Changed my oil yesterday and started it up to circulate the new oil and listen for any weird sounds as one does after an oil change. It's always had a rattling/ticking noise which went away when I put my hand on the power steering pump. I assumed maybe the pulley was going bad or something. Then I noticed that the top mounting bolt for the power steering pump looked loose. So I turned the truck off to check and the damn bolt was completely disengaged and just rattling around in the hole! It's probably been like that since I bought it in September because I noticed the noise the day I bought it. I'm not sure what divine power kept the bolt from drifting into the power steering pulley and grenading any number of things on the engine but man, that could have been bad.
one of the three bolts is difficult to get to.
Maybe it was your yota's way of saying, hey buddy...remove pump and clean screen ( and flush power steering)
2001 SR-5...bone stock ( for now) bought 12/10/20. silver, cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20. Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
You have better luck then me. That bolt would have fell out the first week I had it and bounced of the fan sending it through my rad. . Glad you got it all fixed up now
1997 4X4 V6 5 Speed Sr5 4 Runner (The Tank)
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
