Old 01-08-2021, 10:29 AM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Cost effectiveness of LCA vs bushings if having a shop install
So, I plan on taking my truck in for LBJ's and I know the LCA bushings need to be replaced as well so I figured I'd have them done at the same time. I was looking at the price of the bushings alone vs an LCA that comes with new bushings already installed and the difference is ~$125 per side. I was wondering how much labor that saves at the shop? My thought was that if it cost ~$50 per side or so to have them press out the old bushings and press in the new ones, that makes the difference per side $75 to replace my 20+-year-old LCA with a brand new one, which seems like a solid investment for keeping the truck long term. Thoughts?
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 10:55 AM #2
I paid 1200 to have bushings installed in my SR5. I tried but couldn’t get the cam bolts loose.
That price was labor, new cam assembly’s and a wheel alignment. I provided the bushings
Old 01-08-2021, 11:02 AM #3
Captsolo Captsolo is offline
Captsolo will become famous soon enough
The mechanic at the alignment shop told me to get them with bushings assembled. I just saw this on Amazon. Note the wheel bearing hubs - when you get your wheel bearing failure.
I would not do wheel bearings until you have one go bad. It took a good mechanic two hours of hammering to replace just the bearing.
Amazon.com: Detroit Axle - 14pc Front Upper Lower Control Arms w/Ball Joints Inner Outer Tie Rods w/Boots, Sway Bar Links & Wheel Hub Bearings for 2003-2009 Lexus GX470/ Toyota 4Runner 4WD - See Fitment: Automotive
Captsolo is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:55 PM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Not all LCA's & bushings are created equal, I did what your speaking of went aftermarket big mistake.
Had less than 10k mi, bushings worn enough to mess with alignment, the aftermarket arm was made of thinner material.
I'd stick with OE Arms, OE bushings or whiteline.
Old 01-08-2021, 01:32 PM #5
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If a shop is doing the work I would supply them with a complete OE LCA. And before you take it in, mark and loosen up your LCA adjusters making sure the Cam sleeves all move freely incase you need to order a few to complete the work and have it aligned. This entire job can be done at home, and you could reuse the LCA and put whiteline or OE bushings in, change out LBJ's and clean up the adjusters and go for an alignment and probably save 1000 or more in labour depending on the shop and the condition of the adjusters and LCA ofcourse. If you do it yourself you will have time to clean up and paint the original LCA which most shops won't do unless you requested it adding to the cost. Or pick up used OE LCA's and install bushings of your preference and send them to the shop. I would be asking for a quote from the shop for either route to help make a decision.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 01:41 PM #6
Real Name: Mark
Real Name: Mark
Thankfully I kept my old LCA's.
If your Cam bolts are stuck, Diablo Blades and sawzall work wonders.
Aftermarket arms I tried bushings could not be changed, made in China.
Old 01-08-2021, 02:28 PM #7
T4topher's Avatar
T4topher T4topher is offline
T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light T4topher is a glorious beacon of light
T4topher's Avatar
Watch the Timmy the toolman video, you can even use your Oem bottle jack to push out the old bushings lol.. doesn’t get much easier than that. I do recommend wrapping a ratchet strap around the lca when you use the bottle jack though so it doesn’t bend. I bent mine a tiny bit and I ended up using my floor jack against my work bench to unbend it..
T4Tophers build (click here)
T4topher is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 03:02 PM #8
RandyBobandy's Avatar
RandyBobandy RandyBobandy is offline
RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice RandyBobandy is just really nice
The hardest part of doing the bushings is when things are seized up with rust, if your vehicle isn’t very rusty it will be much easier. I wouldn’t use a bushing that isn’t either oem or poly like white line or energy suspension, aftermarket rubber bushings are junk
RandyBobandy is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 03:40 PM #9
Malcolm99's Avatar
Malcolm99's Avatar
Living in the rust belt, although my vehicle has little to no rust, I measured the distance between the lower control arm ends, soaked the ends in acetone and ATF, heated it up with oxy/map gas, and then I striped the OEM bottle jack, realizing there was no way they would come out I changed my attack, I then proceeded press the rubber out and VERY carefully cut the bushing sleeve at the strongest part of the the LCA, tapped the sleeve out and pressed the new bushings in.
Old 01-08-2021, 03:56 PM #10
Smile
This method is pretty much what I did, only difference is mine were rustier so I burned out the bushing, cut the sleeve, then used a chisel on the edge of the sleeve, rolling it over until it came out.
Old 01-08-2021, 04:00 PM #11
Jubsz Jubsz is offline
Jubsz is on a distinguished road
As mentioned, LCAs and Balljoints are not something to mess with here and most aftermarkets are junk. It will cost you to have them replaced properly but it is better than getting into an accident. Look on the forum for examples of aftermarket ball joints failing. Take a look at the video below to show bad aftermarket bushings at 22k miles. The toe change under braking is pretty scary...
Jubsz is offline   Reply With QuoteReply With Quote
Old 01-12-2021, 04:29 AM #12
I absolutely plan on buying an OE LCA so that I don't have to worry about the aftermarket garbage. I'd love to do it myself but I'm living on 4 hrs of sleep nightly and a couple of hrs of personal time per week until I take my board exam in May and I don't want to put it off until then.
Overall, it sounds like it will be better to just buy everything assembled and have them just swap the new LCA's in instead of replacing the bushings.
99' SR5 HRU
Old 01-12-2021, 09:46 AM #13
I tried doing it myself and broke my pipe I use as a cheater bar and then broke my breaker bar My impact wouldn’t budge the LCA bolts. I was happy to have someone deal with the rust.
Old 01-12-2021, 11:06 AM #14
T4R2014's Avatar
T4R2014 T4R2014 is offline
T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold T4R2014 is a splendid one to behold
T4R2014's Avatar
Just buy a new LCA. Especially if your 4Runner has come from the rust belt, then it is just a massive waste of time to save $75. You'll lose than money in additional labor to press out the old garbage.
Old 01-12-2021, 11:37 AM #15
Real Name: Mark
Real Name: Mark
OE LCA, 4 hrs of sleep nightly couple of hrs of play board exam in May and I don't want to put it off....
Good call, Ace Exam in May will make up out of pocket at the moment I think, won't crash along the way.
Good Luck
Edit : $225 for loaded LCA not bad at all.
bushings , difference , lca , press , side
Cost to Install Bilsteins? apache67 3rd gen T4Rs 6 01-17-2020 08:46 AM
cost of suspension install hinmo24t 4th Gen T4Rs 33 10-03-2019 03:23 PM
How much would my lift install cost cgill00 5th gen T4Rs 29 01-24-2019 09:53 AM
Cost ARB air locker install? dhatcher General Discussions 30 02-14-2017 04:12 PM
How much should a lift kit install cost for a shop to do it? medicrn 4th Gen T4Rs 4 01-26-2013 07:15 PM
