Old 01-17-2020, 02:28 PM #1
rexassian rexassian is offline
rexassian is on a distinguished road
'99 manual SR5 occasional daily driver and weekend crawler build
Sup y'all, I've been mostly lurking and reading build threads over the last year and finally decided to document my own. I've also watched probably 20 hours of videos from @mtbtim & @infamousRNR so thanks for the wonderful resources to enjoy these awesome trucks.
Starting out, I really wanted to get back into rock crawling and have always loved 3rd gen 4runners. I've previously owned a 4th gen 2wd daily and a 1st gen 4cyl daily that was in my family so I wanted to get back into a 4runner and build it up this time. I was also adamant on getting a manual transmission to make life a little more challenging and hopefully eventually use it to teach my kids to drive stick, it's a dying skill after all. So after a few months of searching, I found one on craigslist nearby and got it. It was a theft recovery from Cali that was driven to Texas. PO changed out timing belt, water pump, rad hoses, CV axles, and a rear axle seal so it was in good running condition. One thing it needed was valve cover gaskets but that's not an immediate thing so it was no big deal to me. The only thing missing was rear locker but that's OK, I'll re-gear and lock eventually. Also missing, thankfully, was a sunroof, I didn't want that extra complexity.
Being that it's a theft recovery, it had some "irregularities" like a new steering column with a key that doesn't match the doors. The thief had painted a purple fade on the bottoms of the doors and rear hatch so the PO replaced those but couldn't get the rear hatch key to match the door key so I lost the awesome roll down with the key feature. Also, no remote locks, just manual key. But whatever, it drove fine, shifted smoothly, and was comfortable.
I'll start adding mods below and link the posts here in a table of contents.
Next plans are to get 4.88 gears and e-lockers - coming soon...
'99 manual SR5 occasional daily driver and weekend crawler build-00e0e_2ijbegqbnpt_1200x900-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20181229_2-jpg
rexassian is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 02:37 PM #2
Step 1 was remove the side steps and do some preventative maintenance. The idle got a little rough at times so I replaced the spark plugs w/ OEM set and new plug wires as well. That helped but didn't solve it.
Then it started dying at traffic lights at idle and I got a code about TPS so I replaced that and it helped, but still it was dying occasionally. So some searching and reading and I thought why not clean out the IAC.
Sure enough, the IAC was dirty AF and had a small chunk of RTV stuck in it. Cleaned everything up including the throttle body and put it all back together and it ran like a champ and idled great, right around 700 RPM.
Awesome!
At this point, I wanted better sound so I went to crutchfield and orderd up a Pioneer double din unit with carplay & android auto and 4 new speakers. Sorry, no pics but it was straight forward. I added a wireless steering wheel controller to make it seem like this car was somewhat modern...
Old 01-17-2020, 02:44 PM #3
infamousRNR's Avatar
infamousRNR infamousRNR is offline
infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light infamousRNR is a glorious beacon of light
Sicmods bro! Keep the updates coming!
1998 Desert Dune Toyota 4runner Limited 4x4 w/ factory e-locker
2000 BLACK Toyota 4runner Limited 4x4 w/ factory e-locker Build Thread
2002 Thundercloud Metalic Toyota 4runner Limited 4x4
Build Thread
infamousRNR is offline   Reply With QuoteReply With Quote
Old 01-17-2020, 04:23 PM #4
Talking
next I knew I wanted to run 35's so I went ahead and ordered them.
17x9 (4" back space) Vision Nemisis wheels and 35x12.5" Cooper Discoverer MTP tires. UPS guy didn't even want to drop them close to my garage and left them out on the street.
I mocked one up to see what I'm in for...
'99 manual SR5 occasional daily driver and weekend crawler build-20190329_1-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190331_114941-jpg
Old 01-17-2020, 04:29 PM #5
Now to make room I started with a 1.5" body lift from 4crawler. Simple enough...
Also, I wanted to make room early to ensure easy access to bolts and the stupid rear shock upper mounts so I could install my suspension lift with more ease...
And instead of worrying about the rear bumper, I got rid of it until I can build one.
