Old 01-05-2021, 01:05 PM #31
Brian.'s Avatar
Brian. Brian. is offline
Brian. is a jewel in the rough Brian. is a jewel in the rough Brian. is a jewel in the rough Brian. is a jewel in the rough
Brian.'s Avatar
Originally Posted by 19963.4lsr5 View Post
To me the lower ball joint failure is from rust seizing the ball and it breaking the stem from the ball.
There is a TON of very detailed information on this very forum about WHY they are a failure item in this particular application. It has to do with design of the system. But failures come from the bolts as often as not (though, this seems to be mostly attributed to reusing them).
I replaced mine at 190k (when I bought the 4r form the original owner, non-lifted, most off-road was a gravel driveway), "felt" fine with the FSM test... boots looked fine when installed.... both were torn and holding water once removed with a lot of rust and movement evident. 200k miles is the outside limit for a Street-only, non-lifted truck (or rather, 200k miles/20 years... if you do 200k miles in 10 years, you might be fine).
At this point, any original-installed ball joints should be replaced simply due to AGE. Past that, it's a study in use-case. I'll probably stick to 15 years/150k miles myself for a 99% street/non-lifted use (and since I've only put ~5k miles on it in the past year, that'll be a time-related replacement).
Brian. is offline   Reply With QuoteReply With Quote
good , interval , lbjs , miles , replacement
coolant interval TheHippie General Discussions 3 01-27-2020 01:24 AM
Oil filter interval jminz 4th Gen T4Rs 21 05-15-2016 12:54 PM
Oil interval??? hec983 3rd gen T4Rs 34 01-21-2014 04:16 PM
Fluid Interval SCRunner12 3rd gen T4Rs 5 05-15-2011 09:01 AM
Oil Change Interval? huero 3rd gen T4Rs 6 05-12-2007 12:57 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
