Originally Posted by gamefreakgc
Aisin didn't make injectors for Toyotas, they are all made by DENSO. It's possible you got aftermarket knock offs. How much did you pay for them?
My apologies, just saw this..
You're correct, not Aisin, I just assumed...
$70 for the pack
ENA 2 Hole Fuel Injector 23250-62040
Pack of 6 Compatible with 1999-2004
Toyota 4Runner Tacoma Tundra 3.4L V6
There might have been a bad one in there...
Just because I'm at 300K/mi. and It's only a couple of hundred in parts and good peace of mind, I replaced:
Plugs and wires (recommended NGK and Denso)
I replaced both upstream (A/F) and downstream (O2) sensors with Denso parts from Camelback
New Fuel Pressure Regulator from Camelback
I swapped in a junkyard MAF (same part #) and it threw a P1133 code, swapped back to my original and the P0172 returned
Found my carbon canister had a HUGE crack in it, replaced that with a used on I had. I'll take some datalogs off Torque Pro tomorrow..
And of course I cheaped out on the injectors
