Old 04-08-2017, 11:15 PM #1
weekendclimber's Avatar
weekendclimber weekendclimber is offline
Real Name: Scott
weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice weekendclimber is just really nice
Real Name: Scott
Strippted Front Diff Drain Plug Removal Tips (aka: what not to do)
So, after draining the rear diff and the transfer case and refilling it came time to do the front diff.
Flashback: I had the diffs drained and refilled a previous time at a place that managed to eff it up by not torquing the filler plug all the way done (not to mention not using a new crush washer that I had given them). At the time, I put a new crush washer on and cursed them for having to clean gear oil off the skids. Didn't even think at the time of checking the drain plug, because there wasn't anything leaking from it.
Fast forward to today: The drain plug is either cross-threaded and stripped, or at the very least just stripped. What a PITA! Anyway, after successfully stripping it more, I get the dremel out. Cut a notch, get a chisel and hammer and start whacking away. Not even a bit of a budge.
Well, this is why they make screw extraction kits. So, I pull the screw extraction kit out along with the drill. Get into it and start the extractor. Seems to be biting pretty good until:
No idea what to do now. The diff isn't leaking or anything, I just wanted to replace the stripped drain plug with a new one.
weekendclimber is offline   Reply With QuoteReply With Quote
Old 04-08-2017, 11:30 PM #2
nissanh nissanh is offline
Weld a 17, 19 or 21 nut onto the drain plug.
Old 04-08-2017, 11:34 PM #3
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
1. Weld a nut onto it and remove. Probably don't have a welder. Consider buying one in the future. Handy to have.
2. Buy a screw extractor, multi spline type, just a little bigger than the size of the hole, hit it in there, heat with oxy/ace and then attempt to remove.
3. Probably won't work but take a correctly sized extension, hit it into the hole to where it is snug, then put an impact on the other end.
4. Cut a groove into the plug, take an air hammer with a flat tip chisel bit and hit it enough to where it hopefully spins free.
#1 is the quickest and should be cheapest....
Good luck
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 04-08-2017, 11:45 PM #4
jdmpnoy89 jdmpnoy89 is offline
jdmpnoy89 is on a distinguished road
i ran into the same situation on my 4runner, previous owner stripped the hex, tried the chisel method but that didn't work the first time, then i heated the case slightly with a torch and used the chisel again and that worked for me!
jdmpnoy89 is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 12:12 AM #5
Real Name: Scott
Real Name: Scott
Haven't tried heat yet. That's the next option I think.
Old 04-09-2017, 12:35 AM #6
99Runnr 99Runnr is offline
99Runnr has a little shameless behaviour in the past
Those really seize in there. My last 4runner stripped out with a 2 foot breaker bar on a snap-on hex socket. Fitment was great it just couldn't handle it. My current truck I used my new cordless impact and it shocked the cover right out. I know if I had done (or had for that matter) this big ass impact it would have removed the other one too.
Since you stripped yours as well, I used a siphon pump with a necked down tube and siphoned the fluid OUT of the differential and then added fresh gear oil once I felt it was mostly emptied.
I used the $8 siphon pump from harbor freight and it has always worked well for me until it surpasses maybe 20 quarts through it. It has the smaller hose that fit down inside the diff casing though I believe.
99Runnr is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 01:04 AM #7
JayRolla's Avatar
JayRolla JayRolla is offline
JayRolla will become famous soon enough JayRolla will become famous soon enough
JayRolla's Avatar
Like stated weld a bolt. Bet shop charge half hour labor.
JayRolla is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 02:18 AM #8
nobb nobb is offline
nobb is on a distinguished road
Not to threadjack but does anyone have a thread spec or alternative part # (eg. From different manufacturer with a non hex head) to replace the shitty OEM designed plug with?
nobb is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 06:39 AM #9
s20004runner s20004runner is offline
Real Name: Alex
s20004runner is an unknown quantity at this point
Real Name: Alex
the hex plug used in the rear diff should be the same thread/size
i couldn't remove the plug, but i got the fill plug removed, so i got a pump to remove old oil and fill in new ones.
s20004runner is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 08:04 AM #10
Acorn22's Avatar
Acorn22 Acorn22 is offline
Real Name: Brian
Acorn22 is on a distinguished road
Acorn22's Avatar
Real Name: Brian
Just dealt with this yesterday. What I did was get a drill and create a square shape in the drain plug, just the right size for a 3/8" ratchet extension. Then I hammered an extension into it and was able to get if off by connecting a ratchet to the extension and twisting. That was my non-welding way of getting it out, hope that helps.
1998 4x4 Limited 3.4 Sunfire Red Pearl
Front: Eibach 600lb 3" lift coils over Tacoma 5100's
Rear: Lexus LX450 coils w/ FJ80 shocks
Firestone Destination AT 265/75's
Acorn22 is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 08:40 AM #11
Desertwind16v Desertwind16v is offline
Desertwind16v is on a distinguished road
You can probably use the same method you're using by adding one more step. Grab your hammer and hit the face of the drain plug very hard a few times, it helps to crush the gasket down making it easier to loosen the plug. Then go back to using the chisel. I use this method at work to remove them when they're stuck.
Desertwind16v is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 09:27 AM #12
Harleydoc Harleydoc is offline
Harleydoc is on a distinguished road
I just weld something to it to get it out and just replace it. And when I put the new one I put some Anti-seize on it
Sent from my iPhone using Tapatalk Pro
Harleydoc is offline   Reply With QuoteReply With Quote
Old 04-09-2017, 11:28 AM #13
kball's Avatar
kball kball is offline
kball is on a distinguished road
kball's Avatar
If I was going to weld a nut onto the plug I think I would keep using that plug. It's already got a nut on it now!
Next time, for this application I would use this type of extractor.
Hex Head Multi-Spline Screw Extractors - 522/532 Series - Tools - IRWIN TOOLS
These plugs always seem to need some impact to get them off though. I would think you're on the right track with the chisel technique. Some heat should do it.
1996 SR5 4Runner V6 4WD Auto
Toytec Ultimate w/ OME 890's plus 1.5" daystar spacer
60028 OME shocks, Goodyear Duratracs 265/75 -16
B&M 70268 with Magnefine filter, 199mm TBU
236K miles
kball is offline   Reply With QuoteReply With Quote
Old 07-04-2018, 05:46 PM #14
hyken's Avatar
hyken hyken is offline
hyken is on a distinguished road
hyken's Avatar
I have never had a nut or bolt that some Kroil couldn't bust. It's leagues above even PB Blaster. A little pricey, but SO worth it. I usually spray it on heavy, leave it for 30 minutes, then spray again right before I wrench on it. Works every time - seriously. And my truck is literally eaten alive with rust...
1999 SR5 4wd all stock!
Broke as a trail horse.
hyken is offline   Reply With QuoteReply With Quote
Old 07-04-2018, 07:37 PM #15
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Hey, another thread I can post this video in.
Diff Drain Plug Shaved Down, now what? rossgoldie 3rd gen T4Rs 21 11-15-2016 04:53 PM
Stuck Diff Drain Plug planeboy95 4th Gen T4Rs 12 10-11-2015 10:11 PM
Front diff replacement drain plug PN? bugman-74 3rd gen T4Rs 4 05-14-2015 04:37 PM
Front Diff drain plug is a pain in the a s20004runner 3rd gen T4Rs 8 03-23-2015 11:31 AM
Front Diff Drain Plug Part Number xcmtb83 3rd gen T4Rs 4 12-02-2013 02:35 PM
