Old 01-30-2021, 08:07 PM #16
cas5259 cas5259 is offline
cas5259 is on a distinguished road
We’re in the same boat. Did the valve covers and oil cooler but still have a small leak. Used UV dye and thought for sure it was the back of the oil pan.
Dropped diff, resealed the pan with Toyota fipg and nope, still leaking, just less than before. 99% it’s the RMS. Only getting 5-6 drops overnight.
cas5259 is offline   Reply With QuoteReply With Quote
Old 01-30-2021, 09:03 PM #17
bmwahba46 bmwahba46 is offline
bmwahba46 is on a distinguished road
Shoot man. I’m thinking it might be too. There really not much else that can leak in this area I feel. Oil pan is fairly new since this motor was swapped.
bmwahba46 is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 02:26 PM #18
Welp. I am gonna take it to the local trusted indy to handle the rear main next week. In the meantime, if anyone has any other possible causes to check out, would love to hear some thoughts on what to look into.
Old 02-02-2021, 03:25 PM #19
Zingvs's Avatar
Zingvs Zingvs is offline
Real Name: Zander
Zingvs is on a distinguished road
Zingvs's Avatar
Real Name: Zander
You can always try running 10w-30 to slow/stop oil leaks. A lot cheaper than pulling the transmission, and super easy.
2002 4x4 Limited Stellar Blue Pearl Eibach/Bilstein 5100 3" Lift 285/75r16
Zingvs is offline   Reply With QuoteReply With Quote
Old 02-02-2021, 05:14 PM #20
I more so want to fix whatever's causing the leak rather than band-aid it!
Old 07-23-2023, 01:56 PM #21
lucidberries lucidberries is offline
lucidberries is on a distinguished road
Did this turn out to be the culprit?
Am in a similar boat - my local shop said is either the VC, oil pan, or rear main seal but they can't tell.
Is there a way to confirm the VC are leaking without pulling anything? Front is all very clean and I felt around all along the back side where the half moons but don't think I felt any fresh oil vs old stuff from before the previous owner replaced them on my rig.
lucidberries is offline   Reply With QuoteReply With Quote
Old 07-24-2023, 04:43 AM #22
JoeT4R's Avatar
JoeT4R JoeT4R is offline
JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light JoeT4R is a glorious beacon of light
JoeT4R's Avatar
Take a strong powered flashlight and poke around-- visually inspect the valve covers as closely as possible. You don't need to pull anything for this
Sent from my SM-S908U using Tapatalk
Old 07-24-2023, 10:44 AM #23
Can't see any oil from the top side whatsoever but when I run the truck up the mountain I do get a bit of that burning oil smell. Am seeing 1 or 2 drops every few days when the vehicle is parked.
Old 07-24-2023, 03:23 PM #24
Bad Luck Bad Luck is offline
Real Name: Patrick
Real Name: Patrick
Crawl underneath and check for leaks then.
Old 08-21-2023, 01:28 PM #25
Would you be able to confidently say whether the valve cover is leaking or not by looking from the top? (from the bottom there is oil everywhere so not helpful) Trying to make the call to replace the value covers as a logical step 1 but not sure...
Old 08-22-2023, 07:08 AM #26
JoeT4R's Avatar
JoeT4R's Avatar
I mean you can open the hood and look right at them and see if there's any seepage coming out of them. If so, you can do a few things.
1. Spray everything down with a good degreaser (honestly I use brake parts cleaner, lol)
2. Gently tighten your valve cover bolts
3. If, after a period of time after completing steps 1 & 2, you're still experiencing oil seepage, I'd go ahead and replace the valve cover gaskets.
VCG's are not a difficult job to do and are generally a good maintenance item to cover if you plan to hang onto your rig for a decent period of time. Nobody wants to deal with an oil leak that keeps coming back.
Old 08-22-2023, 11:05 AM #27
Real Name: Patrick
Real Name: Patrick
Just wanted to second this and really stress the GENTLY tightening those bolts. The torque spec on those is super low!
Old 08-22-2023, 11:23 AM #28
Yes of course, trying to put this leak to bed but my situation is the dealer replaced the VC a few years ago (via the previous owner) and there is no visible seepage anywhere looking from the front at the top but there is oil dripping quite a bit underneath.
I am trying to decern if I should get the VC done again (perhaps they missed sealing the back cam plugs or something) but the shop also thinks might be the rear main so trying to rule it out as best I can
Old 08-22-2023, 11:54 AM #29
JoeT4R's Avatar
JoeT4R's Avatar
It definitely could be a rear main leak. I'm curious if mine is leaking, too. If you're gonna do the work on the valve cover gaskets yourself, then okay cool, save the money on labor. But if you don't have reason to believe that's the source of your leak then I certainly wouldn't be going and paying someone to do them over again.
Old 08-22-2023, 07:15 PM #30
Real Name: Patrick
Real Name: Patrick
You can see the back of both heads from under the vehicle. Also the valve cover bolts are known to loosen over time so it’s worth checking them regardless.
amount , concerned , list , noticed , oil
She's taking a leak! Rear axle seal leak that is.... fightman80 3rd gen T4Rs 76 09-18-2014 04:52 PM
Coolant leak solution, pepper, eggs or liquid aluminum stop leak? BUGSEY General Discussions 1 01-30-2014 01:32 PM
Radiator leak, and oil leak maybe tranny? Not sure what should I do? ironmaidn23 Classic T4Rs 14 06-25-2013 10:34 AM
bad oil leak help please OsaFsb Classic T4Rs 11 01-23-2011 09:13 PM
Coolant leak, whining noise, vacuum leak, alternator, starter, battery issues Max O 3rd gen T4Rs 4 12-03-2009 10:31 AM
