Old 01-05-2021, 06:52 AM #1
FabMMoi FabMMoi is offline
FabMMoi is on a distinguished road
Compatible radiators for a 3.4L 3rd gen 4Runner?
Hi guys,
Like a few others my 96 4Runner's radiator splitted (200k miles), and I'm looking to get another one to replace it. I'd like to keep it inexpensive as we need to run pressure tests, not knowing if the head gasket is cracked or other pressure-inducing expensive issue yet.
Problem: I live in the UK and own the only 3.4L V6 in the country, so finding parts can be a bit of a challenge.
There are a handful of Japanese Hilux Surfs for parts in the country, some diesel and some 3.0L petrol or less, so I was wondering what specs radiators are compatible with my model?
note: although I expect that to be mostly engine-dependant, I've seen small assembly differences between the Hilux Surf and 4Runner parts, as well as LHD/RHD differences. And I don't know if the Surf existed as a 3.4L...
If none of these work, would anyone in the UK have a part sourcing recommendation? Euro Car Parts doesn't have that, for instance.
Thanks in advance for helping me save our beloved Runner!
FabMMoi is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 09:22 AM #2
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
Have you tried Partsouq.com?
They ship to pretty much all over the world. Their prices are really good but larger items can get pricey because of shipping costs from Dubai.
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 11:01 AM #3
They don't seem to have the radiator for my model unfortunately ("Not Available").
Now, I'm pretty sure I can find the part matching my trim online (ebay and such) so there are other options than this specific site. But since they're not OEM or expensive, knowing if I can use another trim's part would definitely broaden the options.
Old 01-05-2021, 11:30 AM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Try looking for denso part number 221-0508
Old 01-05-2021, 01:34 PM #5
Diesel radiators have the hose connections reversed (left vs. right on the top and bottom). Any of the gas motor radiators should work - there is a chance that there are 2rz/3rz Surfs in the UK or Europe. LHD vs. RHD won't matter for the radiator.
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-05-2021, 02:04 PM #6
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Hilux Surf was available with the 3.4L 5vz-Fe.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 09:15 PM #7
jeff88 jeff88 is offline
jeff88 is on a distinguished road
FWIW, the 5VZ came with three (at least) different sized radiators: short, medium, long depending on the vehicle. I tried to install a short radiator, but I could never get a radiator cap that would hold. It kept trying to spin out which would allow coolant to seep out. It never burst, but it would turn about a quarter turn. You might be able to try looking at one of the other vehicles, but YMMV with how well it works.
The Renewal of Gaia 1999 4Runner SR5 Highlander IJM
FJ Wheels | Goodyear Wrangler Fortitude HT | TBU
Rancho Shocks & Struts | OME 880 Front | OME 906 Rear | ES Polyurethane Sway Bar Bushings Front/Rear | ES Polyurethane Steering Rack Bushings
Clear Headlight Corners | '98 Rear License Plate Frame & Emblem Delete | Stubby Antenna | Trans Cooler Bypass
jeff88 is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 06:22 AM #8
Thanks for the heads up!
=> I found this, a Nissens at a good price that, according to the description, is a replacement part for my 1640075180 (got the part code from part.toyota.com, which tells me it's been superceeded with 16410AZ011 since then). Do you think that's good?
New Nissens Engine Coolant Radiator Toyota 4 Runner 95- Land Cruiser 90-96 5707286219861 | eBay
@Malcolm99 the 3rd gen Surf wasn't sold at all in the country, only models you'll find here are Japanese import (RHD), and apparently none of them are 3.4L (by choice maybe, or not available in Japan?).
@phattyduck yes there probably are some 2RZ and 3RZ, that's what I was wondering: would part from these cars match?
@jeff88 : interesting. Was the radiator cap included or did you try to install yours onto the new radiator? What if the radiator cap comes with the radiator itself?
Old 01-06-2021, 06:27 AM #9
Thanks @Bad Luck The Denso is 3 times the price in the UK than the Nissens linked above (a bit more than the OEM), do you think the Nissens would do the job as well?
Old 01-06-2021, 11:13 AM #10
Real Name: Patrick
Real Name: Patrick
I think that should bolt up and work. I compared it to Koyo which makes a thicker core radiator without an internal transmission cooler: Koyorad Racing - Products : High Performance Racing Radiators and the measurements convert to within a few mm's.
Old 01-06-2021, 11:18 AM #11
Thanks that's awesome. I'll order it and hopefully the head gasket don't let us down. Cheers
Old 01-06-2021, 12:59 PM #12
Malcolm99's Avatar
Malcolm99's Avatar
We get the JDM Hilux Surf as a RHD with a 5vz-fe 3.4L imported all the time in Canada.
Old 01-06-2021, 01:15 PM #13
All US 4Runners came with the "long" radiator (4 or 6 cylinder). The medium and short radiators are only available on the Tacomas, and would not (likely) be available outside the US.
Old 01-11-2021, 01:48 AM #14
I originally tried my existing cap, but when it didn't work I started searching for others ones, including getting help from the dealership. They were nice enough to let me try a couple and return them when they didn't work and then I gave up and went back to "stock".
Old 01-11-2021, 11:50 AM #15
Update: got the Nissen to my garage, and apparently the automatic transmission connection doesn't match... looks like it'll be fun.
3.4l , compatible , country , parts , radiators
4Runner Bolt pattern compatible mike4Runner2003sr5 4th Gen T4Rs 1 10-08-2013 09:36 PM
5100s made for FJ compatible with 4Runner? danny Engines / Suspension / Wheels / Tires / Audio / Accessories 2 04-03-2011 08:30 PM
T100 Tranny cooler compatible w/4Runner? Kire4Runner 3rd gen T4Rs 0 01-07-2006 12:39 AM
