I'm not a fan of using plumber drain piping for intakes, I think it looks terrible, cheap and out of place even on ATV's/UTV's, and that white pvc sewer drain pipe is pretty thin and cracks when cold, maybe he painted it white to match the truck though? Looking again it appears to be abs painted white, so you'd be better off with black abs pipe if you go that route IMO. I also think at high speeds that pcv pipe will see a vacuum due to the Venturi effect not that it would effect much in reality, whereas pointed forward would give you a ram air effect like the snorkels. But it's all about preference and performance so whatever works.
