Old 11-17-2009, 11:06 PM #1
3G_runner 3G_runner is offline
3G_runner is on a distinguished road
Engine smoking somewhere
Need some help about smoking from engine. I have a 3.4 v6. I cant really pin point where exactly the smoke is coming from, but its the back of the engine, towards the bottom on the driver side. The heat shield is blocking the manifold when im under scoping it out so cant really tell. Any suggestions. Rides fine and dont think it's burning oil. But i can smell and see the smoke when the engine is hot. Color of the smoke like steam but smells like burning oil or rubber like.
3G_runner is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 11:07 PM #2
JohnsD90's Avatar
JohnsD90 JohnsD90 is offline
JohnsD90 will become famous soon enough
JohnsD90's Avatar
make sure the cap is on all of the engine fluids.
JohnsD90 is offline   Reply With QuoteReply With Quote
Old 11-17-2009, 11:49 PM #3
shawnstcyr's Avatar
shawnstcyr shawnstcyr is offline
shawnstcyr is on a distinguished road
shawnstcyr's Avatar
Sounds like leaky valve cover gaskets.
'99 "Big Boy" 4Runner SR5 4wd
ARB Bumper/ SmittyBuilt winch/ Hella 500's, Roof Rack,Deck plate Mod/ ISR mod/ TRD "O" TB gasket/ K&N air, FlowMaster,3" Toytec front, OME 851 LC 2" lift coils rear, extended length LC shocks rear, diff drop, Toytec brake line extension, Definity Dakota M/T LT265/75/16 tires,Lowrance GPS, Kenwood head unit, Sony Xplode 4 channel 800 watt amp, rear Stealth speaker box w/ 10" JL sub, backlit Inclinometer, Cobra 19 CB, TRD Off Road decals
shawnstcyr is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 12:38 AM #4
CaliCal's Avatar
CaliCal CaliCal is offline
CaliCal is on a distinguished road
CaliCal's Avatar
changed any fluids earlier ?
CaliCal is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 11:47 AM #5
Cambo's Avatar
Cambo Cambo is offline
Cambo is on a distinguished road
Cambo's Avatar
Definitely valve cover gaskets. I have the same thing on the passenger side and I can see it is the oil leaking down from the valve cover onto the exhaust manifold.
1997 4Runner E-locked & Lifted on 35's
Cambo is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 12:38 PM #6
longhaul747 longhaul747 is offline
longhaul747 is an unknown quantity at this point
As already mentioned above most likely the valve cover gaskets. Mine leaked and sometimes I could smell something burning. Never seen smoke under the hood but I am sure it did at times. Normally its not difficult but you have to remove the throttle body and replace a gasket for that. So I had the dealer replace mine to the tune of $400. At the least they steamed cleaned the engine as well ;-)
longhaul747 is offline   Reply With QuoteReply With Quote
Old 11-18-2009, 02:05 PM #7
rdgt4r's Avatar
rdgt4r rdgt4r is offline
rdgt4r is on a distinguished road
rdgt4r's Avatar
its easy to do yourself except for the driver side because of the intake but its all just unbolting a few things and slap some new gaskets for around 30 bucks.
rdgt4r is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 11:04 AM #8
andyo andyo is offline
andyo is on a distinguished road
Header/Downpipe smoke
My 2001 SR5 had become our 3rd vehicle about 5 months ago. I've been starting/driving it once a week since then to keep it running. Over the past 2 weeks I've noticed, that once the engine gets up to temp, I'll smell something burning.
A quick inspection with the hood up showed that where the header meets the downpipe, there was a small stream of white smoke rising through the engine bay. This only happens when the car is up to temp and only smokes in that spot.
Any ideas what this could be? It doesn't really smell like oil, if anything it almost smelled electrical. Not saying that it is, but it doesn't smell like an exhaust leak either.
My photo didn't turn out, but this photo of a Tacoma engine bay is pretty close to the area I'm talking about: .
In the photo, it'd be under and to the left of the ABS module (top-right - has the white reservoir and black cap).
andyo is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 11:33 AM #9
thezentree's Avatar
thezentree thezentree is offline
Real Name: Robert');DROP TABLE Students;
thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough thezentree is a jewel in the rough
thezentree's Avatar
I'm no expert on these engines but white smoke is usually indicative of burning coolant. I hope I'm not leading you down the wrong path but it's worth investigating.
2001 SR5 - Like OEM, only worse (gears, e-locker, armor)
thezentree is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 11:55 AM #10
It's so weird b/c it's such a localized area that the smoke is coming from. Doesn't come from the tail pipe, just the engine bay at that joint.
Checking the coolant level is easy enough.
Old 01-23-2018, 01:16 PM #11
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Use a mirror and a flashlight and see if you can get a better look at where the leak is coming from. Checking your coolant level and oil level is a good start too.
It could be as simple as the valve cover gaskets are leaking. Mine have been for quite a while now and it smells more like burning rubber than oil. They leak pretty bad on mine but I still don't need to add any oil between changes.
Super common for the 3.4 V6 to have leaking valve cover gaskets (cam seals/half moons).
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 01:34 PM #12
Scramble's Avatar
Scramble Scramble is offline
Real Name: Scramble
Scramble has a spectacular aura about Scramble has a spectacular aura about
Scramble's Avatar
Real Name: Scramble
I agree with thegipper, valve cover gaskets. The oil drips down onto the exhaust when the truck is sitting & then burns off when up to temp. Smells like burning plastic or rubber. When I'm DD her I dont get the smell or smoke at all, only after sitting for a week.
____________
'99 4Runner - 2.7L 3RZ, 5 Speed, 4.56 Gears - Lifted, Locked & Loaded - 166k Original owner - http://www.toyota-4runner.org/3rd-ge...ld-thread.html
'99 Limited - E-Locker- Stock (for now) - 233k 2nd Owner http://www.toyota-4runner.org/3rd-ge...ted-build.html
Scramble is offline   Reply With QuoteReply With Quote
Old 01-23-2018, 01:35 PM #13
I can see that it's coming right off of the flange where the header meets the pipe. It's just a think stream of white smoke and I don't see anything dripping on it that would be burning. It's pretty rusty too. Could that mixed with the car not being used as much making it start to go? Use it or lose it?
Thanks for the reply gipper.
Old 01-23-2018, 01:38 PM #14
OK that makes me feel much better. I was worried that if something was smoking like that I shouldn't be driving it. Where there's smoke there's fire.
Thanks for the reply Scramble.
Old 01-23-2018, 01:54 PM #15
Scramble's Avatar
Real Name: Scramble
Scramble's Avatar
Real Name: Scramble
Well please make sure that's it! LOL
____________
