Old 12-24-2020, 08:18 PM #1
pierce.martin pierce.martin is offline
pierce.martin is on a distinguished road
Parasitic Draw Driver Power Window
Hi everyone,
I have a 2000 4runner that I am trying to chase down an intermittent parasitic power draw on.
I have installed a current monitor on the battery and tracked the parasitic load down to the "POWER" fuse on the cabin fuse box which I think goes to the power windows/locks/etc...
I have always had an intermittent issue with the driver power window where sometimes if I bang on the door enough it will start working again. Sure enough, after installing the current monitor, when the parasitic power draw is present the driver window won't work. If I bang on the door enough, the window will start to work again and the power draw will go away.
Does this point more to the switch or the motor itself? I have taken the switch assembly out and all the wires/connectors/circuit-boards look in great shape with nothing obviously wrong. Is there anything I can test?
Thanks in advance for any advice you can provide!
pierce.martin is offline   Reply With QuoteReply With Quote
Old 12-24-2020, 08:30 PM #2
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Check the wires in door jam boot and see what you find out.
Old 12-25-2020, 11:41 AM #3
TheDurk's Avatar
TheDurk TheDurk is offline
TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light TheDurk is a glorious beacon of light
TheDurk's Avatar
Try unplugging the window motor when in parasitic drain. If it clears, motor is likely the issue. If not, it's definitely the switch or wiring. I agree...check the wires in the door harness to body connection where they flex. Common fail point.
My Backyard Frame Swap
Old 12-25-2020, 02:14 PM #4
Thanks guys!
Good advice, now to tear into the door to get to the motor. Will check the door connection as well.
draw , driver , parasitic , power , window
strange parasitic draw Frank13F 3rd gen T4Rs 21 01-24-2019 01:24 PM
Parasitic draw help needed runnerw 3rd gen T4Rs 1 06-24-2015 01:14 AM
Parasitic Draw, JBL Amp replace, repair RCX2K 4th Gen T4Rs 6 08-21-2013 10:27 PM
Parasitic Draw Short , am2 fuse mk1959 Classic T4Rs 5 09-20-2012 06:10 AM
Parasitic Draw in JBL amp cotten Engines / Suspension / Wheels / Tires / Audio / Accessories 0 07-15-2008 01:09 AM
