Old 01-10-2021, 03:01 PM #1
Hollywood1 Hollywood1 is offline
Hollywood1 is on a distinguished road
Tightening leaky VC head bolts. Do you Remove intake?
I’m gonna retorque my 02 3.4 leaky valve covers bolts today. 175k miles.
When doing so, do you remove the complete Intake manifold to get to all the valve cover gaskets?
I figured I’d remove the intake and clean it out while it’s off. Along with getting to all the Vakve Cover Bolts.
Gonna degrease the engine beforehand, then once again afterwards.
I’ll replace the valve covers when I do a full timing belt change end of next year.
Any insight appreciated.
2000 2WD SR5 V-6
Hollywood1 is offline   Reply With QuoteReply With Quote
Old 01-10-2021, 05:30 PM #2
spartacus's Avatar
spartacus's Avatar
To get to all the bolts you'll have to remove the upper and lower plenums. Caution: when tightening VC bolts use the pattern specified in the fsm' making several passes also make sure the torque wrench is calibrated so as to not over tighten the bolts.VC bolt torque 53 inch pounds.
Old 01-10-2021, 06:05 PM #3
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
If your going through all the trouble to remove the intake plenum and do intake gaskets, you might aswell do the VC gaskets, half moons and cam plugs, I guess you could reuse the intake gaskets but then you'll have to use a sealant which makes the job harder to clean up next round. You can do the timing without removing the VC's, unless you have a leaking cam seal, then ideally you would want the VC's off so you can pull the bearing cap for the cam seal, not completely needed but the ideal way to do cam seals.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-11-2021, 10:34 AM #4
96RedRunner's Avatar
Real Name: Mark
Real Name: Mark
Was a time I had a VC leak ha who hasn't, wanted to do as little as possible.
I tightened what I could get at using crows foot wrenches, regular, sockets, swivels, stopped leak till ready for Full Monty. Did remove intake.
Old 01-11-2021, 12:03 PM #5
mtbtim's Avatar
mtbtim mtbtim is offline
Real Name: Tim
mtbtim's Avatar
Real Name: Tim
I agree with @Malcolm99 . Just do the job and be done with it. It's not just the valve cover gaskets that can cause a leak. It's also the cam plugs and half moons that can leak. While you're doing the job, you could clean the throttle body, clean the IAC, and clean the MAF. You could also at this time renew your spark plugs and wires. Give your rig a little love. It's money well spent.
Old 01-11-2021, 12:42 PM #6
Real Name: Mark
Real Name: Mark
Did remove intake Tube between filter n TB, fixed it.
Old 01-11-2021, 12:56 PM #7
spartacus's Avatar
spartacus's Avatar
Taking the plenum off is a ten minute job I think there are 6 bolts on top 3 at the bottom and few hoses and the air intake disconnect. I've reused the metal intake plenum gaskets several times while trouble shooting the injectors and have had no issues also never use a sealant on em. I took the plenum off and reinstalled it like 5 times and never had any issues.
Old 01-11-2021, 04:01 PM #8
Real Name: Mark
Real Name: Mark
Ten minutes be stretching it, ha. Nah it a easy job, time I mentioned was a fly by fix during oil change. Lotta things to like with 3rd Gen's V/C gaskets not one of them.
cover , intake , leaky , remove , valve
How to remove roofrack bolts? jjdbike 5th gen T4Rs 15 04-26-2016 05:04 PM
Leaky/Cracked Head, Considering Engine Replacement Slice 3rd gen T4Rs 5 02-22-2015 11:21 PM
which tool to remove connecting rod & head bolts? rockthepouch Classic T4Rs 5 01-15-2012 12:54 PM
How to remove U-joint bolts Mr.pughe Classic T4Rs 6 11-28-2010 11:57 PM
Is tightening the driveshaft bolts necessary? kn38ms Maintenance/Detailing 1 04-18-2008 08:23 PM
