Old 12-21-2020, 11:06 PM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Grounding Question
I've read a few of the grounding threads here but none seem to specifically answer these two questions.
1. Is the indicated point in my engine bay the EA grounding point from the diagram?
Grounding Question
Grounding Question
2. If I put a power distribution center somewhere around grounding point BJ (see image below, basically where the tool cubby is in the back), is there any benefit to running a grounding wire all the way back to the engine bay instead of using BJ, as it relates to audio noise?
I plan to put a very small powered sub in the back, but I keep reading about interference/noise in the audio system from poor grounding. Someone recommended running a ground straight back to the battery to clean it up, but no one validated the recommendation.
The TLDR of question #2 is really, "are certain grounding points in our trucks superior to others when it comes to reducing audio system noise?"
Grounding Question
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 12:06 AM #2
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
The body is grounded to the truck frame in several places. When I installed my amp, I used an existing interior bolt and just ground the paint down where the terminal touched the body. Works like a charm and have had no issues with any installs in 20 years doing it this way....
I have never in my life seen anyone run a ground directly to the battery, even the competition car audio guys will ground to the frame and then ground their system directly to the frame.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 12:46 AM #3
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
The entire body is grounded. As Toyota uses negative ground chassis just almost all vehicles are negative grounded.
Those bolts if clean will work for grounds. If ever any doubt on a ground. Put a Meter in continuity mode and a lead to a known ground and the other on your lead and if it beeps you have a ground.
Old 12-22-2020, 05:46 PM #4
It should be just fine to ground to any body bolt location. If you have problems with noise, attack the 'signal' side first (RCA routing, etc.). Likely to be just fine though.
Oh, and that engine bay ground point is likely behind/below the modules pictured there.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 12-23-2020, 11:19 AM #5
G_Raw's Avatar
G_Raw G_Raw is offline
G_Raw has a spectacular aura about G_Raw has a spectacular aura about
G_Raw's Avatar
As all have confirmed I can also say body ground is fine. I have a small powered sub under passenger seat using a body ground. Also like others sanded through paint to clean up contact surface. No issues with interference.
99 Limited: 4wd conversion, OME 883/891, Built Right UCAs, Armored and winch up front, 285's with 4.88s and dual locked.
G_Raw is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 01:17 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
+1 with Phattyduck.. EA would be below that look underneath that lip for the white wires with black strip. :-)
audio , back , grounding , point , question
Amp wiring question - polarity and grounding Millerrh 5th gen T4Rs 3 05-27-2017 08:05 PM
Electrical grounding question... MadeInMaine 5th gen T4Rs 22 01-26-2017 11:14 AM
Grounding second battery question JSparky 5th gen T4Rs 8 11-28-2016 05:01 PM
Head unit install - grounding question Brique 3rd gen T4Rs 5 12-04-2014 11:52 PM
Cb antenna grounding question Robmills72 Engines / Suspension / Wheels / Tires / Audio / Accessories 15 05-21-2013 09:29 PM
