Old 12-30-2020, 01:58 PM #1
clanofwolves's Avatar
clanofwolves clanofwolves is offline
clanofwolves is on a distinguished road
P0171 - System Too Lean Bank 1
Check engine light came on, my Foxwell is telling me "P0171 - System Too Lean Bank 1". What do you guys think is the cause is as I start an investigation.
Thanks in advance!
Dave
"Family and God - that is what's important. Money, cars, those are things that come and go."
clanofwolves is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 02:37 PM #2
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I would start with looking at your live data, particularly your short and long term fuel trims on both banks.
Oxygen sensors original?
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 03:16 PM #3
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Old oxygen sensors, vacuum leak, dirty MAF. Likely culprits to check in that order.
Old 12-30-2020, 06:10 PM #4
Yes, best I know (second owner from 2011) the O2 sensors are original.
I'm looking at the live data function and trying to figure out what Foxwell indicates as fuel trim. Any ideas on what they would deem this on the live data list?
Old 12-30-2020, 06:26 PM #5
If you can get a freeze frame when it the code shown up it would be helpful.
What is your MAF reading at idle? That will help indicate if you have a vacuum leak.....
Old 12-30-2020, 06:27 PM #6
LTFT is the important one. Plus MAF at idle.
Old 12-30-2020, 06:42 PM #7
bear1998 bear1998 is offline
Real Name: Bryan
bear1998 will become famous soon enough
Real Name: Bryan
A dollar to a donut (lol)....oxygen sensor
bear1998 is offline   Reply With QuoteReply With Quote
Old 12-30-2020, 06:42 PM #8
If you go to the main menu function, it should be the oxygen sensor test, probably either the 4th, 5th, or 6th test. You should see stft and lgft numbers. You would like to see those values as close to zero as possible, but given the code, some will not be.
As stated above, there should be a freeze frame function on the live data main menu. It shows the values of sensors and the like when the ECU sees the fault occur, which may give insight into what caused the money light to come on.
Having never used Foxwell I couldn’t say for certain concerning the live data main menu but usually all OBDII scanners follow the same set list....
Old 12-30-2020, 06:50 PM #9
I did check for vacuum leaks first thing visually as well as using starter fluid, none detected.
The O2 sensors are original as far as I know, but wouldn't they too throw a code in addition to the P0171?
I remove and clean the MAF every 20,000 miles and I just did it about 5K ago, but maybe it is an issue anyway?
Old 12-30-2020, 06:52 PM #10
What should the MAF number be if she's working correctly?
Old 12-30-2020, 06:55 PM #11
Haha, chocolate iced custard filled hopefully... you betting the upstream one?
Old 12-30-2020, 07:14 PM #12
Real Name: Bryan
Real Name: Bryan
Yes.....If ur gonna replace one...i would do both....same code..then shorty after bank 2 code came up..
Old 12-31-2020, 12:06 AM #13
.518 lbs/min is a good number at a warmed up 700rpm idle. Anything less is a vacuum leak.
I created a thread in 2019 about the subject when I put my rebuilt engine in and had your code at idle.
Old 12-31-2020, 02:04 AM #14
Bucket81's Avatar
Bucket81 Bucket81 is offline
Real Name: chris
Bucket81 is on a distinguished road
Bucket81's Avatar
Real Name: chris
Don't forget to clean your IAC. I'm putting mine back together tomorrow.
Bucket81 is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 02:14 AM #15
Joelzy's Avatar
Joelzy Joelzy is offline
Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light Joelzy is a glorious beacon of light
Joelzy's Avatar
I went through this after my rebuild and chased it for a while. ended up being a vac leak at an injector seal which was one of the few things i didnt change during the rebuild because i forgot them and didnt want to wait anymore. Got to wait anyhow
96 SR5 5SPD Elocker "the Barnacle"
–02 bmw 540i6
–19 Highlander SE
Joelzy is offline   Reply With QuoteReply With Quote
bank , lean , p0171 , start , system
P0171 Lean Bank appears and disappears Tundra9er 3rd gen T4Rs 12 08-29-2023 09:14 AM
P0171 Lean bank 1 Question jhueter 3rd gen T4Rs 43 08-21-2023 09:48 PM
P0171 - System Too Lean (Bank 1) nasdamus 4th Gen T4Rs 15 06-12-2019 03:40 PM
P0171 Code - Lean Bank 1... Help? jpontius 3rd gen T4Rs 5 02-23-2013 11:00 AM
P0171 (B1 System Too Lean) Rescue84 Problems & Warranty Issues 2 09-27-2006 03:47 PM
