01-02-2021, 09:44 PM
#16
Real Name: Joshua 3 Bears
for those thinking of LBJ's soon, 2 people today posted pictures of LBJ's failing TODAY. Both aftermarket. ON the facebook 3rd gen mafia page. 1 set was detroit axle brand, other person did not say who made his/hers.
Yes OEM are not cheap. Neither is the damage resulting of having any fail regardless if OEM or aftermarket. Ill use OEM in this application.
2001 SR-5...bone stock ( for now) bought 12/10/20. silver, cloth, sunroof.
2000 SR-5 V6 Auto . TOTALED 10/22/20.  Desert Dune, Spectre intake, Borla muffler, Magnafine tranny filter, B&M cooler, 3 inch lift with tundra springs, billies, lc springs tokico shocks, DRL delete, Big 3 wire, full roof rack, TBU, Swapped in Elocker , all synthetic fluid. block, oil pan and tranny heaters, other small junk
01-02-2021, 10:08 PM
#17
I just picked up an 02 with 147k miles. The LBJ were replaced by Toyota about 90k miles ago under recall, in 2005. The truck is impeccably maintained.
Should I just do them again or give them a bit of time?
01-02-2021, 10:27 PM
#18
Real Name: Keith
Real Name: Keith
Conventional wisdom: If you are lifted, yes. If you drive a significant amount on washboard roads and other high-wear 4WD road conditions, yes.
If just normal streets and highways, no.
I put new OEM LBJs in at 120K miles, when I acquired the 4Runner. At that point it had been driven 120K miles unlifted on normal streets, so the original LBJs probably would have lasted another 100K miles. Now the 4Runner is lifted and it's done a couple thousand miles of rough roads. I'm now at 178K. I'll do them again by 200K miles.
01-03-2021, 01:58 AM
#19
I wouldn't change then unless the steering on the 4Runner isn't floppy and if there isn't much play on the ball joint. They still got a lot of life left. I would change them at 190k again with original Toyota parts.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
01-03-2021, 11:30 AM
#20
Congrats on the low milage find, harder n harder to come by.
90k mi on LBJ's I'd start by doing the FSM inspection to determine the condition of what you have.
I do FSM inspection every tire rotation, its easy once you get the hang of it.
Going on milage alone 100k mi I'm changing them, got my money's worth.
I've seen LBJ separation on net, sunk in when I saw it first hand in Lowes parking lot,
Father n young son 2 blocks from I-55 & 70 mph.
01-03-2021, 12:26 PM
#21
How well do you sleep at night? I’d just do it now and sleep easy for the next 10 years. Why put off the inevitable ?
As for the testing, I’m betting that 99% of us could not spot a bad ball joint using the fsm Method. It’s only once they are off the truck that it becomes obvious unless they are truly grossly worn out.
Just do it. Don’t become one of those photos.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
01-03-2021, 04:14 PM
#22
As for the testing, I’m betting that 99% of us could not spot a bad ball joint using the fsm Method....
That a good thing if you can't spot it, means your in spec, lol.
Spec is .5mm (0.020") max, Magnetic base flex post dial indicator needed.
Your absolutely right @90k mi replacement good for 100k mi no worries.
01-04-2021, 12:55 AM
#23
The ball joint on the right is an AC Delco 555 branded ball joint. Note the differences in the bolt mating surfaces. This ball joint had 40k miles and the only off-road action it saw was about 100 miles of beach driving and NEVER in the water. This ball joint was LOOOSEY GOOSEY. I could move it around with light pressure from my pinky.....
The ball joint on the left is a Toyota Genuine Balljoint. Stark differences. I was too stupid to know better when I first got this rig.
2001 LIMITED 4X4 - Fresh as a Daisy at 196k! - Bone stock and staying that way! (not likely)
99 SR5 Sport - 387k and rolling! Front - Toytec 3/4 Spacer/Tundra Shocks. Rear - Daystar 1.5" Spacer/LC Shocks - GONE
01-04-2021, 11:20 AM
#24
I'm just a newbie, but isn't it ironic that we replace OEM/factory installed LBJs with OEM ones because they fail. But also the aftermarket ones fail?
01-04-2021, 01:24 PM
#25
Real Name: Patrick
Real Name: Patrick
They're a wear item that has the potential to cause catastrophic damage when they fail. So far no one has found a lower ball joint that bolts in that lasts longer than OEM.
2000 Limited V6 Auto E-Locker
#26
@ MLHooker47
, Irony - Wife - X wife - Wife, it everwhere Ha.
01-04-2021, 01:41 PM
#27
LBJ replacement interval?
My lower balljoints are greaseable. I grease them every oil change.
01-04-2021, 02:59 PM
#28
I've always questioned the move away from greasable BJ's, time has proven not a bad thing I guess.
Not gona gripe about 100k service life, price tag, lil dirt from job.
01-04-2021, 05:17 PM
#29
I always look for greaseable ball joints and swaybar links.
To me the lower ball joint failure is from rust seizing the ball and it breaking the stem from the ball.
01-05-2021, 12:02 PM
#30
To me the lower ball joint failure is from rust seizing the ball and it breaking the stem from the ball...
I've changed my philosophy on greasing BJ's, 100k+ service life it ain't broke know what I mean, I don't trust A/M. All for Links.
Rust being issue could see that, thread's on the subject show stud broke, ball base separation, my area ball n base all the time most before Ah Shiite. Lol.
Thread Tools |
Display Modes |
Rate This Thread |
Linear Mode
