Old 12-09-2020, 03:46 PM #16
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
My apologies for being an ass, over the past 12 years I've changed 3 pumps for people and just ordered a PS pump at the corner parts store and never requested a reservoir and all three came with them, and thought surely a shop wouldn't want to fiddle with swapping a reservoir over 3 times let alone never looking inside of it in the process when all 3 pump where loud, but your right, I guess its a possibility..
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 12-09-2020, 09:02 PM #17
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
It's ok. We all have bad days. Mostly the vane pumps are cheaper without the reservoirs.
I priced an OEM vane pump once. Then I just find good used ones. OEM for whatever reason seem to be the most quiet.
Old 12-10-2020, 03:48 PM #18
JasonDoyle JasonDoyle is offline
JasonDoyle is on a distinguished road
Alright everyone. Just wanted to say thanks for all of the great suggestions and (thanks to your help) to let y'all know the problem has been fixed.
As it turns out, when the power steering first started to make some noise, I thought I'd replace the fluid myself so I took an extraction pump and sucked out all of the old fluid. I remember that when I did so, the hose seemed to hesitate at what I'd have to guess was the bottom of the reservoir, but that I could actually get the hose to go down even lower than that if I forced it a little. I figured 'great. I'll be able to get even more of the old fluid out if I get the hose down as low as possible.' Well, as it turns out, I somehow managed to damage and dislodge the screen in the reservoir. When my mechanic replaced the pump, he did not replace the reservoir an instead, just reused the original. This meant that no matter how many times he replaced the pump, the problem remained.
When I took it back to him this last time, I asked if he had looked at the reservoir when he replaced the pump and he said he hadn't. Needless to say, when he drained the fluid and stuck a borescope in the reservoir, he could see that the screen was displaced and restricting flow from the reservoir.
So, long story short, I somehow displaced/broke the screen in the reservoir and once a new reservoir was installed, problem solved.
There's not doubt in my mind that if I hadn't forwarded y'alls suggestions to my mechanic, I would still be wrestling with this problem so I again want to extend my heartfelt gratitude to everyone who took the time to offer their suggestions. Couldn't have done with out this communities help.
Cheers all!
JasonDoyle is offline   Reply With QuoteReply With Quote
Old 12-10-2020, 09:39 PM #19
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Glad to see it fixed.
made , power , pump , rack , replaced
power steering issue. 01thunder 3rd gen T4Rs 5 01-22-2016 11:15 PM
1st gen power steering issue Dibs01 Classic T4Rs 10 12-13-2014 09:04 AM
Power steering issue Kenworth 3rd gen T4Rs 6 11-27-2014 05:46 PM
Power Steering Issue SR587 Classic T4Rs 8 02-15-2014 01:50 PM
Power steering issue 93runnerguy Classic T4Rs 16 10-04-2011 09:51 PM
