Old 01-08-2021, 11:09 AM #1
CWccw CWccw is offline
CWccw is on a distinguished road
running 285s, what gear ratio should I get for better mpg and speedo correction?
I made a post somewhere else, facebook or maybe reddit. whichever, I cant find the post now. I have a 3 inch lift, running 285s now and the speedo is off and the mpg is down a few numbers. What gear ratio do I need to look for when searching for a locker rear end?
98 SR5 4wd, CS144, compass/temp mirror, 2nd gen Hilux Altimeter/Inclinometer ,Chinese knock off diesel heater, Chinese copy of Alpicool CX50, OME 3" lift, 1" Toytec body lift, Snorkel, 13WE, Borla catback, Android hu, LED H4
CWccw is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:08 PM #2
spartacus's Avatar
spartacus's Avatar
This has been discussed profusely on this forum. Here is. good one.
Axle Gear Ratio's
Old 01-08-2021, 12:38 PM #3
Iron duke's Avatar
Iron duke Iron duke is offline
Iron duke has a spectacular aura about Iron duke has a spectacular aura about
Iron duke's Avatar
What's your gears now? How much is it off at 75mph? Is it an auto or 5 speed? MPG's will not change significantly.
Iron duke is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 12:56 PM #4
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
If you have ABS, then regearing will not affect your speedometer. ABS equipped vehicles use the wheel speed sensors for speedometer input. Non abs vehicles use a speed sensor on the transfer case.
Most people with 285's that are automatic regear to 4.88 to account for increased wheel size, wheel weight, and any additional weight from armor and accessories on the vehicle.
Old 01-08-2021, 01:12 PM #5
Since you have an SR5, you have ABS - and as the other poster said, gearing will not affect your speedo. You will need to get a speedometer calibrator to adjust the speed signal sent to your gauge cluster then ECU from the ABS computer.
I used the SGI-5 from Dakota Digital, install shown below (on my '99 - your wire colors may be different):
'17 Chevy Volt Premier
'16 Honda Odyssey Elite
Old 01-08-2021, 02:28 PM #6
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Gear Ratio Calculator. good info put in your numbers, Auto - trans OD is off for 1:1 ratio.
285/75-16 10 ply 4.56 gears Auto my RPM's are 3150 I like it for how I use it, lower RPM's.
4Runner OE Lockers came with 4.30 ratio.
Old 01-08-2021, 03:45 PM #7
Hopeless Diamond's Avatar
Hopeless Diamond Hopeless Diamond is offline
Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about Hopeless Diamond has a spectacular aura about
FWIW, I run 285/75/16 with stock 4.10 gears. Comparing GPS speed and tracking it appears I'm off by ~7%.
Hopeless Diamond is offline   Reply With QuoteReply With Quote
Old 01-08-2021, 05:54 PM #8
Real Name: Mark
Real Name: Mark
Wasn't any concern on speedo for me, just kept in mind driving around.
Old 01-08-2021, 07:21 PM #9
when im doing about 68-69 gps shows 71. Im not sure what my stock gear ratio is.
Old 01-08-2021, 08:57 PM #10
Real Name: Mark
Real Name: Mark
Says so on B-pillar label AO3A = 4.10 AO4A = 4.30
Old 01-09-2021, 01:17 PM #11
Real Name: Mark
Real Name: Mark
Originally Posted by Bad Luck View Post
Most people with 285's that are automatic regear to 4.88...
Thought long n hard on this 4.88 seems to be trail street gears, 4.56 street trail with 285's.
4.56's feel like stock performance on 285's with good mpg's, offroad, I'm dual locked so power gain from 4.88's
wasn't worth running higher rpm's where I spend most of my time. No plans for bigger than 285's.
Old 01-09-2021, 01:48 PM #12
I have AO3A/A340F
If I go to 4.56s would my mpg increase? I used to get 280+ to a tank now im luck if i get 225.
Old 01-09-2021, 03:56 PM #13
Real Name: Mark
Real Name: Mark
You'll get some mpg's back all I can say.
285s , mpg , post , running , speedo
Gear ratio 4X4snowRunner 3rd gen T4Rs 21 07-25-2023 02:42 PM
Best speedo correction approach for larger tires 4Tuitous 3rd gen T4Rs 27 04-11-2020 07:33 PM
Gear ratio? alejo2112 4th Gen T4Rs 6 12-05-2019 03:32 PM
Speedo Gear Doc2012 Want to Buy/Trade 0 10-07-2012 02:53 PM
larger tires and speedo correction... huckleberry668 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 08-30-2007 12:33 PM
