Old 03-10-2024, 12:13 AM #16
Rockinrhombus Rockinrhombus is offline
Rockinrhombus is on a distinguished road
wow looks like I stumbled onto this thread at just the right time! Fresh pic updates!
Just trying to revive an old project truck and pick up where an old "mechanic" left off.
Mine's an 89 with 3vze though, hopefully this nudges me in the right direction
Rockinrhombus is offline   Reply With QuoteReply With Quote
Old 04-16-2024, 07:38 PM #17
aussiebobaustin aussiebobaustin is offline
aussiebobaustin is on a distinguished road
For some reason I can't find the "diagram" ... I converted my 2002 4Runner to Manual and now need to do the wiring to not get the CEL.
Can someone tell me where to find the subject wiring diagram.
aussiebobaustin is offline   Reply With QuoteReply With Quote
Old 04-17-2024, 01:11 PM #18
St Runner's Avatar
St Runner St Runner is offline
St Runner will become famous soon enough
St Runner's Avatar
Not sure you are going to find a diagram for a 2002. Most people who have swapped a 2001/2002 find a manual Tacoma ECU from 2001-2004. It should plug right in. Then you would need to put in the clutch start/cancel switches if you want it like factory
1997 SR5 4x4
R150f swap E-locked 4.30 gears
Tundra 231 brakes LC 80 rims 285/75/16
2001 SR5 4x4
St Runner is offline   Reply With QuoteReply With Quote
Old 04-30-2024, 03:06 PM #19
dtl92 dtl92 is offline
dtl92 is on a distinguished road
I'm not seeing the wiring diagram either. Do you have a new link?
dtl92 is offline   Reply With QuoteReply With Quote
Old 05-02-2024, 03:32 PM #20
Team_Jake's Avatar
Team_Jake Team_Jake is offline
Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice Team_Jake is just really nice
Team_Jake's Avatar
Sorry guys, I don’t know of a good photo hosting site. In the past I used SmugMug but they charge way too much now. I just created a Flickr account and embedded the photos through that on the first post. I’m open to other photo hosting platforms if anyone has one they’d recommend.
1999 4Runner Limited - 5VZ, 4wd, Factory E-Locker, Multi-Mode, 5-speed swap, Armored, Icons, 295s (thread)
2001 Tacoma Xtracab - 3RZ, 4wd, 5-speed (Daily Driver)
Team_Jake is offline   Reply With QuoteReply With Quote
Old 05-03-2024, 11:10 AM #21
I'm seeing them now with the new upload. This is really helpful, thanks!
Old 07-07-2024, 05:41 PM #22
busmup808's Avatar
busmup808 busmup808 is offline
busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough busmup808 is a jewel in the rough
busmup808's Avatar
Help please
PARK NEUTRAL SAFTY SWITCH= on automatic transmission
CLUTCH DEPRESS SWITCH= on clutch pedal assembly?
CLUTCH START CANCEL SWITCH= on L dash
CLUTCH RELEASE SWITCH= don’t know where this is?
REVERSE LIGHT SWITCH= on manual trans
So basically I just want to confirm where the CLUTCH DEPRESS/RELEASE SWITCHES are please. Much Mahaloz in advance.
5-Speed Swap Wiring Diagram-img_7586-jpg  5-Speed Swap Wiring Diagram-img_7585-jpg
Busmup808 all day, all night!
busmup808 is offline   Reply With QuoteReply With Quote
Old 07-08-2024, 12:31 AM #23
busmup808's Avatar
busmup808's Avatar
I found it
CLUTCH START SW=CLUTCH DEPRESS SWITCH
CRUISE CONTROL CLUTCH SWITCH=CLUTCH RELEASE SWITCH
Got the answers by looking at my FSM and it turned out the same, just worded differently. Much Mahaloz from Oahu,HI🤙🏾
Old 07-09-2024, 11:47 PM #24
Team_Jake's Avatar
Team_Jake's Avatar
@busmup808
Clutch Depress Switch: it’s on the clutch pedal assembly, when you press the clutch all the way to the floor, the clutch pedal will engage with a switch allowing the vehicle to start.
