Old 01-01-2021, 06:47 AM #1
sroosma's Avatar
sroosma sroosma is offline
sroosma is on a distinguished road
sroosma's Avatar
Rusted coils OK?
My 99 4runner has decent front springs (fatigue-wise) but are a little rusted. I'm going to replace the shock absorbers anyways, so is OK to re-use these? Otherwise I'd rather just replace the springs while I'm at it.
Rusted coils OK?-20201230_221024702_ios-jpg  Rusted coils OK?-20201230_221514233_ios-jpg
sroosma is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 11:00 AM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If they are rusted you need to change them, they won't work as well as non-rusted springs, or as originally intended.
Edit: if they are rusted in the body of the coil it's bad(coil end rust is normal), pitting and rust in the body of the coil changes the sprung steel and it doesn't act as it is originally intended. They are tough springs though so doubtful they will ever break.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 12:02 PM #3
alumarine alumarine is online now
alumarine has a spectacular aura about alumarine has a spectacular aura about
That looks like surface rust only.
If you can get rid of it with a wire brush it's just fine.
Where I'm from I wouldn't even notice that as being rusty.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is online now   Reply With QuoteReply With Quote
Old 01-01-2021, 02:02 PM #4
bootown's Avatar
bootown bootown is offline
bootown is on a distinguished road
bootown's Avatar
100% fine. That surface rust is having zero impact on coil function. Only thing I would do is remove the rust and paint before reinstalling...if you can get by without the car for the time it takes to prep, paint, cure. Otherwise I wouldn't hesitate to put them right back on as-is if painting is not convenient.
bootown is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 02:31 PM #5
Boognish_Forever's Avatar
Boognish_Forever Boognish_Forever is offline
Boognish_Forever is on a distinguished road
I’m glad you brought this topic up as I was wonder the same thing with my rusted springs. Before I put airbags in my rear springs, I chipped off as much paint as I could that rusted off and sanded those bare spots and spray painted them with a flat black.
My front springs look about the same as yours. My struts are still original and work well being they only have 103,000 miles on them. But I’m guessing sooner or later age will get them and the seals will probably dry out and start leaking.
Boognish_Forever is offline   Reply With QuoteReply With Quote
Old 01-01-2021, 03:02 PM #6
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
Yes rusty springs will be fine. Being springs are spring steel. Once they really start getting deep rust pits in them. They will then crack and need replaced. So surface rust not really an issue. The deep pits and scaling of steel will crack in time. Then you have to replace the springs.
Old 01-01-2021, 03:12 PM #7
sroosma's Avatar
sroosma's Avatar
Thanks guys, I'll definitely take all this into consideration for planning suspension next steps! I really appreciate the quick responses.
Old 01-03-2021, 02:17 AM #8
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
Being in Ohio, thats not terrible although I would change it since i'm there already just to not deal with it ever again (if the spring cracks from rust).
2000 4Runner Limited 4x4 V6
Old 01-03-2021, 03:04 PM #9
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
are yu doing anything with rear shocks too. If so this is a good time to change out springs. Im not a big fan of Moog parts, but some people say the sprigs are fine, you can replace all of em cheap, even do the 99 tallls and pick up an inch.
but to do front shocks, you have to dismantle springs
Old 01-03-2021, 11:00 PM #10
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Putting new struts with old coils will overstress the struts and cause them to fail prematurely. It's advised to pair new struts/shocks with new coils/springs. You'll still get life out of the new ones but not for as long as if you do both. I can understand not wanting to ditch the 99 coils though.
326WHP 347TQ
Old 01-03-2021, 11:57 PM #11
somethingcrafty somethingcrafty is offline
somethingcrafty is on a distinguished road
Probably not the end of the world .. but you will feel it
somethingcrafty is offline   Reply With QuoteReply With Quote
absorbers , re-use , replace , rusted , springs
Rear O2 Rusted Off RPS99SHO 3rd gen T4Rs 11 08-29-2017 09:13 AM
fs, ft, lc coils, tundra d.cab coils, taco trd coils.eastern n.c. 1mxdude For Sale: Suspension/Wheels/Tires 8 01-28-2015 06:07 PM
seriously rusted nut T4R_MTL Problems & Warranty Issues 1 04-12-2013 03:03 PM
HELP! outer tie rod rusted on drabbits 3rd gen T4Rs 10 11-24-2012 01:00 PM
Rusted bumper....no more StarGazer2063 3rd gen T4Rs 5 05-03-2012 01:52 PM
