Old 01-25-2021, 01:32 AM #16
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Originally Posted by texadelphia View Post
Might not be getting to that until spring. Winter seems to have started in earnest here in the PNW.
Is that plug a 10mm allen across the board? I couldn't get a 10mm to go in and the 8mm was too small (don't have a 9) The plug is pretty dirty so it could just have grime build up but I still thought the 10 would still fit.
Sent from my moto x4 using Tapatalk
It's a 10.
Old 01-25-2021, 09:28 AM #17
thegipper's Avatar
thegipper thegipper is offline
thegipper is a jewel in the rough thegipper is a jewel in the rough thegipper is a jewel in the rough
thegipper's Avatar
When I couldn't get my front diff fill plug off, I welded a 10mm allen socket onto the plug. The plug was completely stripped from prior attempts. Once I welded the allen socket in place, the plug came out with very little effort. The heat from the welds really helps.
Good luck
1999 SR5 4x4 Auto for parts
2011 Camry SE V6
2011 Highlander Limited
thegipper is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 09:44 AM #18
alumarine alumarine is offline
alumarine has a spectacular aura about alumarine has a spectacular aura about
It's critical that the Allen socket is perfectly clean before you attempt to remove the plug.
Also, when reinstalling do not over tighten.
1991 4runner 4wd Auto V6
1990 4runner 4wd Auto V6
alumarine is offline   Reply With QuoteReply With Quote
Old 01-25-2021, 11:31 AM #19
texadelphia texadelphia is offline
texadelphia will become famous soon enough
Going to clean everything very well, heat the area around the plug, rap on it with a hammer for good measure, and give it a go. The plug looks to be in very good shape, not rounded or anything, so at least I have a good starting point.
1997 SR5, 3.4L, Manual
texadelphia is offline   Reply With QuoteReply With Quote
Old 01-26-2021, 12:37 PM #20
mtbtim's Avatar
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
Good luck
That's the same experience we had when we shot this video. It wasn't so much the fact we now had a solid connection of the allen socket to the plug that made it easier to remove. It was the heat from the welding process that had the most positive affect. After we had that allen socket welded on, I was able to break the drain plug free with a 1 foot breaker bar with relative ease. On other rigs, it took me standing on a 2 foot breaker bar to break it free.
At one of my Timmy the Toolman parties, a guy wanted help getting his front diff drain plug off. I heated up around the plug once, tried with an 18" breaker bar and no go. I applied heat for a second time and tried again. It still didn't budge. I applied heat for a 3rd time and the plug finally broke free. It takes quite a bit of heat to get these stubborn plugs loose. The key is to not strip the plug. You keep on applying heat until you can get it off with a moderate amount of force. If you have to stand on a 2 foot breaker bar like I stupidly did one time and got away with without stripping the plug, you haven't applied enough heat yet.
Folks, I'll say it again. Heat is your friend when dealing with stuck fill and drain plugs.
budge , fill , oil , penetrating , plug
Transmission Fill Plug 4thGen4.7 4th Gen T4Rs 18 06-11-2022 05:30 PM
transmission fill plug 95supra General Discussions 1 10-14-2017 12:08 AM
2011 Transmission Fill plug Sandpiper 5th gen T4Rs 0 09-08-2011 11:32 AM
Help 2005 transmission fill plug? haroldpo6 4th Gen T4Rs 10 12-21-2010 12:43 PM
