Old 12-01-2020, 09:36 PM #1
Coopsdaddy Coopsdaddy is offline
Coopsdaddy is on a distinguished road
Power steering pump?
I have a 2000 with 185000 miles,clean and no leak or issues other than needing new inner tie rods,so i bought new oem inner and outers and installed them without any issues.I painted and counted threads and got new ones installed very close.It has sit in garage parked for a week while i waited on parts.
I went ahead and did plugs and wires.
Got it together tonight and noticed a different sound,and when i went to back out the steering was squealing and tight,checked fluid and jacked up and cycled steering and did the same,just not as bad.Drove it and while it feels nice and tight because of the tie rods the steering is very stiff and noisy.
Could the pump just go bad ?
Something else?
Thanks
Coopsdaddy is offline   Reply With QuoteReply With Quote
Old 12-01-2020, 10:46 PM #2
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
Cold weather have anything to do with it?
A few years back, during first starts on the coldest of days (maybe 30 here), the first minute, the pump would make a noise. Did a turkey baster suck/fill a couple times, solved that pesky issue. So maybe time for new fluid, it makes a big difference on power steering since most never swap it out. Luck.
Old 12-02-2020, 02:36 AM #3
Twisted Sid's Avatar
Twisted Sid Twisted Sid is offline
Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about Twisted Sid has a spectacular aura about
Look up how to clean the power steering reservoir screen on here and on YouTube.
That helped my steering feel a bunch. Its also a good time to do a fluid flush while your at it.
'99 4Runner SR5: 5VZ, 2wd, AT, 400k+ club
'94 Pickup: 2wd, 22RE, 5spd, (3RZ swap in progress)
Front: Total Chaos Uniball Kit, Fox 2.5 8'' coilover
Rear: Deaver F67 Leaf Springs, Fox 2.0 14'' Reservoir Shocks, E-locker Axle 4.88 Gears 33x10.5 BFG ATs
Twisted Sid is offline   Reply With QuoteReply With Quote
Old 12-02-2020, 05:51 PM #4
Squeal? Replace (or tighten) the belt. If the belt is glazed/old, it won't grip well enough to work even when tight.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-02-2020, 06:09 PM #5
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 for new belt and +1 for cleaning the screen reservoir screen. :-)
Old 12-02-2020, 10:29 PM #6
Flushed with new valvaline syn dex fluid,took off tank and cleaned screen,i think that was it.
I will never neglect the power steering fluid again!
Old 12-02-2020, 10:46 PM #7
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
+1 for a belt and cleaning and weather. Could even have air trapped in the system
I've also noticed when the fluids cold the steering rack doesn't like working when you're nearly stopped and trying to crank the wheel - especially at/near full lock. Makes a much shittier sound than the PS pump. Once the fluids up to temp after a bit of driving it's not nearly as sensitive. Obviously with winter here this has only been exacerbated since the fluid is extra cold after sitting all night. Like I said, this is just what I noticed so take it with a grain of salt if you have too. I could be describing a smoked rack for all I know
Oh, power steering problems. Reminds me of my Dakota; went through 8 pumps in that truck. Good memories
installed , pump , steering , tie , tight
Power Steering Pump or Steering Rack? *VIDEO* LexusFTW 3rd gen T4Rs 44 08-11-2021 10:11 AM
Problems with new power steering pump/ new pump with fluid. no power steering? cdcrone123 Classic T4Rs 3 08-27-2013 09:29 PM
Steering Rack and Power Steering Pump Replacement thebrandon 3rd gen T4Rs 5 07-02-2013 10:07 AM
Power Steering Pump HELP!!! kpnavarro Classic T4Rs 13 11-09-2012 05:37 PM
