Old 01-18-2021, 10:17 AM #1
JZiggy's Avatar
JZiggy JZiggy is offline
JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future JZiggy has a brilliant future
JZiggy's Avatar
Headlight sealant?
Starting to make plans for a retrofit. Lots of places recommend butyl rubber sealant for headlights between the lens and the housing. Some individuals say clear silicone is good enough.
What has worked for you? What do you recommend?
JZiggy is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 10:56 AM #2
Kanoe's Avatar
Kanoe Kanoe is offline
Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice Kanoe is just really nice
Kanoe's Avatar
Isn't butyl rubber a fairly soft flexible product? I used it on boat windows before. i can't imagine it would like the heat of a headlight very much unless I'm not thinking of the same stuff.
-1993 Corolla Wagon 7AFE
-2001 Echo D.D.
Kanoe is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 12:34 PM #3
Ed_C's Avatar
Ed_C Ed_C is offline
Real Name: Ed
Ed_C's Avatar
Real Name: Ed
There are higher temperature butyls used for headlights, you can actually buy it from Nissan dealers but apparently costs much more than the aftermarket stuff.
Diode Dynamics butyl Butyl Headlamp Sealant – Lightwerkz Global Inc
Video about the above Diode Dynamics Sealant Overview - Clean Up - YouTube
Morimoto RetroRubber Morimoto RetroRubber Butyl Glue – Lightwerkz Global Inc
Opening and resealing with butyl Opening & Resealing Automotive Headlights using Morimoto Retro Rubber - YouTube
Old 01-18-2021, 07:06 PM #4
LittleCaesar's Avatar
LittleCaesar LittleCaesar is offline
LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice LittleCaesar is just really nice
I have used this a couple of times with good success:
https://www.3m.com/3M/en_US/company-...3242009&rt=rud
LittleCaesar is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 07:27 PM #5
Nobody Special's Avatar
Nobody Special Nobody Special is offline
Real Name: Special Ed
Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough Nobody Special is a jewel in the rough
I painted the insides of the housings on my '06 X-Runner, and a few minutes in the oven was enough to split each one open.
(OEM stuff was black too)
I used this to seal them back up and 13 years later, no water, fog or degradation issues.
I just used some from a new tube on a cracked humidifier tank.
Works well.
N̷̢̗̪̗̞̯͈̥̐̉͌͜͝O̴̢̨͚̭͕̾B̶̪̩̙̰̩̟̪͓̠̫̉̏̀͗̀̾͒̏̐̽O̵̾̏̈ ̨̡̖̬̀͂̒͂͂̃D̷̯̪͙͍͖͙̰͒̈Y̸͎̗̝͍͌̑̆͂̈́͘̕
Nobody Special is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 07:28 PM #6
It is soft. When I painted my housings, I think it was like 7-10 minutes in my oven and I pried them open by hand.
Low temp... Maybe 250.
Old 01-18-2021, 08:00 PM #7
Drew76 Drew76 is offline
Drew76 is on a distinguished road
I've used the Nissan Stuff, works good. My retro is all chrome I may use the retro rubber in gray next time to try it. 3rd gen 4runner headlight housings are quite forgiving for retrofits, lots of room, all glass lens etc. My personal opinion is that anything less than a 3" lens looks small in the housing. I've only done a retro with OEM projectors nuts and bolts for mounting but the mini D2S seems quite appealing for ease of install in our housings with the threaded shaft and seem to be quite popular.
Drew76 is offline   Reply With QuoteReply With Quote
Old 01-18-2021, 08:19 PM #8
spartacus's Avatar
spartacus's Avatar
Moromoto. Amazon.com: RetroRubber OEM Grade Butyl Headlight Sealant, Black: Automotive
Old 01-19-2021, 12:02 AM #9
JZiggy's Avatar
JZiggy's Avatar
I sprang for the gray retro rubber. Thanks guys!
good , recommend , sealant , silicone , worked
303 touchless sealant DigitalRJH 5th gen T4Rs 12 05-29-2019 03:45 PM
Sealant on brake hoses?? 4xt4r General Discussions 3 09-09-2015 04:47 AM
Watertight roof sealant. Jwhite General Discussions 6 04-02-2014 11:50 PM
Paint Sealant 2003_4Runner 4th Gen T4Rs 0 02-18-2004 01:18 PM
