Old 03-14-2023, 02:32 PM #46
RodrickHeffley's Avatar
RodrickHeffley RodrickHeffley is offline
RodrickHeffley has a spectacular aura about RodrickHeffley has a spectacular aura about
Originally Posted by JoeT4R View Post
Any further updates on this? My rig is now having the P0171, even after clearing the code three times now with my ScanGauge.
Sent from my SM-S908U using Tapatalk
I had this code in July and eventually tracked it down to either a dirty MAF or a vac leak, I'm not sure which it was because I did both at the same time and it hasn't come back since
1998 4Runner Limited 4WD w/Rear Locker
281k Miles
Build Thread
RodrickHeffley is offline   Reply With QuoteReply With Quote
Old 03-14-2023, 06:20 PM #47
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Did you clean the MAF sensor or replace it?
Old 03-14-2023, 08:15 PM #48
just cleaned it with the cleaner from oreilly's, the MAF for the 98 runs pretty expensive new so that was the first (and cheapest) option I found
281k Miles
Build Thread
Old 03-14-2023, 08:39 PM #49
Doc2012's Avatar
Doc2012 Doc2012 is offline
Location: Stationed in Camp LeJeune, home is Conover, NC
Doc2012 has a spectacular aura about Doc2012 has a spectacular aura about
Doc2012's Avatar
Mine was a partially clogged fuel injector.
"We are experts in the application of violence."
-LtCol Christian Cabannis, Camp Letherneck, Afghanistan, 2009. The "Summer of Decision."
Doc2012 is offline   Reply With QuoteReply With Quote
Old 03-15-2023, 05:02 AM #50
JoeT4R's Avatar
JoeT4R's Avatar
I'll do some more research today and see what shows up.
How did you end up discovering that it was a fuel injector?
Old 03-15-2023, 08:29 AM #51
Doc2012's Avatar
Doc2012's Avatar
Deductive reasoning.
Cleaned, tested, and replaced everything that the FSM said was related to the 171; and it still showed up.
So then I moved onto the fuel system; replaced the filter with no change; tested the pump (within spec); ohmed out the injectors (within spec).
Just for poops and giggles I bought an ultrasonic cleaner and injector tester; put all 6 in the cleaner with dawn for about an hour, then pulsed each one for about 30 minutes in the cleaner; then put them back in with fuel system cleaner (to try and get rid of water).
Bam.
No more 171.
Old 03-15-2023, 08:40 AM #52
JoeT4R's Avatar
JoeT4R's Avatar
Bam.
No more 171.
I see. That's good to hear you were able to work the process like that. And I appreciate the information on that. I actually went ahead and ordered a new Denso MAF sensor from RockAuto. Should be here in two days. I'll throw that in and see where it takes me. I haven't noticed a decrease in overall performance or mileage, I've recently done my A/F ratio sensor and o2 sensor, and the fuel filter.
If the new MAF sensor doesn't resolve the CEL, then I'll continue working the problem with some of the things you did. Hopeful that it's just the sensor itself.
Old 03-15-2023, 09:12 AM #53
Bam.
No more 171.
It’s fairly easy rebuilding the injectors. I have how I did it in my build and repair thread with the rebuild kit.
Old 09-03-2023, 09:16 PM #54
Josiah21 Josiah21 is offline
Josiah21 is on a distinguished road
Unhappy P0171 system too lean bank 1
I’ve replaced my fuel injectors fuel pump intake manifold gaskets o2 sensors tps sensor vaccum lines fuel filter and maf sensor I’m still getting a p0171 code a mechanic told me it was the fuel pump and said it was at 28psi instead of 33-38 psi so that’s why I replaced it again I believe it might be my catalytic converter I just had recently changed about 7 months ago bc it sounds weird what do you guys think it could be I’ve replaced literally everything pertaining to the code p0171 I wanted to post my own thread but it wasn’t letting sorry so I tagged along on yours I’ve gotten it smoke tested also it’s not the vacuum lines I’m completely at a lost besides the catalytic converter any help would be appreciated
Josiah21 is offline   Reply With QuoteReply With Quote
Old 09-03-2023, 09:18 PM #55
My 4Runner will get to 70 mph and will struggle to go past it that’s why I’m trying to fix the issue
Old 09-03-2023, 09:29 PM #56
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When was the fuel filter changed, and the fuel pressure good? A other possibility is injectors plugged up.
Does it always cut out at that rpm level ?
Old 09-04-2023, 09:48 AM #57
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Exhaust leaks or a bad air/fuel sensor can also cause P0171.
Old 09-05-2023, 10:23 AM #58
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
With all that changed, I would definitely look at the cat. Shine a flash light through it. to see if its clogged. Being @jross20 just had a pinging issue with one. Its definitely possible. Plus a possible vacuum leak
bank , lean , p0171 , start , system
P0171 Lean Bank appears and disappears Tundra9er 3rd gen T4Rs 12 08-29-2023 09:14 AM
P0171 Lean bank 1 Question jhueter 3rd gen T4Rs 43 08-21-2023 09:48 PM
P0171 - System Too Lean (Bank 1) nasdamus 4th Gen T4Rs 15 06-12-2019 03:40 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
P0171 (B1 System Too Lean) Rescue84 Problems & Warranty Issues 2 09-27-2006 03:47 PM
