Old 12-15-2020, 11:53 AM #16
Traveler74 Traveler74 is offline
Traveler74 is on a distinguished road
Originally Posted by 19963.4lsr5 View Post
You can’t rely on tape to seal off the crack in your intake tube.
You need to replace the tube. Or seal it with RTV. Not tape. This could be why your engine dies after a few min of running. Your engine will not run is the correct airflow is not flowing through the MAF sensor.
Read post voltage at the battery when you try and start it. If it doesn’t drop into the low 11v or lower range trying to turn over the engine you have a bad starter and need to replace it or the contacts inside it.
That click/clunk I hear when I try to start the engine, is that the solenoid ? Does that tell you the solenoid is working ? PS: when I try to start it the 2nd time I do NOT hear any click/clunk.
Traveler74 is offline   Reply With QuoteReply With Quote
engine , flush , running , truck , turn
2007 SR5 checking engine, VSC TRAC, Slip light are on during drive. sunnyside Problems & Warranty Issues 6 09-19-2020 08:25 PM
Tranny siezed? TABrecke 3rd gen T4Rs 15 07-28-2016 02:04 PM
LCA cams siezed, need help ARC 3rd gen T4Rs 7 10-26-2014 11:58 PM
Need help rear end siezed mschein1 3rd gen T4Rs 12 07-23-2014 10:02 AM
Checking engine oil level chunderboy 4th Gen T4Rs 6 11-10-2005 12:52 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
