Old 07-18-2021, 04:45 PM #1
giguchan's Avatar
giguchan giguchan is offline
giguchan will become famous soon enough
giguchan's Avatar
Lost ma Brakes today
Driving along at 65 and then nothing.. pedal to the floor. Saw a giant splash of fluid on the inside driver side wheel. More to come.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
giguchan is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 05:26 PM #2
cl4Rk's Avatar
cl4Rk cl4Rk is offline
cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold cl4Rk is a splendid one to behold
cl4Rk's Avatar
Whoah!!
2000 SR-5 V6 4x4 Auto
"Ol' Ruby" - build thread
@Y2K_4X4
cl4Rk is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 09:07 PM #3
RotaryDreamz's Avatar
RotaryDreamz RotaryDreamz is offline
Real Name: Sean
RotaryDreamz will become famous soon enough
Real Name: Sean
That sounds scary. Assuming you were able to stop without an accident I hope. Busted brake line?
RotaryDreamz is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 09:12 PM #4
Sparky 97Runner's Avatar
Sparky 97Runner Sparky 97Runner is offline
Sparky 97Runner will become famous soon enough Sparky 97Runner will become famous soon enough
Wow! Thank god for a properly adjusted e-brake.
1997 Toyota 4Runner
Sparky 97Runner is offline   Reply With QuoteReply With Quote
Old 07-18-2021, 09:24 PM #5
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
^^^And properly using it! Too hard while too fast will make you flip like no other
Old 07-19-2021, 01:02 AM #6
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I remember when my front brake line off the little 06 Civic bursted and lost all brakes! My master cylinder needed to be replaced due to pumping and running it bone dry which ruined the inner seals. Gook luck and glad you're ok!
2000 4Runner Limited 4x4 V6
Old 07-19-2021, 02:25 PM #7
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I wish that was a problem with my parking brake. I can't even lock the rear up when it rains. I've replaced both bell cranks and adjusted them per the FSM, verified both cables move correctly, adjusted the hand brake, and my rear drums are adjusted correctly as well. Worst parking brake I've ever had in a vehicle.
Old 07-19-2021, 02:37 PM #8
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
It's good to know I'm not the only person who has completely rebuilt their rear brakes and still can't get the parking brake to do much of anything.
Skulking is offline   Reply With QuoteReply With Quote
Old 07-19-2021, 11:23 PM #9
pluton's Avatar
pluton pluton is offline
Real Name: Keith
pluton has a spectacular aura about pluton has a spectacular aura about pluton has a spectacular aura about
pluton's Avatar
Real Name: Keith
Following advice found in this forum, I occasionally use the P-brake to bring the car to a stop (low speed normal driving). The rear brakes seem to in the best possible adjustment after doing this. Of course, 'best possible' for the P-brake on a 3rd gen 4Runner is not saying much.
pluton is offline   Reply With QuoteReply With Quote
Old 07-20-2021, 12:29 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Ha, especially when you use the parking brake on a steep hill and you feel the vehicle slowing slipping backwards anyway...
326WHP 347TQ
Old 07-20-2021, 07:01 PM #11
diverscale's Avatar
diverscale diverscale is offline
diverscale will become famous soon enough
diverscale's Avatar
The small, short part of curved brake line that is connected to the calipers/brake drums, gets very rusty and thin on these older cars. I would not be surprised this is the part that failed. Hope you give us news about the failure mode.
I think more of use should have a look at them. I've absolutely got to replace mine for sure next time I'm working on brakes. All my lines look pristine but these ends. And very easy to do with the copper/nickel brown lines, which you can bend by hand, and they don't rust anymore.
1998 4runner SR5
diverscale is offline   Reply With QuoteReply With Quote
Old 07-21-2021, 01:57 PM #12
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
This is why I am glad my state has state inspections as things like this are mostly caught annually when the vehicle is checked for safety. Brake lines rust out here. when they get really rusty mostly they are changed before failure to prevent things like this from happening.
Glad nobody was injured on the break loss
driver , inside , lost , side , wheel
lost my brakes! Hapeacres 4th Gen T4Rs 4 08-11-2019 12:24 PM
So I almost got raped by the Dealer today....brakes brakes brakes. DizzyV6P 5th gen T4Rs 36 04-28-2015 11:23 PM
I lost my man-card today, but... buchaja 5th gen T4Rs 14 04-14-2014 01:45 PM
Today was a sad day.. TO ALL THOSE who ever lost their keys.. awpsome 3rd gen T4Rs 27 10-29-2012 12:51 PM
Lost Power today !!! KoNEJO 4th Gen T4Rs 14 12-15-2010 10:36 PM
