Old 12-06-2020, 06:09 PM #1
hdoggie24 hdoggie24 is online now
hdoggie24 is on a distinguished road
Bilstein 5100 shocks work on 5th gen front springs?
I was wondering if the Bilstein 5100 front shocks would work on a set of 5th gen front springs to put on my 97 4runner ? I got the front springs for free and are basically brand new but want new shocks. Anyone do this or know how it would ride? would it ride way stiff? I don't do much offroading, mainly street driving
hdoggie24 is online now   Reply With QuoteReply With Quote
Old 12-07-2020, 10:15 AM #2
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light Bad Luck is a glorious beacon of light
Real Name: Patrick
Long answer short, 5th gen front springs will not work.
2000 Limited V6 Auto E-Locker
Old 12-07-2020, 07:35 PM #3
4runnerfiend's Avatar
4runnerfiend 4runnerfiend is offline
4runnerfiend will become famous soon enough 4runnerfiend will become famous soon enough
5th gen springs front springs... on the 5100's will fit and work. that is what I run on the front of my rig. They are about the same as the 99 talls so expect 1" or little more over stock.
Mine are set to second from top (pretty sure. its been a while) C clip, I have Tundra 5100's. The ride pretty good not harsh in my opinion. Its no Kings but good ride.
B7C8E1E9-955F-4364-93C8-784EE54ACA3A
IG: @4runnerfiend- 1999 SR5: ELocker Retrofit, Wheelers T1 Coils-tundra 5100's, Built Right UCA's, LC 8 wraps-Fox 2.0 with CD adjuster, Rokmen lower links, rear swaybar delete, Savage skids, Hot Metal Fab Front Tube bumper, Savage Rear tube bumper, TruckShopSD Sliders, F/R DuroBumps, 285 BFG KO2, Doug Thorley Headers, Magnaflow Overland Catback, yellow top, XRC 12k, ARB single compressor.
4runnerfiend is offline   Reply With QuoteReply With Quote
Old 12-07-2020, 07:43 PM #4
You will have to use your original top hat. So you will have to either buy a new one or disassemble your old one and use that one. I'm pretty sure they are the same spring rate around 550. I did all the research at one point.
Old 12-08-2020, 06:48 PM #5
UnderFire's Avatar
UnderFire UnderFire is online now
UnderFire has a spectacular aura about UnderFire has a spectacular aura about UnderFire has a spectacular aura about
UnderFire's Avatar
They should work pretty well. Overall spring rate is likely similar with the free height of the 5th gen springs likely being a bit taller. Tundra 5100's would be my choice. Which notch you set them on would depend how tall you want it. Bottom notch would probably be around 1" taller than stock. If you didn't want to lift at all just use a factory style shock.
'97 3RZ 5 Speed "FrankenRunner" (Build Thread) - Dormant
The "shitmobile" 500$ 3RZ Auto 4Runner - (Saved from the Scrapyard: Resurrecting a 500$ 3rd Gen
02 Tacoma Double Cab, mid-travel, locked, armored, supercharged and riced. (Longbed and 5 speed in the works)
UnderFire is online now   Reply With QuoteReply With Quote
Old 12-09-2020, 12:51 AM #6
I wouldn't maybe a slight lift 1-2" but want it to ride comfortable on the street. I hardly ever take it offroad, 95% street driven. I looked at stock Tokicos but damn they are expensive for the front shocks. I have Tokicos on the rear but the price on rear shocks were really good.
Old 12-09-2020, 04:24 PM #7
Bilsteins are going to be a bit firmer than stock but should not be bad. I'd just get the 5100's for the 4runner and leave it at the stock setting with those springs and I'd imagine you will get 1"+.
Here is a thread to read thru. People have talked about this before
Solved: FJ Cruiser Spring Lift for 3rd Gen 4Runners
Old 12-09-2020, 08:22 PM #8
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
The KYBs are mentioned as a cheaper alternative to the OEM fronts. Esp for DD use.
I've got a set of the OEM 99 tokicos for the rear also but not put on yet, how do you like them?
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 11:48 AM #9
Ill look into the KYBs. Thanks for the advice on that. Yea don't want a really firm ride. The Tokicos with the 5th gen rear springs work well, I plan to add a trim packer to the rear for a bit extra height but the combo works good. Plus the rear Tokicos are super cheap compared to front shocks
bilstein , front , ride , shocks , springs
Who's running LC springs and Bilstein 5100 3rd gen shocks in the rear? calnhob 3rd gen T4Rs 8 10-12-2019 02:41 AM
FS: 3rd Gen '99 Stock front springs and Bilstein 5100 shocks - Los Angeles(LAX), CA 4xBear For Sale: Suspension/Wheels/Tires 4 11-29-2018 12:28 AM
Help: 2010 FJ Springs + 4runner Bilstein 5100's will it work? sbitter 4th Gen T4Rs 0 11-01-2017 06:54 PM
FS- Bilstein 5100 Front and Rear Shocks w/FJ Springs-NJ Scoward For Sale: Suspension/Wheels/Tires 4 08-22-2014 06:16 PM
Front Bilstein 5100 shocks, FJ Springs, And Daystar 1.5" Rear Spacers Installed -Pics man03999 4th Gen T4Rs 39 06-12-2010 11:03 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
