Old 12-27-2020, 06:06 PM #16
rickashay's Avatar
rickashay rickashay is offline
Real Name: Addison
rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold rickashay is a splendid one to behold
rickashay's Avatar
Real Name: Addison
Great post, bookmarked for future use and +1 vote for a sticky.
rickashay is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 04:11 AM #17
Doc3g Doc3g is offline
Doc3g will become famous soon enough
I added a few more bulbs to the list. I found out the hard way that VLED's lists the map lights as 3175, which they are not (though this is the correct bulb for the dome and rear cargo light). The correct map light bulb on the VLED site is listed under #57, which will bring up the BA(S base, which is the correct bulb (2 needed).
Also, as a heads up, VLED's is currently having a 20% off everything sale for the new year.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 12:05 AM #18
LS-4Runner LS-4Runner is offline
LS-4Runner is on a distinguished road
Great info, thank you for sharing.
LS-4Runner is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 02:38 AM #19
Devbot's Avatar
Devbot Devbot is offline
Real Name: Devan
Devbot's Avatar
Real Name: Devan
well wouldn't you know it, one of my buddies lives a stones throw from where vled is. Small world eh
Just curious, what color is that white? 5000k?
Old 01-02-2021, 03:23 AM #20
Niteghost Niteghost is offline
Real Name: Ty
Niteghost is on a distinguished road
Real Name: Ty
Thanks for putting this together. When installing the bulbs for the instrument cluster, which direction does the polarity go? If looking at the back where the bulbs go is the positive to the left or right?
2002 4Runner Sport -->Build Thread <--
2017 4Runner TRD ORP
2002 Toyota 4Runner - Sold
Niteghost is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 04:00 PM #21
raKnizek's Avatar
raKnizek raKnizek is offline
Real Name: Alex
raKnizek will become famous soon enough
raKnizek's Avatar
Real Name: Alex
Thank you for this! I need to redo mine (again) in hopes to get rid of the hot spots I have in the gauges and climate controls.
2000 SR5 3.4, Manual, 4x4
Icon 2.5 extended coilovers & 2.0 rear, JBA UCAs
265/75R16 General Grabber X3 on LC80s
Full Skid Plates
raKnizek is offline   Reply With QuoteReply With Quote
Old 01-02-2021, 08:40 PM #22
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Ordered my 30-somethin VLEDs today - puttin my faith in you!
Old 01-03-2021, 01:33 PM #23
raKnizek's Avatar
Real Name: Alex
raKnizek's Avatar
Real Name: Alex
Ordered some VLED bulbs for my gauges and climate to hopefully improve on the hot spots. FYI they are offering 20% for New Years
Full Skid Plates
Old 01-03-2021, 01:46 PM #24
Real Name: Ty
Real Name: Ty
Just did the same! OP should let VLEDS know he just sent them a ton of business.
Old 01-05-2021, 01:45 AM #25
My backlighting for the cluster is the 6000K white. It's not as blue as you are used to w/ cheap lights that say the are in the 6K range.
Well, depending on the manufacturer of the bulb, the polarity can be reversed. As far as what is positive vs negative in the bulb holder, from my pictures, it would be positive on the side w/ the "V" and negative on the side with the "2." However, it is so much easier to just grab any 12-volt power source and a set of alligator clips and check that the bulb works in the holder before installing.
You can get a 6 pack of 12V barrel batteries for $6 on amazon, or an actual benchtop test battery for $15. Alligator clips are $3 at Autozone or $5 for a set of 10 test wires with clips on amazon, so, for a $20 bill, you can have a complete 12 V test setup that takes up the same space as a cup of coffee and be able to test 12V accessories whenever you want.
99' SR5 HRU
Old 01-05-2021, 01:48 AM #26
Also, another good tip is to keep some of your incandescent bulbs. I'm finding that the "D" indicator on the dash is sort of annoying at night being so bright. I also often run with my O/D off and it is a bit obnoxious as well. I plan to probably switch the O/D off to a green light to see if it helps and I'm going to try an amber light for the "D" indicator. However, if neither is to my liking, I might just throw the old incandescents back into those two spots.
99' SR5 HRU
Old 01-06-2021, 12:10 AM #27
Pj Benn Pj Benn is offline
Pj Benn is on a distinguished road
Could you add bulbs for rear window defrost and hazard buttons to your list please?
Pj Benn is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 12:23 AM #28
Devbot's Avatar
Real Name: Devan
Devbot's Avatar
Real Name: Devan
Hazard has no lights. He already listed the rear window light, read more carefully, very bottom. Neo Wedge T3 bulb.
Old 01-06-2021, 12:47 AM #29
JJexplr JJexplr is offline
JJexplr is on a distinguished road
Thumbs up
Great info, thanks
JJexplr is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 12:49 AM #30
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
The hazard does have a light. It's also a Neo Wedge T3 bulb, but I don't recommend swapping it to an LED. The bulb doesn't point out towards the front, it points 90 degrees off from the front of the switch (It points up if you are looking at the dash rather than towards you), so an incandescent works fine in there, but an LED will be much dimmer because most of the light is going in the wrong direction. When I did mine I tried swapping it to an LED, and it was almost impossible to tell that it was illuminated. Even with the incandescent it's not bright.
Skulking is offline   Reply With QuoteReply With Quote
bulbs , leds , lights , superbright , updated
Interior Lighting mod shawn719 5th gen T4Rs 142 01-31-2019 12:48 PM
Interior Lighting Help Please rushrunner 4th Gen T4Rs 20 03-04-2010 12:52 PM
Help with interior lighting! And more... Mason Fresh Mountain 1 09-15-2009 11:06 PM
interior lighting skkiii_whhaattt 3rd gen T4Rs 5 03-03-2006 06:00 PM
interior lighting skkiii_whhaattt 3rd gen T4Rs 1 03-02-2006 11:24 AM
