Old 01-14-2021, 12:06 PM #1
Doc3g Doc3g is offline
Doc3g will become famous soon enough
Evap Charcoal Cannister vacuum line recommendation
I plan on replacing my vacuum lines, particularly for the Charcoal canister. In fact, I'm considering relocating it in an attempt to build my power distribution platform closer to the battery. Hence, I'm looking for recommendations (ie, local NAPA or Amazon) for good quality hose because I want to know that if I try to relocate it and things don't work out, that's it's not because I used substandard materials for the experiment.
Updated LED Interior Lighting Thread
99' SR5 HRU
Doc3g is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 01:51 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I haven't been able to find good vacuum line like what came on 1990-2009 Japan vehicles, had to go to wrecking yards and remove as much as possible from made in Japan vehicles, the silicon and washer fluid hose just doesn't work well for us, and I found the newer vehicles don't usually have much vacuum lines of any decent length. I didn't try any of the OEM dealers though figuring they would only supply specific sections as required.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 02:33 PM #3
shadow247's Avatar
shadow247 shadow247 is offline
shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice shadow247 is just really nice
shadow247's Avatar
Check with your dealer. I bet they have bulk vacuum hose in the back...
Failing that.
I actually got some vacuum hose from my local Honda Motorcycle dealer. The Service department had a bunch of pieces and sold it to me for like a buck a foot....ended up being about 4 dollars for the pieces I needed for my motorcycle, but it was just standard vacuum line - but it's branded HONDA and made in Japan.
The 4Runner Show
shadow247 is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 02:48 PM #4
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
Verocious Platinum Cured Silicone Vacuum Line Sold By the Foot | Verocious Motorsports
TurboLogic Silicone Vacuum Hose 4MM
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-14-2021, 06:57 PM #5
Malcolm99's Avatar
Malcolm99's Avatar
The Honda shop is a great idea!, it's used for fuel venting typically so resistant to oil and fuel vapours, probably some form of EPDM for chemical resistance. That silicon stuff is terrible, and is completely useless on boosted vehicles or vehicles with a pcv system.
Old 01-15-2021, 12:54 AM #6
What exactly is wrong with silicon hoses for naturally aspirated applications? BTW, does anyone know at least what the inside/outside diameter of our stock vacuum lines are?
99' SR5 HRU
Old 01-15-2021, 10:33 AM #7
firemanj92 firemanj92 is offline
firemanj92 is on a distinguished road
There are plenty of vendors that carry the OEM vacuum hose/"vacuum piping" in stock for Land Cruiser/Toyota owners, absolute Wit's end-$17 (kit includes 6-20" lines) , SOR-$17 for 23", cruisercorps, CCOT. I've have purchased from these vendors without any issues.
OEM hose 3.5mm for smaller
I've also purhased the Silicone kit which worked fine but later swapped it for OEM rubber vacuum lines. Hope this helps -J
firemanj92 is offline   Reply With QuoteReply With Quote
Old 01-15-2021, 08:45 PM #8
Thanks, I'll definitely check them out. Unfortunately, I went and measured the space I had on the passenger side and it is inadequate to fit the canister. I'm not really sure if there is another suitable location so I'm back to putting my power distribution platform on the passenger side.
99' SR5 HRU
charcoal , evap , hose , quality , vacuum
3rd Gen vacuum line(s) leak? charcoal filter? Derekl36 3rd gen T4Rs 0 04-20-2015 07:37 PM
WTB charcoal canister EVAP jreask Want to Buy/Trade 1 06-23-2014 12:38 AM
Fuel Leak... Charcoal Cannister? ad1315 Classic T4Rs 8 01-25-2013 08:17 PM
'06 Evap Pump/Charcoal Cannister Replacement? dipNrip Problems & Warranty Issues 0 01-02-2011 08:34 PM
Charcoal cannister VSV lstall 3rd gen T4Rs 3 05-18-2008 04:15 PM
