Old 01-05-2021, 08:25 PM #1
3bears 3bears is offline
Real Name: 3 Bears
Real Name: 3 Bears
2001 heater fan on
so I HAD a 2000 4runner and now ( very recent) a 2001. I noticed that with the heater fan switch off, and the heat control set to anything....the fan runs low. Even if fan control pointed to off. Its not a limited with the automatic heating system...its all turn knob stuff. It does shut off with key off.
Is this normal for a 2001 or 2002. maybe it was typical of the 2000 just dont remember
Old 01-05-2021, 08:32 PM #2
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
Check to see that you have recirculate turned on. If it's off it will blow some air from the outside. If it bothers you enough turn it to defrost mode so it doesn't blow in your face.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 08:49 PM #3
spartacus's Avatar
spartacus's Avatar
We are not as cold as Alaska but I don't like warm air blowing so I keep it on recirculation and have my rear heater going which makes it confortably warm.
Old 01-05-2021, 09:46 PM #4
Dom8706's Avatar
Dom8706 Dom8706 is offline
Dom8706 is on a distinguished road
Dom8706's Avatar
+1 to what Zingvs said.
I thought the same thing with my 02. Why am I still getting air pushing through with everything off. It's was cause the recirculation was off and it was just air from outside coming in.
02 T4R SR5 3.4L AT 215k - TJM Front Bumper - Coastal Offroad Rear Bumper - 914Z Ditch Lights w/ CBI brackets - Ebay Snorkel - Airaid MIT - Big 4 - B&M 70268 - Complete Suspension Rebuild - OME 881/906 Coils - OME 90004/60028 Shocks - ToyTec 1" BL - SS Diff Drop/Panhard Bar/Rear Body Mounts/Hi Lift Mount. Plus other stuff.
Dom8706 is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 10:30 PM #5
texadelphia texadelphia is offline
texadelphia will become famous soon enough
If the fan is indeed on and it's not just air being pushed through when the truck is moving it MIGHT be the blower motor resistor. Typically when it goes bad certain speeds stop blowing but maybe it could cause it to not stop blowing? I know this can happen with a radiator fan resistor if it gets a short.
Sent from my moto x4 using Tapatalk
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 01-05-2021, 11:02 PM #6
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
Maybe just a dial issue, out of sync or worn out contacts within the dial. I'm sure you didn't leave the rear heater on low by accident making the noise lol.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-06-2021, 02:04 AM #7
gamefreakgc's Avatar
Real Name: Jerod
Real Name: Jerod
Check your rear heater. I've had this before only to realize I left it on. It's on the back of the center console near the cupholders for the rear seats if you have one. Like spartacus, I also keep it on in the winter as it keeps the interior warm without a hot hair dryer going in my face all the time.
326WHP 347TQ
Old 01-06-2021, 03:26 AM #8
Real Name: 3 Bears
Real Name: 3 Bears
not the recirc button, checked that after the posts above, makes no difference if
on or off,
not rear heater, been fooled on that one before too
when its in off, it is going low speed, turn it to speed 1 and its the same speed, all other speeds do increase.
also makes no difference if in defrost or heat floor mode, or any of them inbetween.
maybe it is a bad resistor, or bad switch....ill just let it go for now.But Im happy its working. up here this time of year its always on, this was prob first time since owning this rig ( month) that Ive probabally turned it to the off position and that was because I was playing with radio balance controls.
I do know this spring I need to pull the motor and clean the squirrel cage out ( noise esp on high) so Ill check the resistor then.
Luckily when I shut truck off, it shuts off so now power drain.
thanks
Old 01-06-2021, 05:58 AM #9
caren22 caren22 is offline
caren22 is on a distinguished road
on or off,
I think that All-in-One Do my Homework Assignment for me writing Service. Order much needed timely writer’s help could be better
Luckily when I shut truck off, it shuts off so now power drain.!
thanks
the last thing you could check up is the circuit breakers
if they are ok then it’s just some kind of safety measure or inner setting
cacacaren
caren22 is offline   Reply With QuoteReply With Quote
control , fan , heater , knob , turn
2001 Springs fit 2001? tbryanh 3rd gen T4Rs 1 12-24-2016 02:44 PM
Urgent question on 2000 vs 2001 heater panel Ghostrider 3rd gen T4Rs 1 12-08-2014 12:39 PM
heater foonanas Classic T4Rs 4 01-07-2011 09:14 PM
Heater Problems - 2001 Limited 4Walker Maintenance/Detailing 1 02-20-2008 12:11 AM
Heater fan R & I... AZrunr 3rd gen T4Rs 2 02-24-2005 12:06 AM
