Old 07-15-2021, 08:45 PM #1
dstewart3ss dstewart3ss is offline
dstewart3ss is on a distinguished road
Roof rack cross bars loose
Both cross bars are completely loose and slide back and forth. New to me T4r. How can I secure them?
Roof rack cross bars loose-7e0f41a7-f4af-47a3-95e5-c971030303d6-jpg  Roof rack cross bars loose-2e5cc68b-b42d-4900-a588-56bf4159211b-jpg  Roof rack cross bars loose-ec4cb44b-d534-4d6f-907a-2f4567f286cb-jpg  Roof rack cross bars loose-1443b43b-c65f-4789-913a-1aded18074c2-jpg
dstewart3ss is offline   Reply With QuoteReply With Quote
Old 07-15-2021, 11:48 PM #2
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
The cross bars are supposed to have a tightening bolt featuring a plastic knob
at each end...two per bar. Yours appear to be missing. Those square metal/plastic pieces in the track are the nuts for those bolts.
pluton is offline   Reply With QuoteReply With Quote
Old 07-16-2021, 12:47 AM #3
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
The missing bolt is an M6-1.0 if you want to try the hardware store route. Not only should they slide back and fourth with the missing bolt but they should also pull right off if I'm not mistaken. Just FYI so they don't fly off when your driving down the road.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 07-16-2021, 02:53 AM #4
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
There is suppose to be a threaded bolt to lock it in place that looks to have fallen out. Luckily the cross bar can't slide out unless you remove the end caps that are screwed down.
Pyral is offline   Reply With QuoteReply With Quote
Old 07-16-2021, 10:54 AM #5
ToyotaBrah's Avatar
ToyotaBrah ToyotaBrah is offline
ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about ToyotaBrah has a spectacular aura about
ToyotaBrah's Avatar
I sell those knobs. PM me and I can work out a deal. You're also missing the 3 smaller load bearing bars.
ToyotaBrah is offline   Reply With QuoteReply With Quote
Old 07-17-2021, 01:54 AM #6
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
Question about the load bearing bars: Is their purpose to protect the roof if luggage is placed directly in the roof surface? Are they necessary for side-to-side dimensional stability of the rack? If I run a roof rack (Yakima) perched on top of the stock crossbars, can I eliminate the smaller load bearing bars? Your thoughts?
Old 07-17-2021, 10:25 AM #7
calimobber's Avatar
calimobber calimobber is offline
calimobber will become famous soon enough
calimobber's Avatar
Im pretty sure they are just to prevent anything sitting directly on the roof. Helps spread out the weight. They are pretty light weight.
My 2002 4runner Build : http://www.toyota-4runner.org/3rd-ge...r-project.html
calimobber is offline   Reply With QuoteReply With Quote
Old 07-25-2021, 11:55 AM #8
ToyotaBrah's Avatar
ToyotaBrah's Avatar
Hey, I apologize for the late response. The 3 bars have the ability to disperse the weight more evenly across with their adjustability and rubber strips that are on the bottom of each of them. You would be fine removing them. I doubt they offer any added structural rigidity to the roof rack.
Tangent: I'm always weirded out whenever I see a 3rd gen that has a completely loaded roof with an aftermarket rack, roof top tent and several other accessories mounted. The factory rails are only held on by 10 very short T-25 screws that bolt to the skin of the roof. It's clear that Toyota designed it for light cargo (kayaks, cargo carrier box) Just does not seem wise.
If I were you, I would mount the Yakima bars directly to the stock rails and bypass using the 2 larger bars. Those bars have an inferior design and crack easily where the feet and the middle of the bar join.
Old 07-27-2021, 01:56 AM #9
pluton's Avatar
Real Name: Keith
pluton's Avatar
Real Name: Keith
The stock crossbars are feeble, I know.
In Yakima world, the way to mount the Load Warrior to the stock rails is to use Yakima's own grotesquely overpriced crossbars, which appear to make the Load Warrior sit at least as high, and maybe even higher, off the roof than it does on the stock Toyota crossbars. I may explore a custom solution that utilizes aftermarket rail anchors, like the old Defender Rack mounts did.
One of my current requirements is that the roof rack be easily and quickly removable.
Old 07-27-2021, 12:05 PM #10
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
The Sherpa Rack installation video says to leave the roof crossbars to provide stability to the track rails.
Old 07-27-2021, 05:36 PM #11
phattyduck phattyduck is online now
I definitely agree on the weakness of the OEM cross bars.
As for the OEM tracks, they do go to a stiffening plate below the roof, so it is not just to the outer sheet metal. Also note that those T25 screws are M6x1.0 which can take at least 1000 lbf each... (tension, shear is a somewhat less). The challenge is not overloading a single fastener and avoiding long term fatigue.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
phattyduck is online now   Reply With QuoteReply With Quote
Old 07-28-2021, 12:59 PM #12
vegask vegask is offline
vegask will become famous soon enough
There are some good pictures in this post that show what it looks like underneath.
The guy that made the blog post reinforced his roof with some flat bar and longer bolts. I did this mod back when I had a roof top tent and it made a pretty big difference.
Reinforcing the Roof
SAS 97 4runner / Bone stock 2005 4runner / aka "Kurtfab"
vegask is offline   Reply With QuoteReply With Quote
bars , cross , loose , roof , secure
WTB Trd Pro Roof Rack cross bars edgesalon Want to Buy/Trade 1 03-07-2020 12:33 PM
WTB: [MA] Cross bars for 5th Gen Roof Rack zerowkul98 For Sale: T4R Items 0 11-27-2017 01:36 PM
WTB: cross bars for 2014-15 cross bars for factory roof rack BowJanked For Sale: T4R Items 0 08-27-2015 01:24 PM
Roof rack without cross bars. Dunk50 5th gen T4Rs 3 09-26-2012 11:04 AM
WTB: 5th gen TE roof rack/cross bars teepee73 Want to Buy/Trade 0 10-09-2010 05:55 PM
