The bellcrank arm is made of steel, the pivot that bolts to the backing plate is aluminum,.. They don't get along well at all and corrode easily. Disconnect ebrake cable and take the pivot pin out that joins the 2 offending metals, it will most likely need persuasion or even a c-clamp and hammer to press/knock it out, clean them both up lube and reassemble and adjust brake shoes so the bellcrank is a mm off the backing plate after pulling the ebrake a few times to set final adjustments, I find adjusting the brakes so the drum is a bugger to get on puts it close to it range that a few ebrake pulls sets it within spec after adjusting the bell crank adjuster bolt.
