Old 03-02-2023, 06:35 PM #16
connorms's Avatar
connorms connorms is offline
connorms will become famous soon enough
connorms's Avatar
Kind of off topic, but I figured I might as well ask here since it's the only current thread related to valve covers. When I last did my valve cover gaskets (about 3 months ago, but have only put maybe 20 miles on it since), I was torqueing down my valve cover bolts using ft-lbs instead of inch-lbs. I guess my torque wrench isn't very accurate at such low numbers, and I managed to snap one of the bolts. As far as I'm aware it's not leaking or anything, but just knowing I have a broken bolt down there is bugging me so I plan on going back in to replace it. My question is that is there anything in there that's single use? I was planning on replacing all of the bolts just to be safe, but is there anything else I should replace just because I took it apart? Mainly looking to avoid doing it a third time, but I already replaced all the additional parts Tim recommends doing. My idea was that I should be ok if I just scrape off the old RTV and replace it, then replace the rubber washers. Am I missing anything else?
Long travel '97 Limited - build thread
connorms is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 06:48 PM #17
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
Are you saying you converted the inch lbs into foot lbs or that you use the wrong torque period?
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 07:03 PM #18
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
This job will take you a while just to replace the valve cover gaskets. You will find that driver side cover will fight you the most to remove it and the plastic cover for the wiring loom will most likely break. Absolutely don't go ham on the cover bolts - thats how I broke my factory cover and had to get a used one at the yard. Recommend inch pounds on a 1/4 in" torque wrench. My Felpro's are on year 4 and are doing fine although I haven't really taken a good look.
2000 4Runner Limited 4x4 V6
Old 03-02-2023, 07:05 PM #19
spartacus's Avatar
spartacus's Avatar
Replace the pcv grommet while you are in there, also cleaning the throttle body is easier. More access to the heater control valve if it's old.
edit: Good time to look at the fire wall side hoses also.
Old 03-02-2023, 07:18 PM #20
connorms's Avatar
connorms's Avatar
I converted it from inch lbs to foot lbs, but the bolt snapped before it was able to torque down all the way. The rest of them were ok, but the one just kept turning without the torque wrench clicking. Right as I started to think "this feels way too tight" the head snapped off... I'm not sure if I really need to replace it since I'm not noticing any leaks, but it's bugging me knowing that I'm missing a bolt down there so I plan on fixing it when I don't have any other projects to work on.
Old 03-02-2023, 07:44 PM #21
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
I'd find a way to extract the broken bolt and replace it without removing the valve cover.
Speedy is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 08:24 PM #22
Sarki Sarki is offline
Sarki has a spectacular aura about Sarki has a spectacular aura about
Originally Posted by Speedy View Post
I'm about to tackle this on my 02. Book time is 3 hours. What is it about this job that seems to take people days to complete it? I'm OCD and will be cleaning the valve covers thoroughly and probably painting them, but how does 3 hours become 8 or 12?
When I did this job on my 02 a few years back I took my time and became a proud member of the weekend club.
Replaced all related parts as noted by Timmy in his earlier post and also went with OEM parts.
Turn on some good tunes, get your tools ready, take a bunch of before pictures as well as some along the way and take the opportunity to clean up engine bay, inspect all hoses wire connections/plugs belts and everything else under the hood.
I took notes documenting my steps so it’s easier next time around. I enjoy the work so no reason to rush through it.
2002 SR5 Sport 4WD
Sarki is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 09:28 PM #23
brillo_76's Avatar
Real Name: Jon
brillo_76's Avatar
Real Name: Jon
When I did the 1997 limited. We resealed the entire engine minus the head gaskets. I can tell you it's alot easier to do that with the engine out..
I do have reseal my 1998 engine yet. As it's bad enough that if you drive around with the windows down you smell the oil burning.
I probably should check the valve clearance as it's at 290k. I did the timing belt a while ago to fix a coolant link.
The entire front of the engine is all resealed now too.
I use toyota oem gaskets and seals for the valve cover project.
Old 03-03-2023, 08:43 AM #24
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
For anyone wondering, the Beck Arnley kit I got was identical to the Ishino kit. Ishino isn't OEM, but it is made in Japan if that does the job for you. You can also get Japanese made NOK cam plugs (they make OEM) for much less in a FelPro package. Still haven't found anything better than OEM intake gaskets or PCV parts.
Old 03-03-2023, 09:24 AM #25
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
As long as your valve cover gasket is still flexible (which it should be at only a few months old) I would feel fine reusing it.
Old 03-03-2023, 01:23 PM #26
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
there is also a gasket in the oil filler. i replaced mine on one I did years ago.
I used the Ishino gasket set at the time and never had a problem.
I will be doing my current 4runner vc gaskets etc this spring/
Old 03-03-2023, 04:47 PM #27
mtbtim's Avatar
mtbtim mtbtim is online now
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I'd say to do a careful job cleaning everything throughly and also painting them, it will be at least a 5 hour job.
mtbtim is online now   Reply With QuoteReply With Quote
Old 03-04-2023, 01:00 PM #28
Spiker Engineering's Avatar
Spiker Engineering Spiker Engineering is offline
official vendor
Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of Spiker Engineering has much to be proud of
official vendor
I'm thinking of painting mine - any recommendations on which paint to use?
High Lift Hood Struts | Ultragauge/Scangauge Mounts | Phone Mounts
Custom 3rd Gen 4Runner products | 100% designed, fabricated, and assembled in the USA
https://spikerengineering.com
Spiker Engineering is offline   Reply With QuoteReply With Quote
Old 03-04-2023, 01:34 PM #29
Speedy's Avatar
Speedy's Avatar
I've been looking at engine enamel. Ideally we'd have them powder coated but I don't really wanna wait a week with the truck torn down for that.
Lots have used VHT engine enamel with good results. I'm just trying to decide on a gloss silver for OEM look or wrinkle red for hot rod.
Old 03-04-2023, 01:41 PM #30
official vendor
official vendor
Good suggestions, thanks. What do you think about a DTM paint like the POR15? https://www.amazon.com/POR-15-45918-...3&sr=8-22&th=1
I wonder which would give the best protection against chemicals like throttle body cleaner etc (powder coat is probably the best approach).
cover , engine , gaskets , miles , valve
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Valve Cover Gaskets mustangaustin34 3rd gen T4Rs 4 06-10-2013 11:48 AM
Valve Cover Gaskets 4RUN0326 3rd gen T4Rs 6 04-22-2013 02:32 PM
Which Valve cover gaskets? mitfan311 Maintenance/Detailing 0 11-15-2009 09:43 PM
DIY Valve Cover Gaskets MHartley Classic T4Rs 7 01-16-2009 04:56 AM
