Old 07-22-2021, 10:28 PM #46
CRB Racing CRB Racing is offline
CRB Racing has a spectacular aura about CRB Racing has a spectacular aura about
These Front Range Off Road Rear arms are no joke!
CRB Racing is offline   Reply With QuoteReply With Quote
Old 07-22-2021, 10:29 PM #47
Old 07-23-2021, 12:19 AM #48
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Originally Posted by CRB Racing View Post
Installed the Total Chaos coil bucket gussets today and touched up the frame.
What paint did you use? Love the shade
Old 07-23-2021, 02:49 AM #49
CRB Racing Build 2.0
I swear by this stuff! You can lay it on and it doesn’t run easily.
Old 07-25-2021, 02:26 AM #50
New steering rack check.
Old 07-25-2021, 02:28 AM #51
On to the rear!
Old 07-25-2021, 04:53 PM #52
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
they are beefy, I also have a set of FROR rears. wondering if you have installed them yet? did you have to clearance the lower arm axle assembly brackets?
my only complaint about their links is the lower joints are maybe just a bit overkill?
I have had the track link for a couple years now and it's been trouble free. they make good stuff.
Old 07-25-2021, 05:43 PM #53
Dezert4Runner's Avatar
Dezert4Runner Dezert4Runner is offline
Real Name: Evan
Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about Dezert4Runner has a spectacular aura about
Real Name: Evan
I’ve had the FROR lowers for about a year. The lower link bracket had to be clearanced on install. It would have been nice to know before hand but nothing an angle grinder can’t fix. The heims on mine made noise right off the bat but I’ve learned that Tri-Flow is your friend! The links are great though, I’m sure you’ll like them.
2000 Black Sport 4WD 5spd -JD Fabrication long travel/ Fox 2.5 8” RR/ Anonymous Fab lower uniball• McNeil Racing fenders • Toytec Superflex/ 5th gen Bilstein 5100/ Wheelers Superbumps • 315/70/17 BFG KO2 on Robby Gordon wheels • 231mm TBU / Wheelers SS lines • MStudt rear swaybar links • Tom Woods driveshaft • Satoshi • K&N FIPK w/ AFE dry filter • Borla Pro XS • URD short throw shifter & Ellis Precision shift knobs • Uniden PRO 520XL & 3' Firefly on custom mount• Prinsu full rack • Baja Designs Squadron Sport Sae & combo beam lights • Paranoid Fab switch panel with Ram mounts • Extended rear diff breather • 01-02 tail lights • Stubbs HD-SKO sliders • Any 7 Offroad gas tank skid • @Assburns custom tube front bumper • Nguyen Works swing out bumper • FROR rear links
Dezert4Runner is offline   Reply With QuoteReply With Quote
Old 07-26-2021, 04:11 AM #54
I haven’t installed them yet. I was planning on doing it tomorrow. Do you have any pics of how you needed to clearance them mount?
I was planning on ordering an upper and lower mount kit from Eimkeith. I wonder if his mounts will still work with these arms.
Old 07-26-2021, 11:24 AM #55
Real Name: Evan
Real Name: Evan
No photos, but maybe I can grab one later this afternoon. It rained early this morning for once here in Socal, so it’s too wet to slide under the rig at the moment. I took off 1/4” - 3/8” off the plated part on the backside of the mount.
Old 07-26-2021, 08:14 PM #56
Real Name: Evan
Real Name: Evan
Here’s a couple photos. First two are drivers side. There’s 1/4” from the factory hole in the bracket to the cut part. Still appearing to touch the bracket on the driver’s side judging from the scratch marks on the rod end. Make sure to use Cross Check or a paint pen on the large nuts once your rod ends are tightened down. Those little bastards like to come loose from time to time.
CRB Racing Build 2.0-a6ff51f6-5181-40c8-b05e-738e31f5e441-jpeg  CRB Racing Build 2.0-87ede120-2e89-473a-8ca8-42940b2e8c77-jpeg  CRB Racing Build 2.0-deba5831-fdd3-40e6-b211-c2bf3873ec79-jpeg
Old 07-27-2021, 03:36 AM #57
Thanks for the pictures and the pointer!
Do you thing that cutting off a part of the mount has weakened it any?
Old 07-27-2021, 04:15 AM #58
Real Name: Evan
Real Name: Evan
I doubt it. There’s plenty of metal still holding those mounting tabs stable.
Old 08-05-2021, 12:13 AM #59
If Tundra brakes are good, then 5th Gen T4R brakes must be better!
Old 08-05-2021, 10:36 AM #60
TW44LR's Avatar
TW44LR TW44LR is offline
TW44LR will become famous soon enough
TW44LR's Avatar
Interested to hear your thoughts on this mod!
TW44LR is offline   Reply With QuoteReply With Quote
comfortable , crb , guy , lift , road
Steel City Racing: King of the Hammers 2019 Toyota 4Runner IFS 4600 Build Thread Charles4x4 4th Gen T4Rs 425 02-03-2022 04:34 PM
Mud bog racing? raty4R Texas & Oklahoma 0 11-20-2019 04:48 PM
CRB Racing's 2000 4Runner Build CRB Racing 3rd gen T4Rs 32 07-12-2018 11:17 AM
2005 Toyota 4Runner SR5 4WD ***Fox Racing, Demello, Method Racing*** The Giz For Sale: Vehicles 18 09-14-2016 06:41 PM