'99 manual SR5 occasional daily driver and weekend crawler build-20190512_175137-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190512_162926-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190512_162900-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190512_162915-jpg
Old 01-17-2020, 04:41 PM #6
Next I noticed the rear axle seals are leaking...so, 5 hours of watching Toyota time and researching online and I got my axles taken apart and old seals removed. I didn't have a press so I opted to take the axles to a local shop to have them press on the new bearings, etc. However, and I should have insisted or taken it elsewhere, they refused to swap the inner seal ring direction as was suggested. At the time, I thought fine, I'll just not press the new seals in all the way (give or take a mm).
The seals held for 3 wheeling trips but are leaking again...
Old 01-17-2020, 05:11 PM #7
Finally it was time to put the lift on. I got the system1.2 with 2.5" long(er) travel radflo's. While I was in there, I wanted to change out all the other bushings and such so I added:
lower control arm bushings
new OEM lower ball joints
upper arms from SPC
new steering rack bushings from energy suspension
diff mount bushings from DuroBumps
I took the whole 3-day weekend over July 4th and got it all done thanks in large part to using my buddy's shop with two-post lift. I probably raised and lowered 20 times so it was VERY handy!
'99 manual SR5 occasional daily driver and weekend crawler build-20190706_180819-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-4runnercoils-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190707_142349-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190707_161435-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190705_175013-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190707_165653-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190707_165719-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190713_131117_stripped4-jpg
Old 01-17-2020, 05:13 PM #8
I started with the SPC arms in the C position and that rubbed badly, as you can see. After more tinkering, I set it all the way back at G as recommended in the SPC alignment thread : SPC UCA Alignment Sheets
and set my lower cam bolts to max caster to offset. Took it to Firestone for alignment and it drove great.
Maybe later I'll get those nice lower arms which move the ball joint forward 1" for more caster...
'99 manual SR5 occasional daily driver and weekend crawler build-20190713_132150_stripped-jpg  '99 manual SR5 occasional daily driver and weekend crawler build-20190714_203216_stripped-jpg
Old 01-17-2020, 06:15 PM #9
I took it wheeling a few times to a local place here in central texas called Hidden Falls. There's lots of easy-ish trails there and it's great for beginners. Everything was working fine...until it wasn't. See here:
Coolant valve broke / engine overheat
basically the combo of 20 year old plastic, 1.5" body lift, and still some flex from off-roading caused the plastic nipple on the heater control valve to break and I didn't notice it in time. You can check the thread, but I added about a 1" drop down bracket to the heater control valve to keep the hoses from flexing the plastic nipples and eventually causing this valve to break like the original. I would highly recommend for anyone running a body lift to do this, even if you don't have a problem, as it's cheap and easy insurance.
Yea, yea, don't have a body lift and this won't be a problem. I definitely took the easy way out to try and not have a bunch of fender hacking to fit the 35's. Now I paid for it...
Old 01-17-2020, 06:25 PM #10
I thought I got away easy after the coolant leak but a few months later (early december), I started having issues again : bad head gasket, fix or motor swap, want to keep manual trans
after a lot of reading on rebuilds and looking for swaps, I decided for now that I can't let it sit while I rebuild the motor as I know myself (and my wife) and it will end up on jack-stands forever. I usually like to get into the work but a motor swap or rebuild will take it out for too long and that is not what I want. I want it back to running a quickly as possible. So for now, I put some Blue Devil stop leak in it and thankfully it sealed up. Of course, there's no telling how long it will last or what other issues it will cause but I was willing to take the risk.
Back-up plan, keep looking for a low millage insurance auction car to swap the motor over in a (long) weekend. For instance, here's one that I'm waiting to start: https://www.iaai.com/VehicleDetails?...oadRecent=true . We'll see what it ends up going for but as of now, I think this is my best option if/when the stop leak lets go.
Old 09-21-2020, 10:51 AM #11
FINALLY, I had time to work on my runner again. This past week I replaced the rear axle seals, bearings, etc, with HUGE thanks to @weekendclimber for the awesome press tool loaner. It turns out at some point, someone had cut off the retainer rings/ABS gear and there were nicks and cuts on the axle. I ended up filling them with JB weld and pressing the new retainers and ABS gear on while it was setting. At this point, if I have to do the seals again, I'm going with a new axle, what a pain!
