Old 01-05-2021, 02:46 PM #1
BoomerBob's Avatar
BoomerBob BoomerBob is offline
BoomerBob will become famous soon enough BoomerBob will become famous soon enough
BoomerBob's Avatar
Best Valve Cover Gaskets 3.4L?
Hi. Haven't posted in a while. I did a search but nothing turned up to my question about the best valve cover gaskets for the 3.4L V6.
Mine are leaking on an reman engine with just 5k miles. Needless to say I'm not happy about having to go back into the engine with so few miles on a basically new engine.
Since I have to though I'd like to use the best quality gaskets available so I hopefully don't need to do it for at least 100k miles.
An independent mechanic says he has the best luck with neoprene valve cover gaskets. Does anyone make these for the T4R 3rd gen.
2001 2wd - Daily Driver
BoomerBob is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 03:19 PM #2
spartacus's Avatar
spartacus's Avatar
Talking
I've used oem and it's been solid for over 100k miles. Some have used felpro and have been fine.
Old 01-05-2021, 03:50 PM #3
FD7683 FD7683 is offline
FD7683 will become famous soon enough FD7683 will become famous soon enough
I used Felpro with NAPA o-rings that go on the bolt and it has been fine ever since. I would use OEM if you want longevity.
2000 4Runner Limited 4x4 V6
Old 01-05-2021, 03:55 PM #4
BoomerBob's Avatar
BoomerBob's Avatar
Thank you. I'll use that info to buy the next set.
Old 01-05-2021, 04:05 PM #5
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I've used both felpro and OEM, OEM seems a lot softer and works very well. Since its new you might get away with reusing the washers, and maybe even the spark plug tube seals if there is no oil in the tubes, that's a big maybe, I would remove and reseal the half moons and even the Cam plugs just to be sure, you will want to use a oil specific sealant for the half moons insuring they are positioned flush and where the VC gaskets goes over the contours of the cam shaft bearing caps.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 04:46 PM #6
Honda pc Honda pc is offline
Honda pc is on a distinguished road
I also plan to do this.. currently at 270k miles and its leaking and messy all over inside... I plan to power pressure wash all the engine oil parts and then do the valve gasket job, tune up... I am going OEM parts... I plan to follow this thread posted here on this forum...its very detailed and has all the oem part ##.. and also follow Timmy toolman youtube.
Replacing Valve Cover Gaskets - A True Write Up - **PICTURES**
Honda pc is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 05:40 PM #7
nissanh nissanh is offline
Please use OEM and TOYOTA FIPG. Also, apply a small film of FIPG to the lower end of the cylinder head/valve cover mating surface.
Old 01-05-2021, 05:48 PM #8
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Oem with everything.. McGeorge toyota parts is one of the less expensive sites.
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 06:05 PM #9
Malcolm99's Avatar
Malcolm99's Avatar
That FIPG red is really expensive, it was grey sealant from the factory for the VC, only other Toyota sealant available is black that I'm aware of, it's very good I'm sure but pricey. I've used Permatex Ultra grey on 4R and Mitsubishi VC, Oil pans, differentials, Manual Transmission halves, Auto trans pans, oil pump housings and many other components, never had a problem, just make sure your prep work is immaculate.
Old 01-06-2021, 11:47 AM #10
BoomerBob's Avatar
BoomerBob's Avatar
Thank you.
Old 01-06-2021, 12:25 PM #11
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Just use OEM parts. Also, this job isn't just valve cover gaskets if you want to do it right. You should also be replacing the cam plugs on the rears of the heads, you should be removing and resealing the 4 half moons on the heads, you should replace the spark plug tube seals, you should buy new valve cover bolt washers, you should replace both plenum gaskets, you should consider replacing the throttle body gasket, you should consider replacing the PCV valve and grommet, you should consider replacing the spark plugs and spark plug wires while doing this job and you should consider cleaning your throttle body, IAC, and MAF sensor while doing this job.
In regards to the RTV or FIPG to use, I recommend you go with the Toyota 103 FIPG (black) The red FIPG is for transmission, transfer cases and differentials. Don't do what the write-up suggests and put a huge bead of RTV on the heads. That is totally unnecessary. Ramon did a great job on his write-up for this job, but his application of FIPG was pretty ridiculous and way overkill. You only need to put it over the half moon junctures and in the corners of the cam humps. You also need to put some onto the cam plug collars when installing the new cam plugs. The cam plugs Do Not require FIPG on them like some guys do. The cam plugs have a rubberized outer surface and that makes a seal with the head and collar just fine. Adding FIPG to the cam plugs is just going to make it a nightmare to clean out the old FIPG at the back of the heads if you ever have to perform this job again. Good luck!
Old 01-06-2021, 01:23 PM #12
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
Agree with above, I would do as much as I can while Ive got it all apart.
just remeber torque for the valve cover bolts is in INCH POUNDS. You can convert to foot pounds. But these covers crack easy, luckily not me yet.
there are other parts of your car that use inch pounds for torque, so good excuse to buy one I had one from working on motorcycles.
Old 03-02-2023, 04:56 PM #13
Speedy's Avatar
Speedy Speedy is offline
Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough Speedy is a jewel in the rough
Speedy's Avatar
I'm about to tackle this on my 02. Book time is 3 hours. What is it about this job that seems to take people days to complete it? I'm OCD and will be cleaning the valve covers thoroughly and probably painting them, but how does 3 hours become 8 or 12?
Speedy is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 05:21 PM #14
Rushthezeppelin Rushthezeppelin is offline
Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about Rushthezeppelin has a spectacular aura about
If your OCD and take your time the first time through a job I'm betting you want to budget a whole weekend for this. I haven't done anything on my engine yet but I know it took me 8 hours to do my first axle seal job on the rear because I took my sweet time and quadruple checked everything. A big chunk of that granted was getting those damn drums back together...drum brakes suck to work on. Second side was about half of that because I felt more comfortable with the job. Also I would say heed Tim's advice and have the "while you're in there" mentality. The fewer times you have to take these old trucks apart the better and if you don't know the condition of other components that you can easily replace while you are there then why not take care of it.
'98 SR5 5 Speed
Rushthezeppelin is offline   Reply With QuoteReply With Quote
Old 03-02-2023, 05:31 PM #15
Speedy's Avatar
Speedy's Avatar
Yeah I've got all new parts coming OEM Toyota seems best. Valve cover gaskets, spark plug tube seals, PCV gromet, fipg, half moons, cam plugs, intake gasket (mine's supercharged), and vc bolt washers. I clean my MAF pretty regular so it's probably good, and I need to see when I last replaced the spark plugs but that's easy so I'll wait and do that when needed.
cover , engine , gaskets , miles , valve
Any other gaskets I should replace when doing to valve cover gaskets? michaelreed 4th Gen T4Rs 0 07-23-2013 09:08 AM
Valve Cover Gaskets mustangaustin34 3rd gen T4Rs 4 06-10-2013 11:48 AM
Valve Cover Gaskets 4RUN0326 3rd gen T4Rs 6 04-22-2013 02:32 PM
Which Valve cover gaskets? mitfan311 Maintenance/Detailing 0 11-15-2009 09:43 PM
DIY Valve Cover Gaskets MHartley Classic T4Rs 7 01-16-2009 04:56 AM
