Old 01-16-2021, 03:02 PM #1
Ghostrider Ghostrider is offline
Ghostrider will become famous soon enough
Glue door fabric
Anyone want to comment on how to get to the point you can re-glue this piece. Just wondering what to take off before I start.
This was added when new in 2000 by an installer who switched the SR5 cloth seats for leather. Does the darker grey surround part just pull off like the armrest or how do I remove enough stuff to glue it back
Glue door fabric-1-jpg
Ghostrider is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 06:38 PM #2
Malcolm99's Avatar
Malcolm99 Malcolm99 is offline
Malcolm99 has a spectacular aura about Malcolm99 has a spectacular aura about
Malcolm99's Avatar
I haven't done this on a Toyota or 3rd gen. Remove the entire "door card" as per usual, on the backside there will be tabs, either plastic, steel, bolts, screws or combination, separate grab handle and cladding from door cards, use fabric spray adhesive or other good alternatives and reinstall. It looks like that material is dried out, for that small an area it might be a good time to replace it with new or good shape originals. I would pull the door cards in warm conditions to avoid clip and clip retainer damage, either a hot day or a warm shop.
Malcolm99 is offline   Reply With QuoteReply With Quote
Old 01-16-2021, 06:40 PM #3
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
The leather door fabric came off on my old 2003 Ford Taurus and it was a pita to replace. Here in Arizona the sun will met pretty much any glue you use, so I eventually just removed all the skins and cleaned the glue residue.
If you live in a state that doesn't get up to 115° then I would suggest putting some kind of fabric adhesive under the leather and using a screwdriver to push it into the slot.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 01-23-2021, 09:59 PM #4
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
sleepydad's Avatar
Real Name: Andy ಠ_ಠ
hey sorry I missed this one... I have been doing some trial and error on this because I want to re-do all the door cards in one of my trucks... the fabric and door pulls are kind of nasty and beyond cleaning.
the old fabric probably foam backed vinyl? the foam/glue breaks down and separates like this?
Glue door fabric
this is just a test one I did so I could learn how not to do it, success on that part for sure... it has bubbles or lumps in it. I know what not to do next time but this was just a test so no big deal.
Glue door fabric
the edge is not glued and the slot/channel along the edge really does not hold the fabric, it's just kind of wedged into it. I know that sounds strange but I have studied a couple of these now and it's really effective and if done correctly is just fine. toyota assembly people know their jobs. yes they do. so you can just peal the edge out and it's not glued in. guessing this is for expansion and contraction otherwise you would have failures like the one you are seeing.
Glue door fabric
you will want to clean off any of the crumbled foam and make sure it's clean then apply this stuff to both the fabric and door card. once it sets up for like 15-20 min you can then make contact with the 2 sides and it will be permanently joined. unless you replace the entire surface I'm pretty sure your gong to have lumps and bumps... but I guess you have to decide how much that bothers you but pretty sure it will look bad?
Glue door fabric
Old 01-26-2021, 11:52 PM #5
plcfcng's Avatar
plcfcng plcfcng is offline
Location: Southern California (please don't hold it against me)
Real Name: michael
plcfcng will become famous soon enough plcfcng will become famous soon enough
plcfcng's Avatar
Real Name: michael
Elmers wood glue no kidding it works fine
plcfcng is offline   Reply With QuoteReply With Quote
door , glue , piece , re-glue , wondering
Dashboard Glue kbfox18 5th gen T4Rs 4 08-22-2013 03:01 PM
Which glue for door seal SJC General Discussions 4 07-23-2012 11:08 PM
2010 Fabric vs. Sport Fabric historyteacher 5th gen T4Rs 9 12-13-2010 04:26 PM
2004 door panel repair-- soft fabric near window 4runnerfrenzy 4th Gen T4Rs 2 11-01-2010 11:42 PM