Also, I started the rear disk brake conversion. I have a bunch of 3/8" steel left over from my bumper work and will be making my own brackets using a plasma cutter (and drill press). For the conversion, I got all the parts from rock auto and ordered the e-brake and caliper flex hoses from @midcoma . Here's the parts I used:
Part NumberPart TypePrice EACore EAQuantityTotal
2003 TOYOTA 4RUNNER 4.7L V8
CENTRIC12144128 (121.44128)Rotor$ 17.67$ 0.002$ 35.34
2000 FORD MUSTANG 5.4L V8
ACDELCO18K2410Brake Bleeder$ 2.86$ 0.001$ 2.86
BENDIXSBC627ABrake Pad$ 17.28$ 0.001$ 17.28
POWER STOPL4825ACaliper$ 54.79$ 27.481$ 82.27
POWER STOPL4824ACaliper$ 54.79$ 27.481$ 82.27
ShippingGround$ 34.97
Tax $ 20.40
Order Total $ 275.39
the bleeders were just in case and are cheap for a pack of 10 so why not. Pads are bendix organic and hopefully will be OK, I'm not looking to lock up the rear tires or anything. Looking forward to getting this all together, hopefully by next weekend, and get back out on the trails.
'99 manual SR5 occasional daily driver and weekend crawler build-bd6abb9b-0ff4-4d44-b2cb-7d6c7c099a1d-jpg
1999 SR5 V6 manual trans 4x4 - Lifted on 35's - Build thread
Old 09-21-2020, 04:44 PM #12
so that peg-board was a bad choice for template, too easy to break. Work was slow and it was very rainy here so I tried to create my own template on tinker cad. I wanted the calipers oriented around 45 degrees to make bleeding easy (in theory) rather than almost vertical as I have in the above picture. Here's what I drew up. For some reason, I couldn't upload the PNG format so compressed jpg it is for now. PM if anyone wants the original PNG, or SVG files for direct printing. I'm planning on cutting this out of sheet metal to test and adjust from there before plasma cutting out of 3/8" steel and figuring out the offsets needed for the spacers.
'99 manual SR5 occasional daily driver and weekend crawler build-caliper_bracket_v1_web-jpg
Old 09-21-2020, 05:08 PM #13
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Tax $ 20.40
Not sure if you mentioned doing this but you might want to check the rear diff breather.. sometimes leaking seals indicate a clogged breather valve. there is no room for expansion/contraction. Truck looks good though man.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 09-21-2020, 05:52 PM #14
Yes! Great, point, I keep putting off the extended breather and checking for clogs. Thanks, I'll clean it up and extend it.
Old 09-22-2020, 03:30 AM #15
papabeach's Avatar
papabeach papabeach is offline
papabeach has a spectacular aura about papabeach has a spectacular aura about papabeach has a spectacular aura about
papabeach's Avatar
You are getting after it, great mods! I look forward to following your build.
(SOLD)1999 4Runner SR5, 5spd-R452d 5th, 4x4 “Highlander”
Supercharged, Lifted, Dual cased, Dual Locked, Geared, Armored and more...
Papabeach Mod Thread
(SOLD)1997 Land Cruiser FZJ80
1979 FJ40L-KC
papabeach is offline   Reply With QuoteReply With Quote
build , gen , key , manual , rear
Meet Blondie --- 2002 Golden Pearl daily driver/weekend warrior build OrRunner 3rd gen T4Rs 11 06-25-2019 07:16 PM
'03 Daily Driver Build/Maintenance Bml_merris 4th Gen T4Rs 23 12-25-2018 11:04 PM
99 T4R. A modest daily driver build diponyou 3rd gen T4Rs 34 07-06-2014 12:35 PM
Daily Driver Weekend Warrior, Whats the best tires in your opinion? 1sick4runner 3rd gen T4Rs 35 02-18-2014 01:30 PM
New build of a daily driver blueblur1984 3rd gen T4Rs 8 05-07-2013 02:54 AM
