Old 12-21-2022, 11:56 PM #1
cashflow50's Avatar
cashflow50 cashflow50 is offline
cashflow50 is on a distinguished road
cashflow50's Avatar
Throttle Body
Can this part be bought separately? It’s throwing a P1121 code and reading says change whole throttle body
cashflow50 is offline   Reply With QuoteReply With Quote
Old 12-21-2022, 11:59 PM #2
cashflow50's Avatar
cashflow50's Avatar
I already changed the TPS. Did some diagnostics and pulled the plug from the circled part and threw the same code
Old 12-22-2022, 02:32 AM #3
Pyral's Avatar
Pyral Pyral is offline
Real Name: N/A
Pyral has a spectacular aura about Pyral has a spectacular aura about
Pyral's Avatar
Real Name: N/A
Why is the cable coming in from the wrong side, is this a Surf?
Edit: nvm the 5vz exists my bad
1998 4runner 2.7 manual
Pyral is offline   Reply With QuoteReply With Quote
Old 12-22-2022, 04:10 AM #4
cashflow50's Avatar
cashflow50's Avatar
Throttle Body
So can that part be bought alone or gotta buy the whole throttle body?
Old 12-22-2022, 09:37 AM #5
jgue467's Avatar
jgue467 jgue467 is offline
jgue467's Avatar
So was the throttle position sensor tested? {Disconnect the pedal position sensor connector. (b) Using an ohmmeter, measure the resistance between terminals VC and E2. Resistance: 1.2 - 3.2 kΩ at 20°C (68°F)}
Check your parts here (use your VIN for highest accuracy):
Toyota Parts and Accessories - Official Online Store
Not sure of your MY but my '01 has a TPS for about $81 (part no. 8945235020)
If not may find a used one at junk yard, ebay, amazon, ect.
Luck.
Old 12-22-2022, 07:51 PM #6
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
That's the electronic throttle that you are unplugging. Unfortunately it's a motorized unit that opens and closes the throttle and the cable is just there as a safety and Toyota sells it as a complete assembly. If it's throwing a code it is most likely needing replacement. Those things are stupid expensive too. I used to sell used ones almost immediately.
326WHP 347TQ
Old 12-28-2022, 12:10 AM #7
cashflow50's Avatar
cashflow50's Avatar
Throttle Body
I bought a brand new oem TB online. p1121 is what it spat out.
Like I mentioned earlier the TPS didn’t fix the problem.
Old 12-28-2022, 10:31 AM #8
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
here is the testing procedure.
https://www.teamtoyota4x4.org/archiv...thrbod/ovi.pdf
Malcolm99 is offline   Reply With QuoteReply With Quote
change , code , iphone , reading , throttle
2002 6cyl. 175k Vacuum leak, Throttle Body throttle lever? Hollywood1 3rd gen T4Rs 3 12-29-2018 06:25 PM
The small black plastic "cap" on throttle body near throttle cable - What is it? bugman-74 3rd gen T4Rs 3 03-10-2015 10:23 PM
Electric throttle body to cable throttle body conversion Dirtyfingers 3rd gen T4Rs 8 12-29-2014 10:05 AM
Throttle body troubles...WOT=half throttle Idahosr5 3rd gen T4Rs 0 10-31-2010 04:09 PM
Throttle body cdmasm Classic T4Rs 1 03-23-2006 08:56 PM
