Old 01-04-2021, 12:35 PM #31
Originally Posted by clanofwolves View Post
I will on the O2s... I do some seafoam cleaning of the TB and I spray cleaner into the IAC when I am cleaning the MAF (the right brass screw is removed with a vice grip as the first attempted removal found her not budging, haha). I haven't paid an overwhelming amount of attention to the IAC, save I just insure she moves easily.
I pull the lower idle assist hose off the IAC and spray in there until no black chunks are visible in the inlet to it.
Old 01-06-2021, 12:13 PM #32
clanofwolves's Avatar
clanofwolves clanofwolves is offline
clanofwolves is on a distinguished road
Originally Posted by LittleCaesar View Post
At least with the preliminary data, not a vacuum leak and probably not a direct fuel problem. Most likely an aging sensor. Post the new data once you have it.
Originally Posted by Bad Luck View Post
I would replace the oxygen sensors
+1 on changing out the 02 sensors.
What is the best brand (other than OEM) that you guys have had good luck with?
"Family and God - that is what's important. Money, cars, those are things that come and go."
clanofwolves is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 12:50 PM #33
bear1998 bear1998 is offline
Real Name: Bryan
bear1998 will become famous soon enough
Real Name: Bryan
Denso....
bear1998 is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 01:29 PM #34
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
I replaced mine with Denso
Old 01-06-2021, 01:39 PM #35
NTKs work also
Old 01-06-2021, 03:49 PM #36
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
Been using the same Densos since 2009 with zero problems......
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 02-11-2023, 12:00 AM #37
Grizzly Be4R Grizzly Be4R is offline
Grizzly Be4R is on a distinguished road
Exclamation
Hi everybody, I'm new to the forum trying to diagnose a P0171 code on my (new to me) '01 SR5.
So far, I've solved my P1135 & P0420 codes by replacing both O2 sensors with Denso.
For the unsolved P0171, I tried cleaning my MAF but the code returned. My next task was gonna be to check for a vacuum leak. Not sure if there's any common things I'm missing or could try? Thanks in advance for any input.
i recently bought the truck and the dealer didn't disclose multiple check engine codes so I'm hoping this is an easy fix
Grizzly Be4R is offline   Reply With QuoteReply With Quote
Old 02-11-2023, 09:48 AM #38
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
One toyota website suggests vacuum leaks like you're saying, but it also goes on to say that it could be a leak in the PCV hoses or even the valve itself.
If you replace the PCV valve, make sure you get a new grommet to go with it and take your time. Get it from Toyota, they are inexpensive. Have needle nose pliers on hand in case it begins to crumble and you get bits down
in the hole it comes out of.
Sent from my SM-S908U using Tapatalk
Old 02-12-2023, 03:30 PM #39
Texmax's Avatar
Texmax Texmax is offline
Texmax is on a distinguished road
Texmax's Avatar
Get or find someone with a smoke machine. It'll save you a lot of time and money.
99 4wd limited w/ E/locker
3" RC lift-loaded struts. Sonoran Drop diff and adjustable rear Panhard.
JBA Offroad UCA's, Pro comp Raven 16x8 wheels wrapped in 265/75/16 Gladiator Mt ,APOC INDUSTRIES Rear Trailing arms.
RETIRED USCG Aviation Mechanic/Hc130h Flight Engineer/HH65-A Flight Mech.
SEMPER PARATUS
Texmax is offline   Reply With QuoteReply With Quote
Old 02-12-2023, 05:10 PM #40
JoeT4R's Avatar
JoeT4R's Avatar
This too!
Sent from my SM-T220 using Tapatalk
Old 02-18-2023, 10:12 PM #41
Question
Mechanic didn't detect a vacuum leak. Changed the MAF (new Delphi) and also replaced the PCV valve+ gasket.
CEL stayed off for about 100 miles and then popped back on. P0171. O2 sensors are new as well. Any other suggestions? I'll try to get a smoke test done soon if that's my only option besides the fuel filter..
Old 02-19-2023, 08:02 AM #42
JoeT4R's Avatar
JoeT4R's Avatar
Fuel filter is an inexpensive fix. OEM filters go for about $40 iirc. If the inlet and outlet nuts aren't rusted on yours I'd suggest doing it yourself, it's not a hard job as long as the nuts can thread easily. Perhaps give that a shot, especially if it's never been done on your truck before and report back. If you need the p/n let me know.
Old 02-19-2023, 10:10 AM #43
If the fuel filter doesn’t fix it look for cracks on the intake tube between the MAF sensor and the throttle body.
Old 02-19-2023, 07:33 PM #44
Thanks y'all. Will report back in the near future.
Old 03-14-2023, 02:23 PM #45
JoeT4R's Avatar
JoeT4R's Avatar
Any further updates on this? My rig is now having the P0171, even after clearing the code three times now with my ScanGauge.
bank , lean , p0171 , start , system
P0171 Lean Bank appears and disappears Tundra9er 3rd gen T4Rs 12 08-29-2023 09:14 AM
P0171 Lean bank 1 Question jhueter 3rd gen T4Rs 43 08-21-2023 09:48 PM
P0171 - System Too Lean (Bank 1) nasdamus 4th Gen T4Rs 15 06-12-2019 03:40 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
P0171 (B1 System Too Lean) Rescue84 Problems & Warranty Issues 2 09-27-2006 03:47 PM
