Old 12-26-2020, 10:05 PM #46
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Try Felpro 61087. I used it on an IAC cleaning on a Tacoma years ago and no problems as of last year.
How dirty was the throttle body?
Grab a MAF as well if you make it back to the junkyard again........
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-26-2020, 11:17 PM #47
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
If you do plan to replace the o2 sensors, Denso and Genuine Toyota is the way to go. Sometimes Genuine parts can come out cheaper than Denso. I've had my truck since 2014 and both o2 sensors have never been changed (there is no record of replacement).
2000 4Runner Limited 4x4 V6
Old 12-28-2020, 02:11 PM #48
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Holy crud Batman! That IAC needs a proper cleaning, or replacing. I don't think it will cure your P0172 but you should get better idle quality. I had to bite the bullet and get a new one recently since my was toast beyond the point of cleaning.
326WHP 347TQ
Old 12-28-2020, 02:49 PM #49
Most manufactures don’t mount the IAC right under the throttle plate where dirt and debris can collect.
Old 12-28-2020, 10:52 PM #50
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
Well I had to pull the intake looking for an oil leak. I guess I could replace the fuel regulator.
Bucket81 is offline   Reply With QuoteReply With Quote
Old 12-29-2020, 11:31 AM #51
That’s expensive but you are there anyway
Old 12-31-2020, 02:05 PM #52
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
Well, that didn't fix it...
I did not replace the fuel regulator. And still no check engine light...
I guess I'll start throwing parts at it....
I have a 99 single cat 4WD Auto is this the right O2? 234-4162 It looks like up and downstream are the same.
Shared album - Christopher Backen - Google Photos
Is this the right MAF?
Amazon.com: Denso 197-6020 Mass Air Flow Sensor, Regular: Automotive
Old 12-31-2020, 04:17 PM #53
I am hoping your 4Runner now idles around 700rpms give or take.
I would start with replacing the oxygen sensors. After 20+ years they are bound to be on their last leg. And that is the correct Denso number. Mike replaced his oxygen sensors concerning a PO172 and it fixed it though you don’t have that code anymore:
P0171 - System Too Lean Bank 1
Others have used that specific Denso MAF with success though Amazon says it isn’t a fit...
Old 01-01-2021, 09:11 AM #54
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
No still ideals around 1000 RPM...
Old 01-02-2021, 07:55 AM #55
As dirty as your IAC was it may be past the point of where a thorough cleaning will bring it back to factory spec.
However, if your throttle body has a shifting linkage, look into this:
My High Idle CURED!!!
Old 01-07-2021, 12:01 PM #56
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
You think it's supposed to move like that... I don't.
TB play - YouTube
Edit: well would it matter at WOT? I wounder if it could be effecting the TPS.
Old 01-07-2021, 03:00 PM #57
Nope, not at all.
Old 01-07-2021, 03:28 PM #58
Bucket81's Avatar
Real Name: chris
Bucket81's Avatar
Real Name: chris
O2 sensors didn't change anything.... And I cleaned the MAF again and no CEL.
Could it be timing? If it was wouldn't I get a CEL?
edit: I noticed it is affected by temperature. So when its cold it doesn't start breaking up tell it hits a higher RPM.
Old 01-07-2021, 04:29 PM #59
Concerning the TPS, use the live data app gradually increase the throttle up to 3500 or so and make sure there is a linear curve it follows for values.
I hope someone else will post their MAF value at idle, operating temp.
No, not timing.
Original alternator?
Old 01-07-2021, 06:52 PM #60
No, not timing.
I posted my MAF readings in the too lean thread.
ended , fuel , injectors , p0172 , thing
Upgrading Fuel System, Fuel Injectors, and Spark plugs! rhearne27 Engines / Suspension / Wheels / Tires / Audio / Accessories 7 03-26-2020 01:40 PM
Smoke after chaging injectors, P0172 AndreiR 3rd gen T4Rs 13 03-19-2015 02:28 AM
Fuel Injectors..... Ol'Blue 3rd gen T4Rs 8 09-06-2014 03:24 PM
3rd gen fuel injectors (4 of them) BeauJo Free 1 06-22-2013 06:36 PM
3.4L Fuel Injectors and Fuel Rail - Qty of 5 Injectors STRRAYNGE For Sale: T4R Items 24 09-20-2012 08:07 AM
