Old 12-31-2020, 03:36 AM #1
jeff88 jeff88 is offline
jeff88 is on a distinguished road
Never-Used Spare Tire is Jacked Up
While changing suspension components today, I noticed this on my tire. It's clearly hitting the panhard bar when looking from the correct angle.
Is there anything I can do to fix this? These tires are the same size as stock even though I have the 17s on it. Could it be the shop didn't install it properly? It does look like it's mounted at a slight angle, if that means anything.
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
jeff88 is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 03:55 AM #2
JLTD JLTD is offline
JLTD has a spectacular aura about JLTD has a spectacular aura about JLTD has a spectacular aura about
Lower it slightly and reposition away from whatever is rubbing on it.
And if it's an original '99 tire it is waaay past useful life.
Between outfits.
JLTD is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 03:58 AM #3
Skulking Skulking is offline
Skulking is a jewel in the rough Skulking is a jewel in the rough Skulking is a jewel in the rough
You say the tires both are and aren't the same size as stock. Which is it? If you think the wheel may not be hanging correctly, just lower it, check that the hanger is centered, and lift it back up and see if it sits further away from the panhard bar.
Skulking is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 10:11 AM #4
Iffykid Iffykid is offline
Iffykid is on a distinguished road
Perhaps overall tire dimension is the similar but utilizing a 17" rim vs a 16"rim, ex 265/70/16 vs 265/65/17
Iffykid is offline   Reply With QuoteReply With Quote
Old 12-31-2020, 02:52 PM #5
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
my new 265/75/16 ko'2 dont hit the bar.
what size you running ? if smaller, then out of position or somthing else is wrong
Old 12-31-2020, 06:38 PM #6
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Real question is the age of tire. How old is it? If it's the original, it should be never used and should be swapped out when possible.
2000 4Runner Limited 4x4 V6
Old 12-31-2020, 07:59 PM #7
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Could be a hitch difference putting the tire closer, or not wound up tight enough to hold tire steady(the spring should be collapsed when wound tight), that spare moves around as does the Panhard bar of course, I put in a 1" body lift and had to add hockey pucks to the OE rubber bumpers on the body to steady the spare tire. Tire looks fine, perfect for a spare or DD, it Does not look like the original spare tire, and even if it was it would be fine for a spare never seeing sunlight.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 09:47 PM #8
It seems nobody has had a problem with their spare hitting the panhard bar before.
I misspoke in my original post, rather mis-remembered. I thought I had ordered sidewalls to match the original stock tire size (30.6" diameter). But I actually ordered a 31.6" diameter tire. A 1" larger tire, however, still well within the 32" spec that this forum recommends for "stock" 4runners. (Until a couple of days ago I was lifted 1" from the factory as stock because of the '99 talls, not that any of that matters since were talking about the spare not the wheel wells.)
My guess is the tire shop didn't install it properly because they were in a rush to get it done. They were having all sorts of problems that day. But I'm not touching the tire until they see it. I guess another trip to the tire shop is in order now...
angle , never-used , shop , stock , tire
Spare Tire location tire size limits Ogre75 5th gen T4Rs 3 03-06-2020 01:11 PM
Ideas for the spare tire area, sans tire. ThrillerR1 General Discussions 12 04-10-2018 10:31 PM
FS: 2016 4runner Trail - 4 Wheel/Tire Combo + 1 spare tire (Houston, TX) brg128 For Sale: Suspension/Wheels/Tires 2 03-21-2016 08:54 AM
Largest fully inflated 16" spare tire that will fit in the stock spare location? 240m3srt 3rd gen T4Rs 16 09-26-2013 01:30 PM
Tire Pressure Sensor - Spare tire Tdub 4th Gen T4Rs 3 09-01-2008 10:49 AM
