12-06-2020, 11:49 PM
Will the Tundra brake upgrade reduce 60-0 distance?
I am running a nearly stock 4runner. Biggest change my 16" stock wheels with crappy Toyo AT's for 18" off a (Tacoma or 4Runner? I can't remember) Premium with 265 wide Michelin LTX, remains at stock height.
With my bad Toyo's my 60 - 0 averaged ~145' and the ABS would kick on repeatedly during those runs every time. I haven't measured my 60-0 with the Michelin LTX, but the ABS doesn't kick on now. It definitely feels more controlled, not sure it is any shorter, though.
So curious if anyone with a Tundra brake upgrade bothered to measure their 60-0 before and after.
12-07-2020, 12:04 AM
The answer is, it depends. A perfectly functioning OEM system will engage the ABS on Dry Pavement at almost any speed. This tells me the tires are your limit until you start outfitting super soft racing tires. Big brakes can theoretically slow the wheels down faster, but it doesn't matter if the tires are garbage and cant grab the road.
So I would say no. The benefit of the Tundra brakes is that the larger rotors/pad area allows the heat to spread out and prevents the rotors from overheating during harder braking. You may notice a descreased stopping distance after Multiple hard braking events, as the brakes would be cooler, and thus more effective at slowing the vehicle down.
The 4Runner Show
12-07-2020, 12:38 AM
Just to clarify, old tires (Toyo AT's) could easily break traction, either on acceleration or braking, but especially on braking. New tires (all-season highway Michelin LTX) I have never had break traction on pavement. Because of that, I was thinking the Tundra upgrade may help me at this point.
12-10-2020, 01:17 PM
Real Name: Reinout
Real Name: Reinout
I thought about the Tundra upgrade myself but have opted out. As you know, here in Washington, the roads tend to be a little slick at this time of the year and
@ shadow247
made a super valid point about the age of the tires being a big factor.
I'd recommend siping if anything to increase traction.
The ABS on our 3rd gen would go off if a mouse farted near it so to increase my control I did the "blue wire mod" to disable the ABS on the fly. I believe that the Tundra upgrade would only make the chance of breaking traction greater.
Look at WRC cars, they do not run big brakes (unless on tarmac) specifically so that they don't unnecessarily lose traction.
1997 4Runner SR5- ~376k Miles and counting - 5 Speed E-Locker
2007 4Runner Limited V6- 165k Miles - Automatic - Brake Controller
2011 VW JSW TDI- 130k Miles - 6 Speed - Air Lift 1000
2006 Scamp trailer 16'
12-10-2020, 02:45 PM
Real Name: Jerod
Real Name: Jerod
I can't specifically comment on 60-0 times as I have not measured them nor do I know how to do it accurately. But I agree completely about the age, tread style and tread compound comments. When I got my 4Runner it had a set of Cooper's on there that were garbage and I would go skidding into intersections in the rain on a frequent basis because the tires would slip and ABS kick in, not allowing me to stop. New H/T changed all that and it's rock solid on dry pavement and great in wet. ABS has never kicked in unless I hit a big pothole or speedbump.
After I did the TBU ABS has never kicked in either. Stopping power is increased as the bigger pads apply more pressure to the brakes with less brake fluid pressure. The ABS system is a balance of fluid pressure and ABS sensor input (tire slip). While I can't say for certain it would decrease 60-0 times or in my case, 100-0 times (tire choice really does matter much more here) in my real-world experience the brakes are stronger will less force needed on the pedal.
12-10-2020, 03:40 PM
Nobody has ever tested this. The cases where people say the TBU decreased stopping distance may have gotten the benefit from the friction material in their new pads and new rotors. The 231's MIGHT, but that caliper also messes with fluid displacement, so people might be claiming wild results from that due to a pedal that only grabs at the very bottom combined with a higher friction pad. Another determining factor is the size of your rear wheel cylinder.
Also 01-02 uses 4 channel ABS vs the 3 channel in 96-00.
With the 199 upgrade, my guess is no, it does not decrease stopping distance when compared side by side to stock larger brakes with the same type of pad and rotor.
12-10-2020, 04:07 PM
Honestly most vehicles should have e ought power to lock the wheels, aka abs kicks in, so more braking power won't help.
12-10-2020, 04:58 PM
I saw no noticeable improvement with just the calipers and rotors. Now, when I did the booster and MC? Holy poop. Combine that with soft AT's and no ABS and I can put your nose on the dash if I'm not paying attention. However, I'll concede I don't have hard data to back it up. But I don't see how it wouldn't be shorter. They grab hard. Like, stupid hard.
18 Audi A6 3.0T - APR Tuned, RS6 Interior 19 Audi A6 3.0T
12-10-2020, 05:04 PM
Do you mean just a new OEM booster and MC or is there a mod to change to a different booster and MC?
12-10-2020, 05:07 PM
I stepped up to a T100 booster and Master. Bumps you up from a 9 3/4 to a 10.5 booster and a 1 inch bore to 1 1/16.
12-10-2020, 07:34 PM
Interesting
How did it fit up?
12-10-2020, 09:37 PM
Originally Posted by jross20
Interesting
How did it fit up?
Build thread is in my sig. Direct bolt on, had to bend the lines a bit.
12-11-2020, 01:19 AM
Real Name: Evan
Real Name: Evan
Yes your braking distance is reduced with the TBU, given the road is dry and your tires aren’t complete shit.
Measuring Stopping Distance of a Toyota Tacoma with Tundra brakes - YouTube
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
12-11-2020, 11:39 AM
Real Name: Patrick
Real Name: Patrick
Did you ABS delete because of the T100 master not working well with the ABS system?
12-11-2020, 02:36 PM
I would also say that apart from a possibly shorter stopping distance, another benefit of greater swept area is an increase in heat dissipation. Which reduces its chances of overheating. Overheated brakes can cause a spongy brake feel with increased stopping distance.
This is most common when going downhill on a mountain road, esp if you're loaded with gear and armor. You can alleviate that by using engine braking and minimizing the use of your brakes, of course. Or pulling over every now and then to let it cool down if you are riding it.
2000 Limited V6 4WD | Factory Locker | 2nd Gen SC | NGK Spark Plug Wires | AEM Boost/AFM Gauges | Scangauge II | Sonoran Steel 1.2 Lift/Washer Reservoir | AirLift Rear Airbags/Wireless Compressor | 4XInnovations Front/Rear Bumpers | Schrockworks Skid Plates/Sliders | Warn 12k LBS Winch-Synline | LED Halo Driving Lights | LED "Satoshi Cover" Lightbar | Thermal IR Cam | BFG All-Terrain KO2 | Kenwood with Sirius/Garmin Nav and Surround-View Cam | Heated Seats | Lumbar Support | Blacked out Emblems TRD Badge | Rear Diff Breather Extension | LED Taillights | LED 6k Headlights | 120V Power Socket | Flipped Hood and Fuel Release | Rear Window Switch in Cargo Area | Custom FlipBlade Key | Warm White LEDs