Clutch Release Switch: also on the clutch pedal assembly, but the switch is always engaged until you start to push the clutch in. If using cruise control, once the button is disengaged, the cruise control will automatically cancel.
Clutch Start Cancel Switch: a button found on the left side of the steering wheel. It allows the vehicle to start without the Clutch Depress Switch needing to be engaged. It can be useful if you want to start the vehicle while sitting in the passenger seat (be sure the transmission is in neutral). It’s also very useful when crawling on a steep incline; if the engine stalls, have one foot on the gas and one foot on the brake, press the Clutch Start Cancel Switch, put it in gear, and use the starter to get the vehicle moving (especially useful with a doubler / crawl box).
Reverse Light Switch: an electrical connector on the passenger side of the transmission (I believe the only electrical connection on a manual transmission).
Hope this info helps! I actually just got back from Oahu, vacation with my wife and kiddo, I was able to bodysurf at Point Panic which has been a long time bucket list item I was able to check off.
Old 07-10-2024, 10:34 PM #25
busmup808's Avatar
busmup808's Avatar
Team Jake
Much Mahaloz 🤙🏾. I figured it out after looking at my FSM & EWD. So if I understand you correctly, if I get a small piece of wire and crimp 2 spades on each end of pins 5&6, the truck will start? There’s a guy on YouTube that did the same conversation, but plugged the park/neutral switch on the existing plug to make the truck start. If I can just jump pins 5/6, it would make a cleaner install
I was thinking of this:
5-Speed Swap Wiring Diagram-img_3188-jpg
Old 07-11-2024, 12:22 AM #26
Team_Jake's Avatar
Team_Jake's Avatar
@busmup808
You’ll have to confirm with your EWD for your specific model year (I can help with that if you need), but for a 1999 yes just jumping pins 5/6 like you have shown in your photo will allow your ignition to start.
Old 07-11-2024, 04:34 AM #27
busmup808's Avatar
busmup808's Avatar
Ewd
The colors and PIN numbers match the same for my 98. I crossed reference everything and it is identical
Old 07-11-2024, 09:09 AM #28
St Runner's Avatar
St Runner's Avatar
It will start like that but I would not want to do a final install like that. Understand that all you are doing is grounding the starting circuit. that is what the park/neutral switch and the clutch depress/cancel switch do. If you ground it permanently it will start in any gear at all times. If you do choose to do it that way its better to do it in the body behind the glove box where the engine harness comes through and it is dry. Or better yet take that starting circuit wire and run it to the clutch depress switch or even to just a grounded switch somewhere and then you will have a theft proof vehicle
1997 SR5 4x4
2001 SR5 4x4
Old 07-11-2024, 12:46 PM #29
busmup808's Avatar
busmup808's Avatar
Mahaloz for the input, but this is just a temporary thing for me to move the truck around. I have a clutch/cancel switch with pigtail coming in next week and the clutch release sw/cruise release sw on the clutch assembly will be wired in correctly. I would never make this my final. I’m taking the wiring further and will be adding the 2HI & 4LO light up in the cluster when engaged. When done, I will post pictures of what I did to complete in detail.
Old 07-11-2024, 12:50 PM #30
busmup808's Avatar
busmup808's Avatar
Revised
Originally Posted by Team_Jake View Post
@busmup808
Mahaloz Team Jake and all who contributed
5-Speed Swap Wiring Diagram-img_7546-jpg
clutch , diagram , swap , switch , wiring
97 4Runner ECU/ECM wiring diagram/PIN diagram Dawgz 3rd gen T4Rs 5 02-20-2023 03:04 PM
5 speed swap wiring issue dhphamqc 3rd gen T4Rs 4 02-19-2018 11:22 AM
5 speed swap, wiring question kolelt 3rd gen T4Rs 18 01-20-2018 01:18 PM
Anyone got the diagram for connector G18 (electric wiring diagram) jicko 5th gen T4Rs 0 04-03-2015 10:01 PM
'90 automatic to 5 speed swap wiring question Tim Wilson Classic T4Rs 0 10-03-2014 09:11 AM
