open. It's definitely strong enough to hold it but a dual swingout would be a more elegant solution.
Overall I think the project was successful and will work rather well for its purpose! Let me know if you have any questions.
ArmArak is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 04:04 PM #2
Ashura's Avatar
Ashura Ashura is offline
Ashura is on a distinguished road
Ashura's Avatar
Nicely done!
Ashura is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 06:59 PM #3
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
This has to be the nicest hitch mount carrier I have seen. Nice job.
Were you able to mitigate the wobble that some of these tend to have?
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 11-30-2020, 07:25 PM #4
ArmArak's Avatar
ArmArak's Avatar
Thank You!
I did originally have quite a bit of wobble but I fixed it easily. First I used steel shims from mcmaster.com to get the fitment very tight, that way there is no place for it to wobble in the receiver. The shims make it difficult to fit into the hitch but I used a bit of motor oil to lubricate it and with a few pushed and taps with a hammer it was easy enough to line up. Next I made a clamp from some 3/8 steel and some 1/2 inch treaded rods. The pic shows how it sits clamping the swingout to the hitch.
Now it doesn't wobble!
Old 11-30-2020, 07:30 PM #5
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Very clever!
Full Skid Plates
Old 12-02-2020, 01:22 PM #6
fourfive's Avatar
fourfive fourfive is offline
fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough fourfive is a jewel in the rough
fourfive's Avatar
Nice work on the hitch swing out. I need to get this done so I have the ability of carrying around a full size spare as needed. I've thought about building my own but also considered buying one from Detours of Maine since their hitch swing out tire carrier is already rated for 35" tire.
1. Black 2002 SR5 4x4 5vz: Front Toytec Ultimate coilovers/eibach 600#, SPC UCA, durobumps Rear Bil5100/Superflex, SS adjustable panhard, PCK, durobumps Body Lift 2" 4crawler Tires 315/75/16 BFG KO2 Wheels SCS F5 Matte black 16x8 3.5bs Armor Custom bolt on rock sliders (no frame drilling)
2. Black 2001 SR5 4x4 5vz: stock
3. Black 2018 TRD Pro (wife’s): Armor Custom bolt on rock sliders (U-bolts)
fourfive is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 03:22 PM #7
ArmArak's Avatar
ArmArak's Avatar
Do you know how much those cost? I'm curious because Wilco sells one for about $1000! You can pretty much get a full bumper for that much lol. I built mine for around $300 btw.
build , holder , pretty , swingout , tire
Detours of Maine Spare tire hitch mount system utctscanr75 5th gen T4Rs 59 09-28-2022 01:51 PM
FS: CBI hitch mount Spare tire/hi-lift carrier $250 03V84R For Sale: T4R Items 19 12-15-2019 08:21 PM
FS: Custom fabbed hitch spare tire carrier, Louisville KY, $285 OBO Noshirtganshirt For Sale: T4R Items 7 02-12-2019 11:17 PM
WTB:CBI hitch mount spare tire carrier HavocRunner Want to Buy/Trade 0 03-29-2015 09:54 AM
Bought a Custom made tire swingout masphx 3rd gen T4Rs 14 09-27-2014 12:50 AM
