Old 01-11-2021, 12:25 PM #16
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Originally Posted by FabMMoi View Post
Update: got the Nissen to my garage, and apparently the automatic transmission connection doesn't match... looks like it'll be fun.
If I was you I would install an aftermarket transmission fluid cooler and bypass the radiator
Old 01-11-2021, 12:50 PM #17
FabMMoi FabMMoi is offline
FabMMoi is on a distinguished road
Confirmed: the automatic transmission cooler connections won't match mine (see picture below). Is that something I can fix with some sort of adapters or does it need an entirely different model?
Compatible radiators for a 3.4L 3rd gen 4Runner?-1-jpg  Compatible radiators for a 3.4L 3rd gen 4Runner?-2-jpg  Compatible radiators for a 3.4L 3rd gen 4Runner?-3-jpg  Compatible radiators for a 3.4L 3rd gen 4Runner?-4-jpg
FabMMoi is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 01:00 PM #18
It is quite an ordeal to get a matching part for this car in the UK, and I'm still just trying to figure out if I have a blown head gasket, so I'm not entirely sure I should invest in more parts before even getting there?
Old 01-11-2021, 02:45 PM #19
Real Name: Patrick
Real Name: Patrick
Good point. If you are just trying to get it to where you can drive it some (not far or for long) you could use a piece of metal pipe to loop the transmission cooler lines together. Just a thought if you are in a pinch
Old 01-12-2021, 04:47 AM #20
I'm mainly trying to start a pressure test (short use indeed), but overall it's better not doing the same job twice, so I'll probably just return that part and find another one, hoping for the best.
Old 01-12-2021, 01:18 PM #21
Just a random thought at the moment (because I'm fearing it's the cause of my blown radiator), how come replacing a head gasket on a 4Runner is that immensely labor expensive (compared to some other cars)?
Old 01-13-2021, 10:33 PM #22
Mgyver1's Avatar
Mgyver1 Mgyver1 is offline
Mgyver1 is on a distinguished road
Mgyver1's Avatar
The ‘96-‘09 Land Cruiser Prado (J90 & J120) and the Toyota Hilux 167 series pickup came with the 3.4L so you might be able to find parts over there for it.
2000 Limited. Lifted....finally!
www.OverlandNV.com
Mgyver1 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 01:50 AM #23
Endlessblockades's Avatar
Real Name: Blair
Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold Endlessblockades is a splendid one to behold
Real Name: Blair
Just curious, are (used/junkyard) engine swaps relatively easy in the UK or are they mired in regulations, in addition to lack of donors, etc.?
I like the idea of joining/capping the transmission cooler inlet/outlet while doing a head gasket test. I have used a simple and cheap kit in the past that tests for combustion gasses in the coolant caused by "Blown Head Gasket, Cracked Head or Block, Pulled Bolts or Studs, or Warped Sealing Surfaces" It put my mind at ease on my 2nd Gen that had a mysterious fluid loss before I sold it to a friend. Turned out to be a faulty heater bypass valve.
Like this: Amazon.com: Block Tester BT-500 Combustion Leak Test Kit - Made in USA: Automotive
Old 01-14-2021, 12:48 PM #24
Not sure how complex that would be here, just moved here a couple years ago with my Canadian truck after driving it all the way to Panama
Lack of donor would certainly be the first issue in mind. I know less than a handful of scrapyards on eBay with 3rd gen Hilux Surf (all RHD diesel) and never seen any 4Runner anywhere. 2nd gen is a bit easier as it was sold here (probably different specs/trims still).
Problem for the 3.4L in Europe is that, in the eventuality it existed, it just wouldn't sell because of the gas price. I remember when meeting other overlanders during our trip, most Americans would always tell me they liked the 4th gen better because of the V8, while ALL Europeans would drive 4 cylinders of whatever vehicle they had (often diesel). And A/T practically didn't "exist" until 2000 in Europe.
Old 01-15-2021, 11:44 AM #25
Update: radiator finally changed, and the pressure seems to have been a false alert with the water pump doing a bit of extra work on startup! Up and running again, thanks all
3.4l , compatible , country , parts , radiators
4Runner Bolt pattern compatible mike4Runner2003sr5 4th Gen T4Rs 1 10-08-2013 09:36 PM
5100s made for FJ compatible with 4Runner? danny Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-03-2011 08:30 PM
T100 Tranny cooler compatible w/4Runner? Kire4Runner 3rd gen T4Rs 0 01-07-2006 12:39 AM
