02-27-2008, 08:27 AM
97' rear washer not working
on my 97' the rear window washer doesn't work. no fluid comes out at all. where should i start looking for the problem? the wiper works fine as well as the defroster. just the fluid doesn't come out.
02-27-2008, 09:59 AM
Super Moderator
Super Moderator
Can you hear the motor for the sprayer working?
2010 Lexus RX350
'99 4RUNNER Highlander SR5 4wd *Sold
02-27-2008, 11:20 AM
didn't check that yet. just noticed this last night.
02-27-2008, 03:59 PM
Super Moderator
Super Moderator
You aren't just low on fluid are you? I know it sounds stupid but the rear washer will stop flowing while the fronts will work as a warning that you are low on fluid. I just found this out recently.
Fill it to the brim and let us know.
2010 Lexus RX350
02-28-2008, 08:24 AM
thats the first thing i did. i filled that sucker right up.
02-29-2008, 12:28 AM
i've got the same problem. i can hear the rear fluid motor run, but no fluid comes out. I recently got the whole back portion of the car (rear window, breaklight, wiper etc) re-wired form the stealership, but they conveniently forgot to fix my rear fluid sprayer.
Its definitely not low on fluid. not sure what it could be. i didnt wanna start poking at it in fear of clogging it further if that is in fact the problem.
02-29-2008, 03:27 PM
Location: Garden Grove, Orange County----Outer Sunset, San Francisco------Madrid, Spain
one time i sprayed the rear window, and nada....i was in my driveway while doing this, and i got out to see what the problem was, and to my surprise, there was a huge puddle of water on the driveway behind my rig. i checked the nozzle, and it looked like it was about to pop off. all i had to do was push it back on. This has happened a couple of times, does anyone know why could cause it to "pop" off?
2000 Limited 4wd Dersert Dune Metallic Silver
Future Mods in Mind:
Navigation System
Lift
Tires
HIDs
LEDs (interior and exterior)
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
02-29-2008, 08:44 PM
Also, this may sound stupid but I have been guilty of this before, the wiper will only work if the rear window is all the way up, and I mean all the way up. Or there maybe could be a clog in the nozzle also.
'02 Limited 4WD
Stuff:OME 3"|ARB Tacoma|Light Racing UCA's|Savage KO sliders|285/75 Terra Grapplers|TRD catback|TRD wires|Brembo'd|VVME 4300K HID|LightForce 170|Exterior LEDs||Inside: Infinity Comps/Kicker/Nuvi625WT|Uniden 520XL|15% tint|Full LED swap|Backup camera
Pending Install:LC80 wheels,OME 883 and LC 8 wraps,panhard drop
03-02-2008, 04:16 AM
speaking of washer nozzles... do you guys know any way to get any more pizzazz out my "sprayer"? Mine when activated just kinda dribbles the fluid out... did it since i stole it from the lot. I've check for leaks- nothing perhaps i just got a bad nozzle head.
Magnaflow, Rigid D Series 4" 50231/Rigid E Series 20" 12231 LED Bar ,K&N FIPK,3"Toytec ultimate, OEM 231MM brake upgrade, LED Interior upgrade,Bushwackers,Savage Rock Rails,Shock works front bumper,PERKINS NON PERFORMANCE REAR BUMPER 33'Duratracs,Kenwood DNX891HD JL Audio C5's
Currently 194K
Cheers
03-02-2008, 04:45 AM
does anyone know how to make the nozzles spray water instead of splash it? would i have to change the nozzle to a car's that does it, or can i tweak mine to do it? thanks for any help in advance guys.
Navigation System
Lift
Tires
HIDs
(\__/)
03-06-2008, 02:20 PM
I'm in the same boat. My rear nozzle has always just...lazily streamed fluid down the window instead of spraying it.
Anyone have any ideas?
01-09-2011, 06:32 PM
Where is the fuse for the rear washer motor? Mine has no power at the motor.
Steve M
1997 4Runner
155K and running strong!
09-23-2018, 10:59 AM
Reviving this thread. My rear sprayer decided to quit working. No noise from the motor. Anyone know where the fuse is or anything else I can check?
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
09-23-2018, 11:29 AM
Nevermind. Got it working.
Tapped on the motor with a screwdriver.... Lol
2011 Camry SE V6
09-07-2020, 11:20 PM
Reviving this thread. In a couple of weeks, I’ll be installing rear window molle panels. Since I will have the large side panel trim pieces removed, anything I should look for?
Mine works, but I also have the lazy streamed fluid flowing down the rear window. Figured if there was something behind the rear side panels, I could look for the issue while they are off.
2002 4Runner Sport Edition - 4WD auto / 3” lift / 33” tires
