Old 12-23-2020, 04:45 PM #1
Fastphin Fastphin is offline
Fastphin is on a distinguished road
3rd gen Push Switch
I have been searching the forums and internet for a push switch to go into the factory slots on left of the steering wheel. The limited has two seat warmer switches leaving the 3 below. I tried a switch that is too big and concerned about cutting the hole largee as I plan to expand a rear pod and compressor switch. 3rd gen Push Switch-20201223_115043-jpg
Sent from my SM-G960U using Tapatalk
01 Ltd 4x4. Bilstein 6112s front ICON uca, 5150 with OME 906 rear.
Fastphin is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 05:04 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 will become famous soon enough Malcolm99 will become famous soon enough
Malcolm99's Avatar
The best option is to buy rocker or push/detent switches that fit as opposed[FIXED FOR BLAIRRACD] to hacking ones in that don't fit, you will notice the other switches are imbedded or counter sunk into the slot, nice and clean fit, some switches have a lip/trim that cover the hack job so it doesn't look terrible though, ideally you want the switch to fit the oe option and save yourself some work, should be a pretty common size for Toyota and most Japan vehicles. Not a big fan of all the trucker push switches that stick out past the mounting location that are available, they just look outta place sticking out like that. Looking again at it even if you did hack it out the hole will end up to large or the locking tabs on your switch won't engage to the modified counter sunk slot. I use to work in a heavy equipment shop that does dump box, crane and highway plow and tow plow installs and we use those type of "push" raised rocker switches because they where cheaper for custom dash and console control work and the industry standard for truckers, most are cheaply made and problematic, we did about 300 truck per year and had issues with low quality switches, mind you there where about 20 added to some installs, under bad conditions and heavy use.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 06:49 PM #3
jgue467's Avatar
jgue467 jgue467 is offline
jgue467 has a spectacular aura about jgue467 has a spectacular aura about jgue467 has a spectacular aura about
jgue467's Avatar
Don't '03 camry switches fit 3rd gens just right, anyone?
2001 Limited 4WD - 328K - SunfireRed\Thunder Cloud; - 265/75/16 Michelin A/T2s - Fat Pat's 1.5" BL, ZERO RUST - StopTech ANGLED rotors - Magnefine trans filter - In series trans cooler, ORIGINAL: paint, engine, 4wd, trans, mstr cyl & brake system, rear axle seals, A/C, steering pump, steering rack, front/center/rear diffs, all electric motors, seat heaters and so on. WooHoo!!
Oh yeah, GO LONGHORNS!
Old 12-23-2020, 07:55 PM #4
rexassian rexassian is offline
rexassian is on a distinguished road
I think this is what you're looking for :
CH4X4 Custom Laser-Etched Toyota Push Switches
I just ordered a couple of these myself.
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
rexassian is offline   Reply With QuoteReply With Quote
Old 12-23-2020, 08:20 PM #5
Malcolm99's Avatar
Malcolm99's Avatar
Deleted
Amazon.com: Cole Hersee 8215902BP Rocker Switch Bracket Mounting Kit: Automotive
Old 12-24-2020, 10:57 AM #6
Bad Luck Bad Luck is offline
Real Name: Patrick
Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all Bad Luck is a name known to all
Real Name: Patrick
Post up some pics once you install them please. It doesn't say that they work with our 4Runners but that doesn't necessarily mean they don't
2000 Limited V6 Auto E-Locker
Old 12-24-2020, 02:21 PM #7
Baughb Baughb is offline
Real Name: Bob
Baughb is on a distinguished road
Real Name: Bob
I think they do
They are labelled "Toyota" and seem to be only 3 amps. I searched for higher amperages, which they have but, some may not be exact fits.
Best of luck!
Baughb is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 03:10 PM #8
blairracd blairracd is offline
blairracd is on a distinguished road
Originally Posted by Malcolm99 View Post
The best option is to buy rocker or push/detent switches that fit as upose to hacking ones in that don't fit
I'm sorry....but do you really not know the word ''opposed"?
Missing my 4runner...
blairracd is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 03:31 PM #9
Malcolm99's Avatar
Malcolm99's Avatar
Geez my apologies, in my haste I didn't proof read it for spelling errors while typing on my phone. I'll be sure to proof read my, and everyone's posts and point out any mistakes and PM you so you can correct everyone publicly. I'll be sure to correct that, thanks for your concern about me. I'd hate for anyone to be confused about what I was saying, I shouldn't post suggestions or offer help here anyways.
Old 12-24-2020, 03:59 PM #10
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
Your fine. People have bad days. I appreciate your thoughts and assistance any day. ;]
1997 4X4 V6 5 Speed Sr5 4 Runner (The Tank)
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 12-24-2020, 04:02 PM #11
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Perhaps the reason for low amperage switches only is your not supposed to put high amperage across switch contacts. As it can have the switch melt down and fail prematurely. Circuits are supposed to use relay to power the high amperage circuits. Just my opinion though what do I know it's not like I went to college for electric engineering or anything. Come on people lighten up its Christmas for goodness sake...:]
Old 12-24-2020, 04:14 PM #12
Malcolm99's Avatar
Malcolm99's Avatar
Well at least I was able to help blairracd out by letting him know the D558 taco 5100's he is using are not 4R 5100's, I'll include some more info for him since he wants to add a steel bumper to his Taco shocks, hopefully nobody made any spelling errors..
Not enough lift from Eibachs. Spacer or higher clip for 5100s?
Read before buying Bilsteins!
Old 12-24-2020, 08:06 PM #13
lol, electrical engineer here as well. yep, planning on relays for all my switches, I don't really want to route 12ga wires into the cab for the larger items like lights, etc. Relays are your friends.
Old 12-24-2020, 08:53 PM #14
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes they sure are.
Old 12-25-2020, 02:48 AM #15
Doc3g Doc3g is offline
Doc3g will become famous soon enough
I hacked mine up for some nice OTR switches. OEM switches look dainty to me anyway
3rd gen Push Switch
3rd gen Push Switch
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
3rd , cutting , hole , push , switch
Lightbar Push Switch - Help Please 4RFiend 5th gen T4Rs 23 12-08-2020 01:16 PM
Square Push Button Switch Mudhorn 5th gen T4Rs 10 05-27-2020 01:16 PM
TPMS Push Button Bypass Switch slimjj 4th Gen T4Rs 9 11-04-2016 03:56 PM
Aftermarket push switch wiring 4OYOTER 4th Gen T4Rs 5 04-03-2016 03:09 PM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
