Old 01-04-2021, 06:01 PM #1
the_welfare_wagon's Avatar
the_welfare_wagon the_welfare_wagon is offline
Real Name: Rich
the_welfare_wagon is on a distinguished road
Real Name: Rich
Extremely strange noise from rear brake drum
Just developed a new noise and its stumping me. When letting off the brake pedal, even with the car off, the right rear brake drum emits a weird short metallic whistle. Happens every time the pedal is pressed and after getting under the car its definitely coming from inside the drum. Any thoughts? Wheel cylinder maybe? Its decently loud. I can try to see if I can post audio of the noise
Edit: Does not make this noise while driving(that i can hear) and braking is not affected. Only symptom so far is the noise everything else is normal
Last edited by the_welfare_wagon; 01-04-2021 at 06:04 PM. Reason: Additional details
the_welfare_wagon is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 06:24 PM #2
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy has a spectacular aura about RandyBobandy has a spectacular aura about
Have you removed the drum and looked in there to see if anything is out of place? That’s the first thing I would do.
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-04-2021, 07:36 PM #3
brillo_76's Avatar
Real Name: Jon
brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold brillo_76 is a splendid one to behold
brillo_76's Avatar
Real Name: Jon
I am curious if your right side is not self adjusting. Thus your wheel cylinder is moving more and making the noise.
Sometimes the metal dust shield lip can hit the drum of debris get between the drum and that dust lip making noises too.
I also verify your emergency brake cable is working properly as the back drum brakes can rust or bind up some that the arms dont return against the bolt on the backplate. Which can cause issues with auto adjustment of the rear shoes.
1997 4X4 V6 5 Speed Sr5 4 Runner (The Tank)
1997 4X4 V6 Red limited 4 Runner (97 Limited)
1998 4X4 V6 Sr5 Red 4 Runner (98 Tetanus1 )
1998 4X4 V6 Sr5 Silver 4 Runner (98 Tetanus2)
2001 4X4 V6 Sport Green 4 Runner (01 Green Sport)
Old 01-05-2021, 11:01 AM #4
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of mtbtim has much to be proud of
mtbtim's Avatar
Real Name: Tim
I agree with @RandyBobandy . Pull the drum off and see what you can see. The problem might be very apparent when you get a look at the brake components.
Old 01-06-2021, 12:06 AM #5
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough Kanoe is a jewel in the rough
Kanoe's Avatar
You are probably hearing the springs retracting the shoes and a friction point is making the noise. It'll happen every time you lift the foot off the pedal. If you look at the FSM or a Haynes manual you will see how to service rear brakes. There are about a dozen points per side that get a little dab of brake grease to keep things working smooth and quiet.
If you haven't serviced the rears in a while this is likely the noise you hear. One of my old cars did it for years and I never bothered to fix it but I treat my 4runner better than that now.
-1996 4Runner. 3RZ 5-Spd. 4x4 Base model. OME2906 rears with 2004 Tacoma Dual Rate Fronts on Bilstien 4600s.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 12:13 AM #6
FD7683 FD7683 is offline
FD7683 is on a distinguished road
Best way to really find out where the noise is coming from is to pull both drums out and take a peak. Actually with the drums on, you could have someone inside the truck put it in drive and let the rear axle move by its own (with the rear jacked up obviously, and the front chalked) and you could probably track down the noise from there (if it happens). When putting it into park, pull the e-brake up so you don't shift it while it's moving.
I did this just to see what the f*** would happen when I did my bell crank replacements a while ago but this might be a good way to track down the small noise.
While you are there with the drums, spray the whole area with brake cleaner and see if the noise goes away. It might work. Keep in mind if they haven't been off in years, you might want to back off the adjuster behind the drum shield and pound the drum with a rubber mallet.
2000 Toyota 4Runner 4x4 Limited Sport Edition V6
brake , car , drum , noise , pedal
Rear Brake Drum Assembly goatfarmer Classic T4Rs 6 11-05-2016 02:29 PM
rear drum brake problem help! dominopizza 3rd gen T4Rs 17 01-03-2016 12:53 PM
Question on Rear Drum Grinding Noise kmiller93 3rd gen T4Rs 8 05-16-2013 04:28 PM
Strange noise after brake replacement DIVNWND 3rd gen T4Rs 4 12-17-2010 11:44 AM
Feedback Buttons provided by Advanced Post Thanks / Like (Lite) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
