In your engine bay diagnostic port take a wire to use as a jump wire and plug into AB and TC port. Turn key on to ACC position. Your cruise control light will have a seizure. Your air bag light will go on for 6 seconds doing it's normal self check. It will then do 1 second blinks for however many times, rest 2.5 seconds, then blink 1 second interval again, then 4 seconds off. This tells you your two digit code, then you need to look that code up.
Example: blink 6 times, off 2.5 seconds, blink 4 times, off 4 seconds is code 64.
You may have more then one code. So after the 4 seconds off it may start the second code...
Example: blink 6 times, off 2.5 seconds, blink 4 times, off 4 seconds, blink 3 times, off 2.5, blink 2 times, off 4 seconds. Codes 64 and 32
So watch it until the first code repeats...
Now that you know the code and where the problem is disconnect negative terminal and inspect/fix.
Once you fix the problem you need to clear the code. IT WILL NOT CLEAR ON ITS OWN!
Obd2 from dealer is best...make a friend in the repair section, bring him beer and hope he doesn't charge you...
Other wise with key in acc position using 2 long wire. Plug one into tc port and one into ab port. Starting with the tc port alternate grounding them on a body ground for 1 second intervals allowing .2 seconds between switching. Tc needs to be grounded 3 times and on the last one hold for a few seconds.
This is really hard. It will go
Tc ground 1 sec, no wires touch for .2 sec, ground ab 1 sec, no wires for .2 sec, tc ground 1 sec, wires of, ab ground 1 sec, no wires .2, ground and hold tc.
If done correctly your airbag light will hyper flash....code cleared.
Turn acc off.
Restart truck, if still no airbag light you have fixed it. If airbag light returns you did not fix problem...restart diagnostics and chasing the problem.
Hope that makes sense and good luck.
P.S. if you get code 64 it will be an open in right hand circuit. Options are poor connection at relay under intake box in engine, airbag behind glove connection, or passenger seat belt connection. I'd start with the seat belt...
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
